Old Aug 01, 2012, 08:10 PM
this is nukin futs!
out of stock's Avatar
United States, FL, Lehigh Acres
Joined Jan 2012
need foam touch up advice (sapac eurofighter)
people, im on my way to purchase this sapac eurofighter from a buddy of mines locally. its got scuffs here & there and i have 0% knowledge on how to treat these wounds.
im in love with this breed of edf's. i chose this over HL's 90mm eurofighter.
just any advice like preparation, type of paint safe for foam.
i dont know what type of foam sapac's models are.
out of stock is offline Find More Posts by out of stock
Old Aug 02, 2012, 11:54 AM
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia / UK visits
Joined Jan 2010
Dings and dents in edges are quite simple to sort.
Very small unsightly hangar rash can be sorted with dabs of Hot glue .. wet finger / wet flat stick to smooth / flatten.
Slightly larger or where a moulded item has been worn / broken away such as a wing fence ... these are replaced by cutting area out as a square. Get closed cell foam and cut a block to fit that cut-out. Shape, sand, seal and paint.
Dents in surfaces can either be raised by hot water or again the cut-out and fill with closed cell foam, shape, sand, seal and paint.
Where appendages have been broken of - such as missiles etc. These are best remade in laminated form to give better strength and then cocktail stick + glue fitted. The laminations has runs of glue through adding that strength.
The trick is to get foam that is easy to work with ......... house insulation closed cell Pink / Blue foam is ideal. You can buy in thin sheets or thick wide blocks.
Nigel
solentlife is offline Find More Posts by solentlife
Old Aug 02, 2012, 09:33 PM
this is nukin futs!
Joined Jan 2012
fantastic nigel! im set! thanks
Help! looking for sapac eurofighter arf in the u.s out of stock Electric Ducted Fan Jet Talk 3 Aug 01, 2012 03:39 PM
Discussion SAPAC Eurofighter Hatch DForbes Electric Ducted Fan Jet Talk 3 May 23, 2012 09:03 PM
Poll Sapac L-39 foam best dress up contest Sapacbill Foamy EDFs 0 Apr 20, 2009 06:08 PM
Red touch up paint for the Hobby Lobby foam Strega lrsudog Aircraft - Electric - Airplanes (FS/W) 0 Jul 13, 2004 08:48 PM
