Old Aug 04, 2012, 06:12 PM
Expat
Japan
Joined Apr 2010
Med/long distance objects fuzzy
Hello all
I finally got my tri up and running fpv today. Works well, but I'm having the problem mentioned above. Up close objects look fantastic, such as my hand. I assumed the lens focus, but extensive twisting produced no improvement.
The camera:
http://www.securitycamera2000.com/pr....8mm-lens.html
I'm useing LM 2.4 and an 8"LCD 800x600 native on PAL.
Thank you
TheNiceGuy is offline Find More Posts by TheNiceGuy
Old Aug 04, 2012, 07:48 PM
Canada, ON
Joined Jan 2009
Has to be the lens. Does it change length when twisting?
Martin Y is offline Find More Posts by Martin Y
Old Aug 04, 2012, 07:57 PM
Expat
Japan
Joined Apr 2010
Thanks Martin.
It changes length, I can get fore/back ground in/out of focus, but the med/long range always looks a bit weird. As if slight double images or something. Not sure what it is. It makes fpv object recognition difficult.
Old Aug 04, 2012, 09:56 PM
Canada, ON
Joined Jan 2009
You may have a lens element out of place. Do you have another to try?
Can you post a small video?
Old Aug 05, 2012, 12:44 PM
Expat
Japan
Joined Apr 2010
Hi Martin
I just have the one lens currently. I don't have a capture device, but I do have an EasyCap. I just took a video to show. In processing the quality degraded somehow. Not sure if the issue shows up. Outdoors long distance its more noticeable.
In this video I shoot my hand, which looks very crisp at the time. However, the "W" on the card up on the wall in the far room looks a bit blurry, not pixelated as if the resolution ran out, but unclear. I twist the lens twice in both directions to show intentional out of focus, and finish with the best position.
Again, on my LCD my hand looks very crisp and vivid, even very small features, while the "W" remains unclear and blurred no matter where I focus the lens.
Any ideas?
uvs120806 002 (1 min 22 sec)
Old Aug 05, 2012, 08:10 PM
USA Beautiful
LexusFPV's Avatar
Joined Feb 2011
I had the same issues.... you have to focus your lens outside....
with the Low lighting inside house, and looking at "fine" details of your hands close up, will result
in great images..... go outside and focus as best as you can.
As long as its not blurry and its to your satisfaction....go fly it.... :-)
LexusFPV is offline Find More Posts by LexusFPV
Old Aug 05, 2012, 09:13 PM
Expat
Japan
Joined Apr 2010
Thanks for the interest. I did focus it outside with the same results. It's not unflyable, but I was expecting better given the resolution. Houses at the end of the street all look like blobs and it's impossible to differentiate them. Whereas objects smaller on the screen and closer are more clearly defined.
Is this just standard for this hardware?
Old Aug 05, 2012, 11:05 PM
North vancouver, B.C. Canada
Joined Apr 2008
The camera is not of highest quality nor are the provided lenses
If you try a 3.6 or even a 6 mm lense you will get better quality video
Focus at an object far away and try to read the say license plate, then screw in the lense
Recheck for focus as little screw can unfocused when you tighten
If you are stuck on the 2.8 expect poor results with lense
One lense I got with this camera if fuzzy around one corner but still fly able
When you do you ground tests like in the video move actual camera to see if certain areas are or not ever clear as other areas will be
Set your focus so the furthest object away is clearest
Do tests and also use osd to calibrate camera for better video
You can also remove the outer part to,make this camera smaller
Keep it cool with some air flow
David22 is offline Find More Posts by David22
Old Aug 06, 2012, 02:32 AM
Expat
Japan
Joined Apr 2010
Thanks, that's good to know.
Is there a guide somewhere regarding important fpv features in the camera menu? some of the features I have no idea their purpose.
Rcmodelreviews mentioned DSR Iirc for evening shadows, so I turned that on. There's a feature that asks you to cover lens for a moment too, no idea what that is.
Old Aug 06, 2012, 06:38 AM
USA Beautiful
LexusFPV's Avatar
Joined Feb 2011
+1
David22
"""Set your focus so the furthest object away is clearest""""
Old Aug 08, 2012, 06:24 AM
Expat
Japan
Joined Apr 2010
Found out the problem, and you'll be surprised.
Turns out the Lawmate receivers are all bad, they output too low and cause a "shadow effect".
http://www.rcgroups.com/forums/showthread.php?t=1707027
I'm very surprised at this, as Lawmate came reccommended. I don't know what to do now.
Old Aug 08, 2012, 06:59 AM
Joined Apr 2008
I don't see the shadow effect in your video
But rather a slight last minute adjustment , from good focus, to slightly out of focus at end of video
Try to go out side and focus on distant license plate on car, but do it as far away as you can
Turn lense so you can read plate, let go of lense and make sure it still is readable
Tighten screw and then set with piece of tape
Recheck to make sure license plate is still readable from long range
Old Aug 08, 2012, 08:04 AM
Canada, ON
Joined Jan 2009
Another way to focus is take a flash light/bright led. Go about 200 feet(if you can) and do the focus to the smallest point of light you can get. Don't do it through a window, must be clear LOS.
Help! Heng long tank distance control problem Othor11 RC Tanks 16 Jan 20, 2013 05:05 PM
Discussion Methods of transporting Multicopters on a plane/long distance slidins15 Multirotor Talk 4 Aug 21, 2012 08:22 AM
Question Is Hitec Freedom 9s a good receiver for long distance? easystarfpv4 Electric Plane Talk 16 Jul 02, 2012 12:23 PM
Discussion Newbie Long Distance Flying Question HoosierGuy Sailplane Talk 7 May 09, 2012 06:39 PM
Discussion 1.2gHz Diversity antenna choices - low/med distance/alt Howemd Video Piloting (FPV/RPV) 20 Jan 25, 2012 03:27 PM
