Old Aug 03, 2012, 08:52 AM
KillerCut is offline
Find More Posts by KillerCut
USA, NY, Brooklyn
Joined Jan 2002
I love using pan, but how to use tilt on radio?
Ok, I finally figured out a quick and easy pan setup (picture) its just a pz0420 with 2 square pieces of dollar tree foam board covered with uline packing tape (the camera doesn't get warm at all)... (tiny cutouts for osd and power/video plugs) and I hot glued it to a servo 4 way arm thingy. very solid. I use the rudder on my radio to control it.
Now that I got a taste of whats possible with moving the camera around I also want tilt, how do you guys control it on your radio? I have a futaba 9cap and can probably use the side thingys, but its not easy to center them (use expo?)
Or maybe I should just use throttle on those side thingys and use the throttle stick for camera only???
KillerCut is offline Find More Posts by KillerCut
Old Aug 03, 2012, 09:09 AM
LKJ is offline
LKJ
Find More Posts by LKJ
LKJ
Lars k Jensen
Denmark, Central Denmark Region, Tostrup
Joined Apr 2006
I use this one.
http://www.rcgroups.com/forums/showthread.php?t=1651310
When trainer svitch is off i use 2 turning knops on my F9.
Lars.
LKJ is offline Find More Posts by LKJ
Old Aug 03, 2012, 04:02 PM
whakahere is offline
Find More Posts by whakahere
Kiwi in Germany
whakahere's Avatar
Germany
Joined Jun 2010
I use this but add another button to have pan or tilt on ... or both down to have both.
http://www.rcflighttest.com/home/201...he-left-stick/
whakahere is offline Find More Posts by whakahere
Old Aug 04, 2012, 08:05 AM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
Precise control of servo is best
Not a 3 way switch but to be able to move digital sevo slowly or fast at will
QUOTE=KillerCut;22344523]Ok, I finally figured out a quick and easy pan setup (picture) its just a pz0420 with 2 square pieces of dollar tree foam board covered with uline packing tape (the camera doesn't get warm at all)... (tiny cutouts for osd and power/video plugs) and I hot glued it to a servo 4 way arm thingy. very solid. I use the rudder on my radio to control it.
Or maybe I should just use throttle on those side thingys and use the throttle stick for camera only???[/QUOTE]
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Mini-HowTo Sticky pan-tilt using ER9x firmware mkuvy FPV Talk 30 Jun 03, 2014 06:46 AM
Mini-HowTo How I did my 360 deg Gopro Pan/tilt Bluestreak007 FPV Talk 0 Jun 25, 2012 01:52 AM
Question How to do a pan & tilt button on jr dsx7? superek4 Radios 6 Aug 26, 2011 07:49 AM
Question How to get pan/tilt and throttle mixed in a Futaba 7C on one gimbal kyle7119 FPV Talk 26 Apr 20, 2010 07:41 AM
Discussion Thoughts on using 1 MPX connector for Pan/Tilt/Video nathanj988 FPV Talk 3 May 12, 2008 11:09 PM
