Old Aug 04, 2012, 08:49 PM
hidaven is offline
Find More Posts by hidaven
United States, NJ, Roseland
Joined Apr 2009
ice 100 spools head faster than blades....wobbles
im on the lowest setting in the CC ice 100. Both the spool up speed and the initial power setting are both on the lowest settings and when my heli first starts the head spins faster than the blades . this throws the balance off untill the centrifigul force evens the blades out. only problem is it really wobbles until that happens and im afraid im going to tip over.......Any ideas or tips?
thanks!
hidaven is offline Find More Posts by hidaven
Old Aug 04, 2012, 09:46 PM
skizziks is offline
Find More Posts by skizziks
United States, NJ, Manville
Joined May 2006
Tighten your blades...
skizziks is offline Find More Posts by skizziks
Old Aug 04, 2012, 09:55 PM
finguz is offline
Find More Posts by finguz
finguz's Avatar
United States, CA, San Diego
Joined Mar 2012
maybe tighten the blades a little more, but leaving a little movement so they can straighten themselves out. I tighten mine down sometimes and worry that they might be too tight to straighten themselves out, but as long as they aren't too tight they seem to straighten out (even having said it, this means nothing on paper ).
what about spooling up slower with the throttle stick? what start speed is your esc set to? for helis you basically want verysoft or at least soft.
finguz is offline Find More Posts by finguz
Discussion Quadcopter, 1 motor runs a lot faster than other 3 golden77 Multirotor Talk 14 Jan 17, 2014 12:00 PM
Discussion Cheaper Faster Than MM Rustler XVL Wa7sh Electric Power Cars 3 Feb 28, 2012 05:07 PM
Video Gaui Hurricane Spool Up/Down Head Wobble L0stS0ul Electric Heli Talk 15 Feb 14, 2008 06:30 PM
Discussion tightening blade grips fixes spool down wobble. dubhouse Mini Helis 2 Nov 24, 2007 02:56 PM
Question Wicked Wobble In The Middle Of Spool-up and Spool-down wannabe Electric Heli Talk 4 Apr 16, 2004 01:37 AM
