Old Aug 02, 2012, 02:15 PM
mewannafly is offline
Find More Posts by mewannafly
United States, MO, Lincoln
Joined Jul 2012
Help!
Separating retract power from Rx battery...will this work
Hi everyone
Getting back into flying after about 16 years away. Flew nitro then, decided to try electric now.
I got a Durafly P51, Spektrum dx6i, OrangeRx 6 ch rx. When I flew back then, just plug in a battery to receiver. This is my first electric. I've searched and read alot on ESC, BEC set-ups, useing separate bec for like retracts. But I'm still a bit confused on the wiring and such.
I would like to put the receiver on its own battery and run the aileron, rudder, elevator, and flaps on it. I was thinking of having the retracts on the esc/bec,motor battery. I plan on upgrading the esc to a 45 or 50A. For now I was going to use 3s 2200 or 2650 lipos. Maybe try some 4s later.
Will this work? (the highlighted area). If so, can I use NiCD or NiMH battery for the rx if the esc/motor/retract battery is lipo or does it need to be a lipo?
Thanks for any help
Stan
mewannafly is offline Find More Posts by mewannafly
Old Aug 02, 2012, 02:20 PM
Endlesslag is offline
Find More Posts by Endlesslag
Fly it like you STOL it!
Endlesslag's Avatar
United States, FL, Daytona Beach
Joined Jan 2011
Yes, that will work just fine Good idea too, in case the retracts get stuck or something.
Also, welcome to RCGroups
Endlesslag is offline Find More Posts by Endlesslag
Old Aug 02, 2012, 02:31 PM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Your wiring diagram looks fine. That's basically the way I (and many others) do it, so that the receiver won't be starved of power if a retract stalls.
Your receiver supply can be any type of battery, or it could be another BEC, taking its power from the main battery.
abenn is offline Find More Posts by abenn
Old Aug 02, 2012, 03:07 PM
Joined Jul 2012
Thanks guys.
Old Aug 02, 2012, 10:22 PM
Wintr is offline
Find More Posts by Wintr
Wintr's Avatar
USA, MO, Florissant
Joined Nov 2010
The only issue I see is, if a retract stalls, it will pull lots of power from the BEC on the ESC, possibly making the ESC heat up, especially if the main battery is 3S or higher volts. If the ESC has a switch mode BEC, this is less of a problem.
For one of my aircraft, I use a 1800mah 3S LiPo and two switching BECs, one for the receiver and servos, the other for the retracts. I disabled the one in the ESC, which runs from a larger, 4S battery.
Wintr is offline Find More Posts by Wintr
Old Aug 02, 2012, 10:50 PM
Foambird is offline
Find More Posts by Foambird
St. Louis
Foambird's Avatar
USA, MO, Ballwin
Joined Mar 2010
What retracts are you using? I did not go with this set-up since the E-Flite retracts have a protection circuit that kicks out in a jam. Resets so you can cycle the gear.
Otherwise I think your set-up is good insurance.
Foambird is offline Find More Posts by Foambird
Old Aug 03, 2012, 07:56 AM
Joined Jul 2012
It's the esc/bec that comes with the plane. I can't tell what it is, other than what Hobbyking has on their site. I'm going to replace it with a 45 -50A that does have a switching BEC.
Where would you wire in the separate BEC?
The retracts too are the ones that came on the plane, so I'm don't know the brand.
I really appreciate everyone's help.
Old Aug 03, 2012, 02:21 PM
abenn is offline
Joined Jul 2004
The power leads for the separate BEC are usually soldered to the ESC's main battery plug, so the ESC (and its built-in BEC) and the separate BEC both power up when you plug the main battery in, and power down when you unplug.
The 5v (or whatever) output from the separate BEC goes into the battery slot or any spare slot in your receiver.
Just in case you're wondering which BEC to use for the receiver, and which for the retracts; I would always use the stand-alone BEC for the receiver because there's always a slight risk of the ESC failing and taking its built-in BEC with it. If that happens, you've lost power to the retracts but you've still got control of the aircraft if the receiver is powered by the stand-alone BEC.
Old Aug 03, 2012, 02:41 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Nice job on your diagram. If you want to take it as far as you can go, putting bypass caps between power and ground, at the Y between section 5 and section 6, as well as the Y between section 2 and 4, will reduce noise and susceptibility by providing a path for high to low switching return currents (to your receiver). Small .1 uF capacitors should be sufficient. The receiver likely alread had bypass caps, but putting an additional .1 uF for your retract and throttle wouldn't hurt.
Also, if this is a larger plane, twisting your servo wires (2 or 3 wire servo wires) will help with EMI/glitches/crosstalk, as well as using a Ferite ring between your ESC and the section 5/6 Y.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old May 05, 2013, 11:35 AM
Recce is offline
Find More Posts by Recce
Recce's Avatar
Estonia, Harju, Tallinn
Joined Aug 2012
I posted this question in 1100mm Durafly p-47 thread, but here it would probably get more views. I would like to do a reverse on my model: power the rx together with flight controls from the BEC and retracts, flaps and navigation lights from a separate battery. I found information about how to do it:http://www.gibbsguides.com/article06...wer-supply.htm. Also found a lot of info from Google and this forum, but I would like to get some info about the following:
Does it work if I use a low voltage battery to bring down the retract operation speed? If control power came from the BEC and drive power from say 3,0V. The retracts themselves probably need 4,8v to operate, does that mean control power only, or both? The retract resembles this one:http://www.hobbyking.com/hobbyking/s...dProduct=17538
Would the overload protection work with lower voltage?
I plan on doing my own tests, but not any time soon. So I`m looking for your opinions and experience.
Recce is offline Find More Posts by Recce
Discussion What Separates those Who are Smart and Work hard from the Crowd? LcJ Life, The Universe, and Politics 58 Jul 30, 2012 07:05 PM
Discussion Will this battery work with Accucell 6 aftatchell Batteries and Chargers 6 Jun 03, 2012 08:17 AM
Discussion Will this battery setup work? Ron RC Power Systems 4 May 11, 2012 07:16 PM
Question Will this charger, Power Suppy setup work? snoshoe62 Batteries and Chargers 0 Mar 14, 2012 11:04 PM
Discussion Will this charging board work with these batteries keithy351 Batteries and Chargers 1 Feb 27, 2012 10:06 AM
