Old Aug 03, 2012, 04:36 PM
Dr.M is offline
Find More Posts by Dr.M
Dr.M's Avatar
United States, WA, Issaquah
Joined May 2011
Careful!
WARNING to all users of Solar Servo D654
The motor inside these servos is not supported by the backplate. Under the vibrational environment characteristic of a heli, it can slide down into the case and lose grip on the servo gears allowing the output shaft to rotate freely.
How I found out: following a crash of my 450, I did a few bench tests to figure out what happened. With some shaking and proding the servos while running the motor at full RPM (blades off ) I noticed inconsistent behavior from the elevator servo. What happened was that the motor inside the elevator servo case slid a few mm lower (away from the output shaft) allowing its small pinion to only make partial and intermittent contact with the first gear of the servo transmission. Under high load, the pinion would loose grip on the gear and allow the servo output shaft to rotate freely, though in static tests the servo would act and feel normal.
Solution: Open up the servo casing and add enough foam to push the motor body against the backplate. Not too much, as the servo case won't close properly, but enough to create some pressure in there.
Edit:
Another issue related to gears disengaging has been reported. It was caused by the pinion on the motor shaft being installed too low for a positive contact with the first gear. See this post here: http://www.rcgroups.com/forums/showp...postcount=5482
Edit:
Maiden flight report for Solar D770 added:
http://www.rcgroups.com/forums/showp...4&postcount=61
Dr.M is offline Find More Posts by Dr.M
Old Aug 04, 2012, 12:50 AM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
Could shoe goop work too?
ridge_racer is offline Find More Posts by ridge_racer
Old Aug 04, 2012, 01:34 AM
Dr.M is offline
Dr.M's Avatar
Joined May 2011
Yeah, but it would be hard to remove if you ever wanted to and would add significantly more weight. I like to keep my helis as light as possible.
Old Aug 07, 2012, 02:02 AM
mixfisto is offline
Find More Posts by mixfisto
mixfisto
Joined Feb 2012
Dr M,
I'm planning on getting 3 of these for my Blade 300x. Does Solar also make a decent tail servo?
mixfisto is offline Find More Posts by mixfisto
Old Aug 07, 2012, 11:17 AM
Dr.M is offline
Dr.M's Avatar
Joined May 2011
Originally Posted by mixfisto View Post
Dr M,
Solar doesn't have any servo with specs good enough for tail duty. Many people like the Fitec 9357 (ebay) though it may be a bit too big for a Blade 300.
Old Aug 08, 2012, 03:19 PM
mixfisto is offline
mixfisto
Joined Feb 2012
Thanks.
That Fitech looks pretty good. Just wish it had metal gears.
It seems the stock tail servo has a bit of extra room, probably allowing a bigger-than-stock servo to fit.
Old Aug 09, 2012, 09:07 AM
Beachcomber is offline
Find More Posts by Beachcomber
Savannah, Ga, USA
Joined Feb 2009
I can confirm what OP says. Just received qty 6 of the Solar D654, and right out of the box, 2 of the 6 the servo motor is running but gears not turning. Opened up the case and pushed the motor up into case aprox 1 mm and servo/gears started working.
There is a piece of foam under the rear cover, but was over the circuit board rather than the end of motor. I have relocated foam to hopefully be pushing on the motor with end cover replaced. Fingers crossed.
I was hoping these Solar would be more reliable than the EXI servos I used in the past. Had a batch of those with the jitters at mid-stick so quit using EXI. Still looking for a reliable under-$10 servo.
Beachcomber is offline Find More Posts by Beachcomber
Old Aug 13, 2012, 10:49 PM
bcamphaus is offline
Find More Posts by bcamphaus
bcamphaus's Avatar
United States, MA, Amherst
Joined Sep 2011
I just want to add that I also had this happen on two out of four servos. One of them is actually completely shot even after pushing the motor up. It spins all the way right or left without stopping until reaching the end or back to center. I also had the rx on with the rudder and elevator connected and there were a couple times in five minutes when the rudder spazzed out for a second (as if I had bumped the tx). I don't think I want to fly with these servos at all, I just don't trust them This was going to be used on a 3dhs 41 edge...
bcamphaus is offline Find More Posts by bcamphaus
Old Aug 13, 2012, 11:06 PM
radman615 is offline
Find More Posts by radman615
radman615's Avatar
San Diego,CA
Joined Sep 2008
China Crap for sure!
radman615 is offline Find More Posts by radman615
Old Aug 14, 2012, 02:21 AM
Dr.M is offline
Dr.M's Avatar
Joined May 2011
I'm guessing your motor slipped just enough to strip the pinion and/or the first gear. Anyways, they seem to be hit or miss...
I got a D770 to test as a potential HV option.
Old Aug 14, 2012, 09:49 PM
mligosh is offline
Find More Posts by mligosh
mligosh's Avatar
New Smyrna Beach, FL
Joined Jun 2005
I'm very interested to see what you find. I was asking around about the D771 for my 550 FBL, but nobody seems to want to be the guinea pig. I was hoping to hear some field reports. $22 for a fast, strong, HV servo, but if it's not reliable, it's not worth $2. Especially when going into 550-700 class helis.
mligosh is offline Find More Posts by mligosh
Old Aug 14, 2012, 09:55 PM
bcamphaus's Avatar
Joined Sep 2011
So, an update to my solar servo issues... The one I referred to that was turning until it hit the end point, or the center, and nothing in between had a loose wire on the feedback pot. I re-soldered that and then it was properly responding to the tx. The other problem with the slipping gear was actually the result of the motor gear being pressed on too low. When the servo was mounted in the aileron (upside down), the second gear would slide up just enough to miss the motor gear. It was not from the motor sliding down as I originally thought. I pressed the gear up the shaft and now everything works perfectly. Not sure what caused the flutter I referred to earlier, it has not happened again so I'm gaining more confidence in them. I will be taking every last one of them apart to inspect them though...
Old Aug 14, 2012, 11:52 PM
Dr.M is offline
Dr.M's Avatar
Joined May 2011
The D770 is gonna be opened up and inspected, sent thru some pretty tough bench tests, then, if all goes well, it will be installed on my Pantera 6 tail (600mm main blades).
Old Aug 16, 2012, 04:06 AM
soneebee is offline
Find More Posts by soneebee
Joined May 2006
why is this solar servos attractive? are they selling them cheap? or too cheap? its kinda hard to rely on cheap servos that once it fails will cost more $$$$ on crash parts
soneebee is offline Find More Posts by soneebee
Old Aug 16, 2012, 10:52 AM
prop bender is offline
Find More Posts by prop bender
USA, CA, Red Bluff
Joined Dec 2007
I was wondering the same thing soneebee,It seems to me better servos (and true allso more expencive) would save on heli repairs. Being able to fly with peace of mind has to be worth something.
prop bender is offline Find More Posts by prop bender
Found Solar servos d650 or d653 or d654 Dr.M Aircraft - Electric - Helis (FS/W) 0 Mar 17, 2012 09:16 PM
Discussion anyone use the Solar Servo D654 3Daddict HobbyPartz.com 0 Mar 10, 2012 07:34 PM
Alert Pha-01 Warning For All Pha Users: Support Me! lostrider GWS (Grand Wing Servo) 105 Jun 17, 2005 03:17 PM
Alert Pha-01 Warning For All Users : Why My Thread Is Closed??? lostrider Micro Helis 5 Jun 10, 2005 02:04 PM
Alert Pha-01 Warning For All Pha Users lostrider Micro Helis 13 Jun 08, 2005 10:32 PM
