Old Aug 03, 2012, 05:22 PM
robe_uk is offline
Find More Posts by robe_uk
Metallica
robe_uk's Avatar
Londonderry UK
Joined Nov 2004
Options for 4 axis foam cutter software
Hi All
Am interested to hear your options on software for controlling a 4 axis hot wire cnc foam cutter, I am currently mid build and now starting to think about software.
I intend to cut wings and any shape i fancy. I currently use Autocad with cambam or vcarve pro depending on project with mach3 controlling my cnc router.
So lets hear your views on functionality/cost/pros and cons of the software you use.
First question you'll ask is 'whats your budget', well I dont know really, about $80??
Rob
robe_uk is offline Find More Posts by robe_uk
Old Aug 04, 2012, 04:59 AM
jregholdsworth is online now
Find More Posts by jregholdsworth
Joined Jul 2006
What foam cutter software
well...since you already have mach3 pick up a 4 axis screen set from here :
http://odysseywood.us/profili/CNC%20Foam.zip
and get Profili from here:
http://www.profili2.com
While it doesn't have hot wire control, and GMFC does.
However Profili works well enough for me.
If you use GMFC you have to have a 4khz or 10 khz square wave input..slightly awkward..but no need for Mach3.
there is an associated stepper heat control board (MM2001) but I've never found one for sale it always seems to be necessary to make one...
As an alternative I built and arduino mega based one which mimics the MM2001 board, but uses a chinese stepper driver board for the machine.. I'd be glad to share this if that would help.
The hot wire driver is based on the ufoman post in DIYDrones:
http://diydrones.com/profiles/blog/s...age=1#comments
.... significantly expanded to provide GMFC compatibility (and Tjzoide) and a LCD display to show the heat setting.
Hope this gives you some ideas..
regards JH
jregholdsworth is online now Find More Posts by jregholdsworth
Old Aug 06, 2012, 03:00 AM
Prop-er is offline
Find More Posts by Prop-er
Launchpad McQuack
Prop-er's Avatar
Netherlands, Moordrecht
Joined Sep 2004
This one is free, and from what I hear is worth a try, if you don't mind the German language:
http://www.rc-network.de/forum/showt...t-SchnApps-%29
http://scehandball.de/SCHNAPPS/publish.htm
Prop-er is offline Find More Posts by Prop-er
Old Aug 18, 2012, 02:14 PM
heliwill10 is offline
Find More Posts by heliwill10
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
Also, free.
http://www.stealthplaneworks.com/FoamCutter.aspx
Really easy to use...
heliwill10 is offline Find More Posts by heliwill10
Old Aug 21, 2012, 10:31 AM
robe_uk is offline
Metallica
robe_uk's Avatar
Londonderry UK
Joined Nov 2004
Thanks for the suggestions, I have been playing with foamworks 4. and i like the dxf import function, i'll take some time to play with the ones suggested.
Cheers Rob
Old Aug 28, 2012, 04:33 PM
dpot is offline
Find More Posts by dpot
dpot's Avatar
France, Auvergne, Lapalisse
Joined Dec 2005
foam cuter
try devcadcam devfuzcam devfuzfoam profil pro2
my foam cuter2 (2 min 23 sec)
dpot is offline Find More Posts by dpot
Old Aug 28, 2012, 05:16 PM
robe_uk is offline
Metallica
robe_uk's Avatar
Londonderry UK
Joined Nov 2004
Originally Posted by dpot View Post
try devcadcam devfuzcam devfuzfoam profil pro2]
Good looking programs and nice videos you have online. I'll have to try a simple project sometime to use these programs, at the minute the foam cutter has been put to the side to try and wrap up a couple of other project which are dragging on
My foam cutter has been on the cards for at least 6 years and only took me a couple of weeks to build once i finally got around to it, sometimes the machine build is more fun than what its final use will be, am even thinking of a reprap printer head build for my router for 3d printing, not that it'll be much use for me but more just to see if it'll work
Rob
Old Sep 01, 2012, 02:09 AM
dpot is offline
dpot's Avatar
Joined Dec 2005
foam
yes there is always lots to do when you're a modeller we have just move to a new house propjet and have to build and setup a new work shop good luck with your build
For Sale Hobby CNC 4 axis foam cutter FLYBOB54 Aircraft - General - Miscellaneous (FS/W) 7 May 21, 2012 09:04 AM
Build Log Arduino Mega/Big Easy driver 4 axis foam cutter sscherin DIY Electronics 5 Apr 16, 2012 08:16 PM
Help! Cnc foam cutter 4 axis plans srkipa Foamies (Scratchbuilt) 1 Apr 04, 2012 03:41 PM
For Sale MM2001 CNC foam cutter 4 axis Interface for GMF bgriggs Aircraft - General - Miscellaneous (FS/W) 0 Apr 15, 2006 12:59 PM
Looking for a CNC 4 AXIS FOAM CUTTER A.D. Power Systems 3 Nov 13, 2001 02:44 PM
