Old Aug 02, 2012, 10:00 AM
wc_wickedclown is offline
Find More Posts by wc_wickedclown
United States, CA, Signal Hill
Joined Aug 2009
what could cause the tail to blow out when flipping the heli
does not blow out when doing punchouts
im thinking it could be to much rudder expo using 15 percent atm
wc_wickedclown is offline Find More Posts by wc_wickedclown
Old Aug 02, 2012, 10:14 AM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
What is your setup? It could be a few things? Are you sure you are not inputting a little rudder during the flip?
ridge_racer is offline Find More Posts by ridge_racer
Old Aug 02, 2012, 10:30 AM
Joined Aug 2009
spartan gyro on both birds
seems when i use low head speeds is when it kicks the most and im kind of sure its not me giving that much input
Old Aug 02, 2012, 05:26 PM
Alan Hahn is offline
Find More Posts by Alan Hahn
Chicago 'burbs
Joined May 2006
Low headspeed makes it hard for the gyro to have enough tail authority (=thrust). Now depending on your throttle curve, and whether your pitch curve is really symmetric about midstick, , it is also possible that inverted is flying with even less headspeed.
That could cause the blowout to be worse on the flip.
I say first thing to try is higher headspeed.
Alan Hahn is offline Find More Posts by Alan Hahn
Old Aug 03, 2012, 11:42 AM
Joined Aug 2009
i think i figured it out
i use a separate gyro gain per idle up condition unfortunately i use 35 percent for all three conditions i noticed in idle 2 the tail does not blow out when doing flips
my crashes have been in idle 1 so i guess i may need to increase the gain to 40 percent in idle 1
lesson learned and only cost me 300 bucks to learn lol
Old Aug 07, 2012, 04:19 AM
Joined Nov 2010
That much damage from a tail blow out??
Old Aug 08, 2012, 02:53 PM
Joined Aug 2009
i was lower to the ground when i flipped it then i should have been
blades boom .
servos and motor are ok so i feel lucky
ordered the new design sab blades 45 bucks they are 55 to 70 bucks everywhere else.
Discussion 5 blade head tail blows out. mikes68charger Multirotor Talk 1 Jun 30, 2012 12:02 AM
Discussion what could cause a belt to get lose and what can i do wc_wickedclown Electric Heli Talk 6 Jun 23, 2012 04:01 AM
Discussion what could cause my align esc not to make the arming beep. wc_wickedclown Electric Heli Talk 14 May 23, 2012 11:27 AM
Discussion What could cause my R50 tail to not hold when hard climbing? Vertical Electric Heli Talk 16 Jun 18, 2006 08:38 AM
Help! What could cause my foam sheets to "warp" when slicing them? NetForce2K Foamies (Kits) 18 Jan 28, 2004 05:31 PM
