Old Nov 19, 2003, 01:03 AM
MX is offline
MX
Find More Posts by MX
MX
Embedded Systems Engineer
MX's Avatar
Grass Valley, CA
Joined Sep 2001
AP Plane Design #2 - Comments?
After flying my first AP plane design for a while, I've designed to
improve on the design based on what I've learned. My goals
are to:
- Reduce weight further.
- Improve wind penetration.
- Add ailerons for roll control and flaps.
- Make the wings and tail detachable for transport.
- Make it look better to civilians interested in my AP.
To accomplish this, I'm going for balsa built-up wings and tail,
carbon fiber boom fuselage, solite covering, and ailerons. I also
have a plastic trunk from K-Mart that it's designed to fit in so I
can transport it while avoiding hanger rash.
Here's my drawings thus far:
Here's some shots of progress:
- Stack of ribs after sanding the profile and cutting stringer slots:
Airfoil is Selig 3021:
Wing partially assembled:
Tail Pieces:
(cont)
MX is offline Find More Posts by MX
Old Nov 19, 2003, 01:04 AM
MX is offline
MX
MX
MX's Avatar
Grass Valley, CA
Joined Sep 2001
Brass Tubes that slide inside each other will hold wings together:
Tubes will slide through the keel (plywood/balsa sandwich).
Camera will mount below wing on keel:
Wings will come apart for transport:
Entire wing:
Nice and straight:
But it flexes too much:
The wing seems to have a lot of flex in torsion. If I grab one end,
I can twist it about 45 each way pretty easily. Any suggestions
to stiffen it up?? I added some balsa between ribs but it didn't
help a whole lot:
Will the covering help this?
Thanks for looking. Sorry for the lengthy post.
MX
Old Nov 19, 2003, 02:23 AM
Trikster is offline
Find More Posts by Trikster
Zoom, zoom...
Trikster's Avatar
Roseville, CA (Sacramento area)
Joined May 2003
I bet the covering will help some. I wish I could handle balsa, it seems to be such a nice thing to build with (I am unfortunately allergic to it). That looks like a great start to a nice AP rig. How do you plan on keeping the wings together?
Trikster is offline Find More Posts by Trikster
Old Nov 19, 2003, 02:49 AM
Fredrik W is offline
Find More Posts by Fredrik W
Fredrik W's Avatar
Stockholm, Sweden
Joined Jul 2002
Originally posted by MX
Any suggestions to stiffen it up??
You should add a D-box. That means that you cover the area from the trailing edge to the main spar with a sheet of balsa or thin plywood, both on lower and on top side of the wing. (A cross section of the wing will then look like a long D. ) That will stiffen up the wing a lot - and make it more crash resistant.
The covering will also add strenght and stability to the wing.
Your ribs looks very thin. That could be a problem, you will find out when you shrink the covering. I made a built up wing a month ago, when I shrunk the covering the ribs flexed and looked like S-urves. I had to remove the covering, stiff up every rib before I could cover the wing again.
I too is building a new AP-plane as we speek.
// Fredrik Wergeland
Sweden
www.flyingmodels.org
The Great Electric Motor Test
Fredrik W is offline Find More Posts by Fredrik W
Old Nov 19, 2003, 07:58 AM
CenTexFlyer is offline
Find More Posts by CenTexFlyer
Near Austin
Joined Dec 2001
Also glue shear webs in between your top and bottom spar.
CTF
CenTexFlyer is offline Find More Posts by CenTexFlyer
Old Nov 19, 2003, 08:49 AM
AUBrian is offline
Find More Posts by AUBrian
Zen Flying Master
AUBrian's Avatar
Sweetwater, TN
Joined Sep 2002
Um....tex...in that last picture, he has shear webs ;o) I'd say since you're going for lightness, go ahead with what you've got and cover it. It always amazes me how much torsional rigidity that adds, and having just a touch of flexibility may help it bend in a crash instead of breaking.....
AUBrian is offline Find More Posts by AUBrian
Old Nov 19, 2003, 08:58 AM
KLH is offline
KLH
Find More Posts by KLH
KLH
Pack Rat
KLH's Avatar
Hayward CA / Valley Springs CA USA
Joined Jan 2001
As per Fredrik and CTF, If you do both the sheeting from the leading edge (top and bottom) to the main spar and the shear web (vertical grain) between the top and bottom spar to form a "D" tube or box section you will stiffen the wing up.
