Espritmodel.com Heli Air
Old Aug 05, 2012, 07:39 AM
Australia, WA, Perth
Joined Jun 2011
Cleaning dust from motors?
Hi brains trust,
Just wondering what is the consensus on cleaning motors?
I have some Hyperion Zs2213-22 motors that are covered in fine dust. (if anyone knows the north west of western australia you'll know how fine I mean) it's an almost talcum powder like red dust. It's made it's way in to the motors and I suspect bearings too.
I was thinking rinsing in distilled water and then using compressed air to blast out the excess water before drying them
in the sun for a day or two?
Any thoughts on the subject would be most appreciated.
Cheers
Jesse Stack
jessestack is offline Find More Posts by jessestack
Old Aug 05, 2012, 09:00 AM
Merry Christmas... :)
KCV6's Avatar
Australia, SA, Edinburgh
Joined Aug 2009
I would just use compressed air and a soft cloth to wipe them over Jesse. The bearings should be ok.
Mark
KCV6 is offline Find More Posts by KCV6
Old Aug 05, 2012, 09:54 AM
Bitten by the RC Bug....
vineet_p's Avatar
India, Andhra Pradesh, Hyderabad
Joined Aug 2011
You're better off. I use bell-type motors that are exposed below. I am a bad pilot and whenever I make a midly hard landing, grains of sand go into the motor. The ferrous-containing sand particles stick between the motors and cause it not to rotate.
vineet_p is offline Find More Posts by vineet_p
Old Aug 05, 2012, 11:33 AM
Quad Smasher
DavidPDX's Avatar
United States, OR, Portland
Joined Feb 2012
Originally Posted by jessestack View Post
Hi brains trust,
Cheers
Jesse Stack
I ploughed my first quad into the ground filling three out of four motors with mud. I figured I had nothing to lose so rinsed the motors out with hot water, making sure to remove anything stuck magnetically. Afterwards I shook them dry and hosed them down with tri-flow oil, also shaking off any excess and then reassembled.
I am still using these motors months later and they are running great. Funny enough I think a couple of the motors actually benefited from the cleaning and oiling as they actually seem to run better then new.
DavidPDX is offline Find More Posts by DavidPDX
Old Aug 05, 2012, 12:25 PM
Hong Kong
Joined Sep 2004
Rising with water, blasting with air compressor, then dry with a hair dryer on full heat (not heat gun!) will do the trick. For your bearings, if they are gritty when you spin them, you may have to soak then in denatured alcohol in an ultrasonic cleaner to get them smooth again. Don't forget to apply bearing oil to the bearings.
.....this is fairly standard procedure for anyone running RC buggies. But sometimes WD40 works better, but there are 2 schools of thought around WD.
dtm360 is offline Find More Posts by dtm360
Old Aug 05, 2012, 09:01 PM
Joined Jun 2011
Thanks guys,
Yes the bearings are gritty so I might have to take the motors apart somewhat.
I also forgot to mention the the dust is red due to the iron so yes it sticks to everything metallic.
I'll try the wash and dry and see how I go
Discussion Cleaning varnish from outside of engine minklein Engines 9 Jul 15, 2012 07:44 AM
Question Is Falcon Dust off good for cleaning RC cars? jazza96 Car Talk 1 Jan 27, 2012 10:50 PM
Question Clean motor 430L from dust sreis Mini Helis 5 Jul 23, 2007 12:38 PM
