Old Nov 12, 2001, 09:13 AM
Steve McBride is offline
Find More Posts by Steve McBride
Steve McBride's Avatar
Agra, Oklahoma
Joined Feb 2000
Why you should not run an MP Jet planetary gearbox in reverse......
Decided to give a different motor a try in a pusher model and had a Hacker B20-12L on an MP Jet 3.8:1 planetary gearbox available.
I reversed the motor direction, slapped a 7x4 APC prop on it and checked everything out. Handlaunch and 2 complete circuits before the prop came fluttering down.
A deadstick landing and I find the housing had unscrewed itself due to the prop torque. It was secured but somehow came loose. In a normal rotation (for tractor use) this would not have made a difference. However as the reverse prop torque tends to 'unscrew' things, use as a pusher should only be attempted if you are sure things are tight and secure.
I lost all the planetary gears and assume I need to buy a complete new box.
Oh well - live and learn I suppose.
You have been warned
Steve McBride
Steve McBride is offline Find More Posts by Steve McBride
Old Nov 12, 2001, 06:07 PM
NipponDave is offline
Find More Posts by NipponDave
http://www.aircraft-world
NipponDave's Avatar
American in Japan
Joined Mar 2001
Hi Steve,
Just FYI, you don't need to throw away the gearbox. I'll have the pinions in stock when we open the shop next year. I'll be back in Japan early March, so send me an email and I'll get them out to you if needed. Shipping will only be about $2 - the set of gears and washers will probably be priced around $5.
Cheers,
David
Air Craft Japan
shop@aircraftjapan.com
httt://aircraftjapan.com
NipponDave is offline Find More Posts by NipponDave
An Apology.......(or why you should not bite off more than you can chew) Steve McBride Electric Plane Talk 16 Jan 24, 2003 10:42 PM
New MP Jet Planetary gearbox for speed400 3.33:1 Gerald Aircraft - Electric - Airplanes (FS/W) 3 Nov 11, 2002 12:45 PM
AF 010 with MP jet planetary gearbox ? dvint Power Systems 0 Nov 07, 2002 04:51 AM
Durability of MP Jet planetary gearbox ? dvint Power Systems 1 Apr 08, 2002 08:39 PM
FYI - Lesson Learned with MP Jet Planetary Gearbox Steve McBride Electric Plane Talk 1 Sep 19, 2001 06:41 PM
