Old Nov 18, 2003, 10:46 PM
jrobgray is offline
Find More Posts by jrobgray
Joined Oct 2003
Corona Battery power low? I know nothing about batteries!!
Okay, so I finally rebuilt my Corona using carbon fiber everything, AND I got it set up, and when it came time to fly, my batteries just didn't have the juice.
I don't know anything about batteries. I have a cheap charger, and I don't know how long, or even how to charge them. They are 7 cell nicad's. One is 2400, one is 2600 mah. DO I need to run them all the way down?
When I trickle charge them for a long time, they are still low.
Can someone recommend some reading, or instruction on what to do?
Thanks a lot!!! I really want to get flying!
Jeff
jrobgray is offline Find More Posts by jrobgray
Old Nov 19, 2003, 02:05 AM
FrankW is offline
Find More Posts by FrankW
Danger! Danger!
FrankW's Avatar
Portland Intl, Oregon, United States
Joined Dec 2002
My advice would be to get a nice peak charger, something like an MRC Superbrain 959. It will charge your batteries quickly (30 minutes or so) and will peak charge them. It will charge to their full capacity (peak) and stop charging. The Superbrain will charge up to 8 cells at up to 4.5 amps, all for only $50. Usually, if you trickle charge your batts, they seem to not put out as much power as if you regularly charge them at a higher rate (2C-3C).
"C" refers to the rated capacity of the cells, so if you charge 2400Mah cells at 2C, then you charge them at two times their rated capacity. 2 x 2.4 Ah or 4.8 amps. The 4.5 amp rate of the Superbrain is good.
-Frank
FrankW is offline Find More Posts by FrankW
Discussion Does anybody know details about PICOZ (or similar toys) battery ? mattijs321 Micro Helis 5 May 08, 2007 08:42 AM
Question What About a Battery Power Switch? modelmaster2001 Glow to Electric Conversions 35 Feb 22, 2007 04:58 PM
Question dont know jack about battery/charger poochy Batteries and Chargers 3 Jan 24, 2007 11:12 AM
You guys have to help me out I know nothing about getting a plane Sgwyldechild12 Beginner Training Area (Aircraft-Electric) 17 Sep 01, 2004 11:29 AM
About 12v Battery to power up the charger GTOVR4 Electric Heli Talk 5 May 28, 2004 12:27 AM
