Old Aug 03, 2012, 10:57 PM
OutcastZeroOne is online now
Find More Posts by OutcastZeroOne
"Fly, yes... Land, No"
OutcastZeroOne's Avatar
United States, CA, Santa Cruz
Joined May 2005
Build Log
YF-241 Shrike II
Have yet to fly it more then test glides for CG. We will see how well the tails hold up in a landing. I originaly wanted to have all servos tucked in the body but since i wasnt sure of CG till I built the thing it was hard to plan out. Though I am glad to see my rough estimate of where I thought the CG should have ended up was right. Right in front of the wing root to the body.
Plans added, its a one sheeter
EDIT: Updated info:
My newest design. 27" wingspan, 20" length, 6" tall.
Parts:
Servos:
2 HXT500 Servos
Power System:
Strong Motor 2900kv motor
(these motors have similar specs:
AX 1806N 2500kv Brushless Micro Motor (19g) (this is the closest to what I am running)
C10 Micro brushless outrunner 2900kv (this is the second closest)
C2222 Micro brushless Outrunner 2850kv (15g)
ESC:
TURNIGY Plush 12amp (2A BEC) BESC
Battery:
Rhino 460mAh 3S 11.1v 20C Lipoly Pack
Prop:
TGS Sport 6x4E Precision propeller
or
GWS EP Propeller (DD-5043 125x110mm)
around 200 grams flying weight. (with Kfm4 wing and some tape)
KFm2 or Kfm4 wing
Please go to:
http://www.rcgroups.com/forums/showthread.php?t=1767590
for plans of finalized versions of this plane and continued talk. This will now only be for prototype versions of this aircraft.
OutcastZeroOne is online now Find More Posts by OutcastZeroOne
Old Aug 04, 2012, 08:24 AM
soulreaper is offline
Find More Posts by soulreaper
Joined Nov 2005
Your plane looks good. suscribed.. Can you please post a picture of the bottom of your plane.
soulreaper is offline Find More Posts by soulreaper
Old Aug 04, 2012, 10:32 AM
bobdaeronort is offline
Find More Posts by bobdaeronort
"Five Easy Pieces"
United States, IN, Terre Haute
Joined Sep 2011
Cool.
bobdaeronort is offline Find More Posts by bobdaeronort
Old Aug 04, 2012, 11:16 AM
foamdave is online now
Find More Posts by foamdave
skumgummi dave
Gresham, OR.
Joined Mar 2004
OZO:
Looking goood!
Dave-
foamdave is online now Find More Posts by foamdave
Old Aug 04, 2012, 02:19 PM
Joined May 2005
i will, batteries died on the camera
Old Aug 06, 2012, 10:06 AM
Joined May 2005
more pictures of the plane, as requested.
Old Aug 06, 2012, 05:04 PM
Joined May 2005
Just got back from the park. YF-241 flew well. Hand lanching from the fuselage under the body was super easy. Was responsive to the controls and made a nice turning loop. Only once did I have a pitch up issue with power, but it was also as it got near tree top level. Once it got up there it flipped around and flat spun into the ground, nose dropping till it hit nose first. Took the hit very well. Nose was fine along with the rest of the body. Even the tails are undamaged. The only thing to happen was the little piece in front of the canopy that holds it down came off. Without that, the canopy cant stay on, so that ended the first flight. Good minute if flying
Since I just walked across the street to the park I didnt bring anything with me to repair anything. Also going to be leaving in a few minutes to go see Batman.
I still think there is turbulant air around the top of the trees near my house. Had almost the same problem, in the same area as I did with the larger YF-239 Fox Sparrow I made. Got just about tree top level and things go a bit crazy with a sudden gust of wind.
Old Aug 06, 2012, 07:31 PM
Dickeroo is offline
Find More Posts by Dickeroo
Dickeroo's Avatar
Joined Dec 2006
Great looking plane.
You asked for names... So here are a few... To get the ball rolling.
The Enigma
The Paradymn
The Shrike
The Annihilator
You've done a beautiful job with this build.
~ Dick. The K In KF
Dickeroo is offline Find More Posts by Dickeroo
Old Aug 06, 2012, 09:32 PM
Joined May 2005
Enigma, Paradymn and Annihilator sound too comic bookish to me Shirke, I'm not Indian I can only guess you ment Shrike, as in the small bird. That one Im kind of likeing.
I am still very surprised that the tails held up as well as they did. Keep in mind the only tape on the plane are on the hing points of the flaperons
Old Aug 06, 2012, 09:40 PM
Joined Nov 2005
Thanks Outcast for the picture of the bottom of the airplane. I cant wait for a video and maybe plans? I kinda think the name Enigma is just right for the plane. Im itching to build one your planes, and I might try and make into an FPV airplane. Please post a video if you have time. Thanks again for sharing your plane
Old Aug 06, 2012, 09:52 PM
Joined May 2005
no video Ill see what I can do as far as plans go. The old computer with illustrator is having issues.
Found a good sideveiw of a Loggerhead Shrike, and the shape of the birds head is a good match for this plane I htink, so it works. Plus I seem to have a habbit of naming my jet designs after birds... Not sure why.
Old Aug 07, 2012, 08:54 AM
Dickeroo is offline
Dickeroo's Avatar
Joined Dec 2006
Yes, I got careless and misspelled the bird's name. I'm glad you liked my suggestion, however. Love the look of this plane.
Old Aug 12, 2012, 04:57 PM
Joined May 2005
Soulreaper: Im having issue with my computer that has Illustrator on it so plans are still being a problem to make. If you want to try one of my planes as a FPV, try my Wind FIghter. Funbat based Kfm4 pusher. Very easy to fly and stable. And plans aswell
Will keep trying to get my G3 up and running to make plans of the Shrike. I have a CAD program on my G5, but it dosnt do PDF, and cant wrap my head around sketchup still. Ive done 3d modeling since the mid 90's but for some reason I just cant get sketchup to work for me. I think I have too many other systems running in my head as it is
Old Aug 12, 2012, 08:14 PM
Joined May 2005
Was able to make plans on my cad program and "print" it as a PDF Still cant do tilled files. I did 2 versions. B model has a new canard design. It ALMOST fits on a single sheet of Readi-Board.
Old Aug 12, 2012, 09:08 PM
Joined Nov 2005
Awesome, and thank you very much for trying. In the mean time, Im going to check out your other plane (Wing Fighter).
Build Log No name yet Thermaleer Thermal 37 Jul 02, 2009 09:47 PM
Contest Let's play "Name That Plane!" -No winners yet! will_newton Sailplane Talk 33 May 31, 2006 01:07 PM
Yippee! Prototype 250 no name yet grumman5277 Foamies (Kits) 0 Feb 08, 2005 10:13 PM
first scratch built!! no name, no graphics yet punkin Foamies (Kits) 12 Oct 15, 2002 07:11 PM