I've built up a lot of balsa wings of my own design over the years and the "D" section as described above is one of the easy ways of gaining torsional strength. The sheeting does not have to be very thick. On my smaller planes I use 1/32" contest grade and on my larger planes I use 1/16". There are several examples of this type of construction on my homepage if at www.kern.hanson1.com
I'm just about to try out a new AP plane thats very similar in design, but I got lazy and am using and old Wingo wing that I took most of the dihedral out of and add ailerons.
Good luck with it! Your workmanship appears to be outstanding!
Kern
KLH is offline Find More Posts by KLH
Old Nov 19, 2003, 10:06 AM
MX is offline
MX
MX
MX's Avatar
Grass Valley, CA
Joined Sep 2001
Thanks. The wings will first slide together using the brass tubes,
then I will have a hard block glued to inside of each first rib,
and blocks glued to the center keel. There will be a vertical hole
through each. So I would slide the wings in from the sides, then
put nylon wing holddown bolts in from top to bottom. This will
lock them in. By the way, the center two ribs on each wing are
1/8" ply.
MX
Old Nov 19, 2003, 10:09 AM
MX is offline
MX
MX
MX's Avatar
Grass Valley, CA
Joined Sep 2001
The ribs are 1/8" balsa. They seem to have enough stiffness
front to back.
MX
Old Nov 19, 2003, 10:12 AM
MX is offline
MX
MX
MX's Avatar
Grass Valley, CA
Joined Sep 2001
I was concerned about there being too much flexibility in the wing
to the point that it would flex in flight, causing too much wash
out or wash in. Perhaps even causing problems like tip stalling
in wind and such.
MX
Old Nov 19, 2003, 10:17 AM
MX is offline
MX
MX
MX's Avatar
Grass Valley, CA
Joined Sep 2001
I may try doing the D box by sheeting from leading edge to
trailing spar with 1/32" balsa, then do covering.
Thanks for the suggestions.
Another questions: do my ailerons look too small? They are
24" x 0.75".
MX
Old Nov 19, 2003, 10:27 AM
jgleigh is offline
Find More Posts by jgleigh
jgleigh's Avatar
Manassas, Virginia, United States
Joined May 2002
If you are worried about torsional stiffness, I'd suggest you use monokote for the covering. It seems to add more stiffness than some of the other products, and DJ Aerotech specify it for their built-up balsa sailplanes. The transparent colors are reasonably light, especially the yellow.
jgleigh is offline Find More Posts by jgleigh
Old Nov 19, 2003, 10:55 AM
MX is offline
MX
MX
MX's Avatar
Grass Valley, CA
Joined Sep 2001
I wonder which would way more: sheet about 50% with 1/32"
balsa and cover in solite or cover all with monokote?
MX
Old Nov 19, 2003, 11:59 AM
jgleigh is offline
jgleigh's Avatar
Joined May 2002
Well, if you add 2 inches of 1/32 sheet to the top and bottom of the wing, that's 2*2*52/32 = 6.5 cubic inches of balsa. Fairly light balsa weighs in at say 10 lb/cuft, or a little less than 0.1 oz/cuin. So that would add about 0.6 ozs. I don't know the weight difference between solite and transparent monokote, but we're looking at 8*2*52 = 832 sqin = 5.8 sqft of wing area. Anyone?
Old Nov 19, 2003, 12:08 PM
MX is offline
MX
MX
MX's Avatar
Grass Valley, CA
Joined Sep 2001
I can't use transparent monokote. A couple other guys have
mentioned problems with the camera image being colored due
to sunlight going through the transparent wing. Unless I use
clear. I do have a bunch of doculam that came with my
MiniFlash. It's clear.
I think I'm going to cover one wing with solite and see if only
the covering will be enough to eliminate most torsion. I can
peel it back off if I need to. I'm really trying to cut down on
weight with this one.
MX
Discussion New AP Plane Design and Inexpensive Digital Camera Comparison chrisgood Aerial Photography 11 Jun 02, 2006 02:43 PM
My new AP plane design that works (My 1st AP flight!) mrbisset Aerial Photography 6 Sep 10, 2005 10:18 AM
What would your ideal electric AP plane design look like? Canada Goose Aerial Photography 21 Jan 14, 2005 04:11 PM
AP plane design rikhye Aerial Photography 0 Sep 30, 2004 03:04 AM
Here's The New AP Plane I'm Building...Would like Some Opinions On Wing Design Randy Due Aerial Photography 68 Feb 23, 2004 02:38 PM
