Old Oct 03, 2012, 03:54 PM
msev is offline
Find More Posts by msev
Joined Sep 2010
Originally Posted by charlienofun View Post
Ian, Thanks again! I was just taking a break from work and looking at the code again that was exactly what I wanted to confirm
Did you see the Arduino DUE is going to be out by the end of the month? its got a way to do USB host on the M3 chip they are using! Good stuff!!
Can you post the link to that reference?
msev is offline Find More Posts by msev
Old Oct 03, 2012, 04:21 PM
IanJ is offline
Find More Posts by IanJ
Aberdeen, Scotland, UK
Joined Dec 2007
Yep, the DUE is a 32-bit device......and I believe it uses a 32bit Cortex-M3 ARM processor, a SAM3U processor from ATMEL running at 96MHz with 256Kb of Flash, 50Kb of Sram, 5 SPI buses, 2 I2C interfaces, 5 UARTS, 16 Analog Inputs at 12Bit resolution and more.
I'll probably get one of those to update my home made Segway.
Ian.
IanJ is offline Find More Posts by IanJ
Old Oct 03, 2012, 04:25 PM
charlienofun is offline
Find More Posts by charlienofun
charlienofun's Avatar
United States, CA, Santa Clara
Joined Mar 2008
Check the video in this post on DIYDrones, Massimo mentions it will have two usb ports one will be like it is today (uploading code) and the second is for USB on the go which includes USB Host.
http://diydrones.com/profiles/blogs/...-arm-based-due
charlienofun is offline Find More Posts by charlienofun
Old Oct 04, 2012, 01:34 AM
dathird313 is offline
Find More Posts by dathird313
dathird313's Avatar
Joined Jul 2006
What is being run on IS3 that requires interrupts to be used?
dathird313 is offline Find More Posts by dathird313
Old Oct 04, 2012, 06:46 AM
IanJ is offline
Joined Dec 2007
Are you asking why Timer 3 is being used?...............Quite simply to provide timing for various calls to various subs.............and I suppose could easily be reproduced with some code without using a timer if one really wanted to run on other Arduino's...............however, last time I looked I was using more flash mem than is available on the Atmel 328's.
Code:
// *********************** TIMER 3 **************************
ISR(TIMER3_OVF_vect) {
  tick0 = tick0 + 1;                        // update timing tick
  tick1 = tick1 + 1;                        // update timing tick
  tick2 = tick2 + 1;                        // update timing tick
  tick3 = tick3 + 1;                        // update timing tick
  TCNT3 = 155;                              // reset timer cnt to 155 out of 255.........?
  TIFR3 = 0x00;                             // timer3 int flag reg: clear timer overflow flag
Old Oct 31, 2012, 10:26 AM
msev is offline
Joined Sep 2010
Well I received my arduino mega and 16x2 lcd, but haven't yet done the pcb for usb host shield...Is it possible to upload code, and see if menu's are working without the usb host shield connected?
Old Oct 31, 2012, 01:59 PM
IanJ is offline
Joined Dec 2007
You can upload the code but the menu's won't work because it needs the stick attached.....via USB.
All you will probably get is the opening display on the LCD.
I'm thinking the PPM output will work albeit everything at default settings since you won't be able to config anything.
Opening LCD screen:-
Ian.
Old Nov 01, 2012, 12:10 PM
msev is offline
Joined Sep 2010
Thanks Ian.
I'm thinking of having some pcbs for Usb host shield made at a local EU pcb-fab-house..
Probably one will cost around 5-6 euro + shipping, anyone interested?
Old Nov 01, 2012, 12:58 PM
IanJ is offline
Joined Dec 2007
Thanks Ian.
How will these differ from the ones you can buy?
Ian.
Old Nov 01, 2012, 01:33 PM
msev is offline
Joined Sep 2010
Ian.
They'll be the same, its just that I got a few max3421's lying around and I want a bare pcb so I could make that usb host shield myself..
Old Nov 06, 2012, 07:43 PM
tevada2010 is offline
Find More Posts by tevada2010
Joined Jun 2011
Where can I buy Thomas Scherrer's 430mHz LRS kit ?
tevada2010 is offline Find More Posts by tevada2010
Old Nov 07, 2012, 02:30 AM
IanJ is offline
Joined Dec 2007
Google is your friend - http://www.webx.dk/rc/uhf-link3/how2purchase.htm
You can use any Tx system just as long as it conforms to standard Futaba type PPM stream, albeit I have only tested with Thomas's kit.
Ian.
Old Nov 14, 2012, 10:21 AM
jerry_hu is offline
Find More Posts by jerry_hu
Joined Nov 2012
LCD no display
Hi IanJ,
I'm tring to make may USB RC Joystick just same as your parts with MEGA1280&LCD1602, the function of Tx and stick control are all worked well, but my 1602 LCD have no words display, just have back-lighting on, could you pls help me for this problem? ~~ thanks!
I connected the LCD to arduino MEGA1280 I/O as below:
ARDUINO I/O:-
Dig Pin 2 = LCD D7
Dig Pin 3 = LCD D6
Dig Pin 4 = LCD D5
Dig Pin 5 = LCD D4
Dig Pin 6 = LCD RS
Dig Pin 7 = LCD ENABLE
jerry_hu is offline Find More Posts by jerry_hu
Old Nov 14, 2012, 12:21 PM
IanJ is offline
Joined Dec 2007
Originally Posted by jerry_hu View Post
Hi IanJ,
ARDUINO I/O:-
Dig Pin 2 = LCD D7
Dig Pin 3 = LCD D6
Dig Pin 4 = LCD D5
Dig Pin 5 = LCD D4
Dig Pin 6 = LCD RS
Hi,
Did you connect up a potentiometer to adjust the LCD contrast?
Here's an example I found on the web:-
Old Nov 15, 2012, 12:14 AM
jerry_hu is offline
Joined Nov 2012
Hi,
thanks Ian!I did connected the potentiometer,and,the contrast also can be adjusted ,but really no words display on the LCD,maybe the lcd was damaged,i will try another new 1602lcd later.
Discussion Re inventing the internal combustion engine UlteriorModem Life, The Universe, and Politics 20 Jun 19, 2015 07:36 AM
Discussion RC Radio Tx - Re-inventing the wheel! IanJ DIY Electronics 345 Mar 18, 2013 03:44 PM
Sold Immersion RC 600mW 5.8 TX Version 1 $50 shipped. nybeechpilot FPV Equipment (FS/W) 2 Jun 02, 2012 07:36 PM
Discussion Re-inventing the wheel philgib Blimps 5 May 25, 2006 07:42 PM
Wanted WTB AeroFly Professional Deluxe USB Interface Version RC Flight Simulator for futaba heliguy Aircraft - General - Radio Equipment (FS/W) 0 Oct 20, 2005 03:21 PM
