This thread is privately moderated by ross_badger, who may elect to delete unwanted replies.
Old Aug 05, 2012, 12:38 PM
ross_badger is offline
Find More Posts by ross_badger
Trader Rating: 70
SuperX Hex and X8 Flyer
ross_badger's Avatar
Columbus, IN
Joined Jul 2009
Trader Rating: 70
Sold
SOLD - Eagle Eyes FPV Diversity Station
Like new Eagle Eyes FPV Diversity Station used only a few times. It is the same model as shown in the link, with the exception of the plastic case (this one has clear shrink wrap instead of the plastic case) :
http://www.readymaderc.com/store/ind...roducts_id=121
I'm asking $SOLD shipped Priority Mail with tracking in the US. Comes with a power cable with Deans plug battery connector.
Paypal only....PM me if you are interested.
* Receiver Diversity - when you connect two NTSC or PAL audio/video receivers to it (of any frequency), the EagleEyesTM picks the better signal at any given time, which can greatly reduce video fades and improve your FPV experience! A variety of diversity settings are configurable with the on-board switches and LED indicators.
* Antenna Tracking - when coupled with our OSD Pro, the EagleEyesTM is the heart of a full-featured pan/tilt antenna tracker. Powerful, easy to use menus are provided for adjusting the EagleEyesTM to work flawlessly with the tracker of your choice. ReadyMadeRC.com produces a low cost, high quality tracker. The built-in regulator drives even large pan/tilt servos, with no need for an external BEC.
* Telemetry - When coupled with our OSD Pro, all Eagle Tree data (not just GPS position) are transmitted to your laptop, via your video transmitter and the EagleEyesTM USB port (separate USB cable required). Your flight can then be graphed and displayed with our powerful software, or visualized (either in real time or after your flight) with Google Earth!
* Four Channel A/V Distribution - Ever wish you had more video/audio outputs? The EagleEyesTM has four built-in outputs!
* Programmable Low Voltage Alarm - How is your ground station battery doing? Now you can program a low voltage alarm buzzer, which alerts you when your battery is below your chosen voltage. The buzzer can also be programmed to alert for other conditions, such as poor telemetry signal.
Here are the specifications:
* Two video inputs -NTSC/PAL, using your video receivers of any frequency. Video Input 2 is adjustable to match Video Input 1.
* Two audio inputs - Two monaural audio inputs are supported. Audio Input 2 is adjustable to match Audio Input 1.
* Four A/V outputs - Four video outputs (75 ohm) and four "line level" audio outputs
* Power Input - Power input range approximately 6V to 14V. Barrel style power input with standard 2.1mm center pin.
* Two Servo Outputs for pan and tilt trackers - Unit is capabable of delivering 5A burst output to drive even large pan/tilt servos.
* USB Port for connecting to PC, for live PC display of telemetry and firmware update. Note: A standard USB "Mini-B" cable required for these features, but not included.
ross_badger is offline Find More Posts by ross_badger
Old Aug 05, 2012, 04:14 PM
jsxx is offline
Find More Posts by jsxx
Trader Rating: 1
jsxx's Avatar
Wielka Brytania, Anglia, Derbyshire
Joined Jan 2011
Trader Rating: 1
Pm send
jsxx is offline Find More Posts by jsxx
Old Aug 06, 2012, 04:31 AM
iskess is offline
Find More Posts by iskess
Trader Rating: 4
FPV in Hawaii
iskess's Avatar
United States, HI, Kailua
Joined Feb 2012
Trader Rating: 4
I'll take it.
iskess is offline Find More Posts by iskess
Sold Eagle Eyes FPV Ground Station Hmerly FPV Equipment (FS/W) 3 Jul 07, 2012 08:27 AM
Discussion eagle eye station vs oracle diversity LTS49 FPV Talk 3 Jul 04, 2012 04:03 PM
Sold Eagle Eyes FPV Station Nick_P FPV Equipment (FS/W) 0 Jun 11, 2012 12:31 PM
For Sale Eagle Eyes FPV station and Eagle Eyes Antenna Tracker techcapsule FPV Equipment (FS/W) 8 Feb 27, 2012 01:36 PM
Sold Eagle tree osd gps complete fpv system and eagle eyes ground station never flown! djdaveq FPV Equipment (FS/W) 4 Aug 06, 2011 07:40 PM
