Old Nov 16, 2012, 11:54 AM
maxmus is offline
Find More Posts by maxmus
Joined Aug 2012
Dang. U got close to the roof and the tree.
Have fun, I love fpving
maxmus is offline Find More Posts by maxmus
Old Nov 17, 2012, 11:18 AM
AcroFPV is offline
Find More Posts by AcroFPV
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
I actually clipped the tree just before I landed.
AcroFPV is offline Find More Posts by AcroFPV
Old Nov 17, 2012, 11:19 AM
AcroFPV is offline
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
Here are a few pix of my FPV gear mounted up.
This is whats going on the frame. I got a 800mah 3s battery for the vRX. I didn't want to run the vRX off a 4s, and was thinking a separate battery would reduce interference. The keychain cam is a V2 cam that has video output, while also recording 720p onto a micro-SD card.
Camera is sitting on a chunk of memory foam. Foam is taped to the RX using double sided duct tape. The zip tie holding the camera, is ran through the center of the foam block. I am pretty impressed with the results so far.
I mounted my vRX and battery on the tail. I am not sure if the tail motors will cause interference with the video signal, but it looks good there if you ask me
I'll have to get some pictures of my ground station setup next time I set it all up.
Old Nov 17, 2012, 05:03 PM
AcroFPV is offline
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
Ok so I had to do something about all the wires needed to run this operation. My ground station is a mess... but at least now its an organized mess
I burned off another 4s today trying the FPV. I got some more video to edit, and a whole lot more practice to do.
The spec's on everything involved:
Dell XPS17 L702X Laptop - Sandybridge i7 & nVidia GT 550M
ION video2pc RCA to USB video adapter
FoxTechFPV 5.8ghz RC305 video receiver
FoxTechFPV 5.8ghz 200mw video transmitter
Old Nov 17, 2012, 08:53 PM
AcroFPV is offline
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
Video from today. Give's you an idea of what I see on the laptop:
FPV is hard (2 min 48 sec)
Software used:
Windows 7 64bit
vDUB v1.9.11 in video capture mode
Camtasia Recorder 8 for screen capturing.
I plan on going out on monday to a real park, and stretching out a bit now that I feel comfortable with the tests.
Old Nov 18, 2012, 07:35 AM
Akcopter is offline
Find More Posts by Akcopter
Akcopter's Avatar
Joined Apr 2012
hey which one is that Video Tx is it the 200mw or 400 mw version.......???
Akcopter is offline Find More Posts by Akcopter
Old Nov 18, 2012, 10:22 AM
AcroFPV is offline
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
200mw
Old Nov 19, 2012, 11:20 AM
Akcopter is offline
Akcopter's Avatar
Joined Apr 2012
Man you have got to get this setup out in the open with less obstacles..I want you to test the range on these!!!!! and also ..try the CP antenna's they really boost the range as well as the performance of your FPV equipment...because as you can see there is always some static when there are throttle changes.....you need to stabilize the power you send to the FPV gear..also they interference due to shadowing and multipathing will be solved when you use CP...
Old Nov 19, 2012, 11:23 AM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
Since he has a FPV battery the interference from the throttle changes have to be coming from the ESC noise.
brontide is offline Find More Posts by brontide
Old Nov 19, 2012, 11:35 AM
AcroFPV is offline
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
Yup. My vTX is mounted almost directly over the two ESC's for the tail motors.
I dont have money for CP antenna's. But I am packing everything up right now as I type to go fly with Snipeworm at a real park. This should be interesting.
Stay tuned for either some real good footage, or some pictures of a mangled V-Tail copter.....
Old Nov 19, 2012, 11:40 AM
brontide is offline
Joined Sep 2012
Why is that an OR? :-)
Old Nov 19, 2012, 11:42 AM
Akcopter is offline
Akcopter's Avatar
Joined Apr 2012
you dont need to actually but new CP antenna's.... you can make them yourselves.... the quality will always differ from something you buy off the shelf but still it will be tons better than the dipole antenna....In fact I use CP antenna's even on my RC Tx and Rx for better glitch free rc link....
DIY: FPV backpack build part 2 (antennas) (35 min 41 sec)
Here you have one of the most detailed... step by step build log for a DIY Circular Polarised antenna..(especially for a 5.8 Ghz setup..enjoy..).
Old Nov 19, 2012, 12:41 PM
brontide is offline
Joined Sep 2012
You can also just shield your vTX signal from the camera to the Tx. canabalize some shielded cat6, USB, or firewire cable.
Old Nov 19, 2012, 05:10 PM
AcroFPV is offline
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
Cat6 is in the plans. I think im going to move all the FPV stuff to a different frame.
I took the setup to the park today. The wind was making it very difficult to fly. And FPV is still pretty difficult, as I do not have an idea of where I am, or any clue of altitude. Also I have some pretty insane vibrations right now, and my camera mount is near useless. The vibration was so bad all the video is useless as well.
Old Nov 26, 2012, 11:41 PM
AcroFPV is offline
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
Well guys. I am giving up on the V-Tail for now, and stripping everything off her to put on a new frame. You can keep up on the new build here: http://www.rcgroups.com/forums/showthread.php?t=1774676
But to end things, I thought I would share some pictures of the final disassemble.
Flew great just the other day...
Missing its brain and legs, ready for final teardown.
Everything laid out.
I am thinking of putting this V-Tail frame up for sale, but who knows... maybe I'll hold onto it incase I gather enough parts to have 2 flying quads.
Build Log First Tricopter build smoking91awd Multirotor Talk 4 May 03, 2013 07:01 PM
Discussion Tricopter first flight Theladon Scratchbuilt Multirotors 9 Aug 07, 2012 04:03 AM
Build Log My first adventure in flight... a Tricopter Build AcroFPV Multirotor Talk 6 Aug 02, 2012 11:08 PM
Help! I need tips for my first fpv on a tricopter jordanmeir FPV Talk 10 Jun 24, 2012 09:46 PM
Discussion Building my first tricopter! Questions faheja Multirotor Talk 1 Feb 23, 2012 09:51 PM
