Old Aug 04, 2012, 06:45 AM
Clintstone is offline
Find More Posts by Clintstone
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
Mini-HowTo
Checking the KV of your Motor Using the Castle Data Logger
This should really help get the correct prop and the correct gearing on your Heli...
I put this in quotes because I pulled this from another post I made... Thanks for reading....
" You can use the Castle data log to find the "Running KV" of the Motor ... In the native gov set the HS 3 to 4000 RPM ( this is to get the motor to run at 100% ) you can also run in fixed endpoint and make sure you are running 100% in the data log. In Set RPM Gov the IDEA is to get the motor to run Flat out... clear the Data Log...then run the Heli with blades off or pinion disengaged so you can get the motor to run at 100% un loaded... Then on the graph viewer you can download the data from the esc.... change the gearing to 1 to 1 and then in the graph scroll over and you get the vertical line that shows voltage and motor RPM at that time ( ame Mouse position ) ... divide motor RPM by Voltage and you will get the KV of the motor and you can use this in the Castle link setup instead of the rated KV as this is the information you are feeding the Castle Link for the advisement part of the program..."
Clintstone is offline Find More Posts by Clintstone
Old Aug 06, 2012, 08:28 PM
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
Try it... you may be surprised...
Old Aug 07, 2012, 05:45 PM
sandyem16 is offline
Find More Posts by sandyem16
sandyem16's Avatar
Enid, OK
Joined Jun 2006
yep.. my 440 kv motor calculates to 478 kv.. With my Logo 600se and lowest gear 11t on 12s, its still over geared.. No wonder..
sandyem16 is offline Find More Posts by sandyem16
Old Aug 07, 2012, 07:51 PM
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
This is a valuable setup tool...
Old Aug 11, 2012, 06:56 AM
miche is offline
Find More Posts by miche
miche's Avatar
Joined Oct 2008
Thanks..
miche is offline Find More Posts by miche
Old Aug 23, 2012, 08:54 AM
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
We checked motors at IRCHA and folks were surprised to see how far off some ratings were....
Old Sep 06, 2012, 11:39 AM
teamlotus is offline
Find More Posts by teamlotus
Joined Nov 2007
Is the 4000 rpm a "magic" number for all heli motors , ie do I use this set HS for all my motors with CC ESC's ?
teamlotus is offline Find More Posts by teamlotus
Old Sep 06, 2012, 02:21 PM
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
No magic number the idea is to get the GOV to run the motor flat out at 100%. you will see the motor out put at 100%...
It is possible for a smaller Heli to have a HS of 4000 or greater so you need to make sure that the HS you enter is high enough to run at 100% you can see this in the graph so it should be easy to sort out.
The example of 4000 that I used was on a Heli GOV at 2000 HS around 95% in Set RPM mode... So this model could not get to 4000 RPM so it was running flat out at 100% ....
Old Sep 06, 2012, 02:23 PM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
The number has to be high enough so that the motor is running at 100% full throttle. Its possible that a very small helicopter would need to have that number higher.
RC Man is offline Find More Posts by RC Man
Old Sep 09, 2012, 02:30 PM
rotomatt is offline
Find More Posts by rotomatt
United States, CT, Hartford
Joined Aug 2010
How about airplane set-ups
Will this work with just a full throttle run ( no prop) using a controller in airplane mode as well? auto or fixed end points?
rotomatt is offline Find More Posts by rotomatt
Old Sep 09, 2012, 04:08 PM
Alan Hahn is offline
Find More Posts by Alan Hahn
Chicago 'burbs
Joined May 2006
Just plot the Power Out parameter too. It should be 100% at WOT. If it is, then yes you can calculate Kv with the method.
Alan Hahn is offline Find More Posts by Alan Hahn
Old Jan 07, 2014, 03:34 PM
Marcos Sallua is offline
Find More Posts by Marcos Sallua
Joined Sep 2012
Good info! . I made the test with my new Align 730mx "850"kv , and a big surprice!!
Real kv -> 886kv
Good for governor setting!!
Can I use this parameter with safe in my SET RPM ?
Marcos Sallua is offline Find More Posts by Marcos Sallua
Old Jan 08, 2014, 04:40 AM
RC Man is offline
United States
Joined Feb 2001
Yes that’s the real number. The advertised number is just rounded off to look nice.
Old Jan 08, 2014, 04:56 PM
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
Real kv -> 886kv
That is what I recommend... this number can change some with timing but if you are testing with the setting you plan to run... then plug this number into the SET RPM KV Setting for the motor... This part is advisory to help get the best setup for your specific model and power system.
Old Jan 08, 2014, 08:20 PM
Joined Sep 2012
Thank you. the setup of the Governor SET RPM is correct in this moment
Now, Some time ago I found this video of Curtis Youngblood , he recommend change the lipo voltage to "Custom" and select 3.90 because the value is better average
What do you think about this ?
You can find this advice in 6:35 of the video
http://www.youtube.com/watch?feature...&v=SDeCpckM9w8
Question ICE Data Logger Questions FlyingW Castle Creations 12 Jul 23, 2016 09:17 AM
Sold [CLOSED] - Jive ESC Data Logger - jLog2 Making your ESC that much better!! Wynn1427 Aircraft - Electric - Power Systems (FS/W) 5 Apr 04, 2012 11:24 AM
Careful! Firmware 3.0 screwed the data logger on my ICE 50 3Dmuse Castle Creations 8 Jan 04, 2010 09:16 PM
Discussion ICE 100 Data Logger WessCo Castle Creations 13 Oct 01, 2009 05:45 PM
Discussion Phoenix ICE esc data logger village_idiot Xtreme Power Systems 4 Aug 05, 2009 09:05 AM
