Old Aug 20, 2012, 10:39 PM
Blaser is offline
Find More Posts by Blaser
Blaser's Avatar
Joined Mar 2012
yes on the y connector for the flaps worked fine
Blaser is offline Find More Posts by Blaser
Old Aug 20, 2012, 10:41 PM
dbc is offline
dbc
Find More Posts by dbc
dbc
United States, FL, Brooksville
Joined Apr 2008
You got your's ready to maiden, Doubletap? What about CG? I havent tried to balance it yet.
dbc is offline Find More Posts by dbc
Old Aug 20, 2012, 10:44 PM
dbc is offline
dbc
dbc
Joined Apr 2008
Hummm... The servos are mounted opposite each other so one must be reversed. I haven't even looked at it that closely.
Old Aug 20, 2012, 10:46 PM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
Haven't had a chance to set it up yet.
Doubletap is offline Find More Posts by Doubletap
Old Aug 20, 2012, 11:13 PM
Westwood is offline
Find More Posts by Westwood
Canada, BC, Burnaby
Joined Oct 2010
Originally Posted by Westwood
Super sky surfer mods (1 min 27 sec)
Originally Posted by lv2soar View Post
Hi Westwood.
looks like a good idea to add magnet for the mod.
looks like a strong connection
*** What size magnet did you used?
i used this one
http://hobbyking.com/hobbyking/store...idProduct=7645
10 mm
Westwood is offline Find More Posts by Westwood
Old Aug 21, 2012, 12:32 PM
compuatic is offline
Find More Posts by compuatic
Principal Member
compuatic's Avatar
San Francisco, CA
Joined Jun 2002
Guys, i just maidened mine today and it flew like a dream. Full FPV setup with OSD on board. I used a 5000mah 3S like i mentioned earlier which fit like a glove in the battery compartment. CG was spot on with no added weight. I will post information and pics later on. I also recorded the FPV video and I'll see if it turned out good enough to make it worth posting.
More later...
compuatic is offline Find More Posts by compuatic
Old Aug 21, 2012, 12:53 PM
Doubletap's Avatar
Joined Jul 2005
More later...
Awesome!!!
Old Aug 21, 2012, 01:42 PM
jcarff is offline
Find More Posts by jcarff
United States, FL, Pensacola
Joined Jul 2012
Flight Time
How long of a flight were you able to get, and what should be the flight time of this platform with fpv gear on board.
jcarff is offline Find More Posts by jcarff
Old Aug 21, 2012, 01:58 PM
jcarff is offline
Joined Jul 2012
Battery
I have a couple 6000mAh 3 cell lipos from an old quad project, would that be to much for this plane?
Old Aug 21, 2012, 03:23 PM
dbc is offline
dbc
dbc
Joined Apr 2008
My measurements on the stock prop came in close to Blaser's. This with a new, fully charged 3600 3s 20c. Power draw: 310 watts, 25.5 amps. Prop RPM 12360. Actual measured thrust: 1320g. Calculated data: pitch speed 74 mph, thrust 1331g.
APC 9x6 prop gave 418 watts, 34.7 amps. Way over the recommended max. An APC 8x6 gave similar performance to the stock prop. APC makes an 8x8 but I dont have one in the prop box. It might give an improvement over the stock and still remain with the spec's.
The stock prop is going to be very close to optimum for this power system and it's the one I'll use initially.
Old Aug 21, 2012, 03:24 PM
Principal Member
compuatic's Avatar
San Francisco, CA
Joined Jun 2002
i burned through about 1500mah in 15 minutes. I wasn't flying efficiently by any means. The motor pulls ~20amps at full throttle with 3S and the stock prop. about 4amps are needed to maintain altitude. With a 5000mah pack, a 45min fpv flight should be easy. An hour if you do it Prius style.
Old Aug 21, 2012, 03:54 PM
porcia83 is offline
Find More Posts by porcia83
United States, CT, Hartford
Joined Jun 2009
Couldn't stand looking at pics and videos, broke down and bought it.
porcia83 is offline Find More Posts by porcia83
Reply With Quote  (Disabled)
Old Aug 21, 2012, 04:00 PM
Doubletap's Avatar
Joined Jul 2005
WOW! and that is for a plane loaded down with all that extra electronic gear, so the clean plane by itself, one would probably pass out of boredom after a 70 minute flight or so.
Old Aug 21, 2012, 04:01 PM
Doubletap's Avatar
Joined Jul 2005
HA HA HA!!!! Only surprised you had held out this long.
Old Aug 21, 2012, 04:09 PM
porcia83 is offline
Joined Jun 2009
I double checked shipping and it was cheaper today for some reason, it was over 30 when I checked last, 21.00 today....i thought screw it, I just sold 5 planes...I can justify getting one more (and hiding it in the shed).
Discussion Banana Hobby BlitzRCWorks Sky Surfer JoshB Electric Plane Talk 12 Feb 14, 2012 11:01 PM
Found Looking for BlitzRCWorks Sky Surfer Airframe Only or Wing Set cutty01 Aircraft - Electric - Airplanes (FS/W) 0 Aug 16, 2010 03:16 PM
Discussion BlitzRCWorks Sky Surfer Aerobatic Flench Beginner Training Area (Aircraft-Electric) 4 Feb 13, 2010 03:17 PM
Discussion sky surfer powered parachute $29.95 w/ Free shipping interplanet Hot Online Deals 26 Dec 30, 2008 10:58 PM
