Old Sep 13, 2012, 09:50 AM
Guayaquil- Ecuador
Joined Dec 2008
Thanks for the tip Allan, maybe that s the only solution since even I apply force in cold to straight it up, after a while it return to its original position , but as I understand you ,I can do it with your towel method but I will sacrifice the painting???
Scott, do you have the same stab type than mines with two elevators. I think if I install two servos SZD16 suggested, it will weak the elevators and maybe it is not thick enough.
Regards
Erwin
erwin peters is offline Find More Posts by erwin peters
Old Sep 13, 2012, 11:08 AM
Vintage wood is the best!
SZD16's Avatar
In a house
Joined Sep 2002
As long as you reinforce the opening you make like I did you will be fine.
SZD16 is offline Find More Posts by SZD16
Old Sep 13, 2012, 11:46 AM
Big Nuts 181's Avatar
Joined Jul 2004
And as to thickness there are done really nice paper thin servos available now....
Big Nuts 181 is offline Find More Posts by Big Nuts 181
Old Sep 14, 2012, 10:08 AM
marnochs's Avatar
Canyon Country, California
Joined Dec 2006
Hi Erwin,
My ASW28 elevator is a one piece unit. Here it is all fiberglass, awaiting some primer and paint.
two servo setup would be the way to go.......
Scott
marnochs is offline Find More Posts by marnochs
Old Sep 16, 2012, 09:25 PM
Blenheim, NZ
Joined Dec 2007
Regards
Erwin
Yes, you do get some roughening of the gelcoat, mine came up as a diamond pattern which may be shear lines due to the twist or perhaps the cloth grain coming up. Only minor but needs tidying up if want a perfect finish.
I'm a fan of 2 servoes on elevators by the way. It is the single vital control on the model so some redundancy in the system is real good.
Allan
AllanK1 is offline Find More Posts by AllanK1
Old Sep 21, 2012, 11:49 AM
Guayaquil- Ecuador
Joined Dec 2008
Would be the HS 125 48oz torque servo, enough for each elevator??
Old Sep 21, 2012, 09:19 PM
Fly long, Life is Hard
Lbuff1's Avatar
Killingworth CT
Joined Nov 2008
Yes
Lbuff1 is offline Find More Posts by Lbuff1
Old Oct 18, 2012, 05:24 PM
Guayaquil- Ecuador
Joined Dec 2008
Hello friends, how do you install the tail wheel without making holes n the fuselage for the axis?. I have seeing some gliders in the forums that there is not mark or sticker covering the holes for the axis.
Regards
Erwin
Old Oct 23, 2012, 11:39 AM
Joined Jul 2005
Regards
Erwin
On a full-size ASG29 (or any other modern Schleicher glider) the axle for the tail wheel goes through the tail fairing from the outside. A disc of white PVC/fablon is stuck over the opening hinding the bolt head/nut.
robertjwelford is offline Find More Posts by robertjwelford
Old Oct 23, 2012, 01:05 PM
Guayaquil- Ecuador
Joined Dec 2008
Yes that what I finally did and will use some white stickers to cover the holes.
For the wing servo covers, I just receive the covers made from light plywood but not the fairings, is there a place where I can get long fairings to make them go until the control horn??
Erwin.
Old Oct 29, 2012, 11:55 AM
Guayaquil- Ecuador
Joined Dec 2008
Hello, any idea or forum to watch about installing this type of hinge. It’s a front opening canopy.
I cannot get an answer from Rosenthal.
Regards
Erwin
Old Oct 29, 2012, 12:24 PM
JoseLG's Avatar
Jerez Frontera (Spain)
Joined Nov 2004
Regards
Erwin
Hi, I don`t have the same kit, but I think, looking at the pic, that the short piece goes (glued?) in the fuse an the longer in the cabin. The front on the longer makes as a stop in the closing.
Cheers.
José Luis
JoseLG is offline Find More Posts by JoseLG
Old Nov 09, 2012, 09:59 PM
Guayaquil- Ecuador
Joined Dec 2008
Hola Jose Luis, yes, your idea is right but actually the hinge does not have the “u” shape I have seeing in other hinges so actually the full opening of the canopy is not practical, I have not glue it since I don’t want redo , reglue and maybe broke something. Also have post in RC network 2 days ago so far not an answer. I am very disappointed with Rosenthal (paid 60 Euros for the hinge) about this , I have request at least a hand drawing but not answer for the hinge assembly.
Wait for a lighting of illumination
Regards
Erwin
Old Nov 15, 2012, 08:57 AM
Guayaquil- Ecuador
Joined Dec 2008
Finally after some good advice, I change my original idea, and switch to two servo for the stab , very simple Work, since my stab was only fiberglass clothing on top and bottom I reinforce with a carbon fiber clothing same size as the servos opening and surround lateral surface with 1/8 plywood . Here some picture.
Build Log ASG-29 1:3 from Tangent/Graupner H205 Scale Sailplanes 39 Mar 20, 2013 09:48 AM
Discussion H-model ASG 29 1:3 - need info sjaa Scale Sailplanes 146 Jun 27, 2012 04:33 AM
Sold Rosenthal 1/3 scale fuselage Jackspt28 Aircraft - Sailplanes (FS/W) 3 Apr 22, 2012 12:02 PM
Found 1:3 or 1:3.5 ASW-27, ASG-29 fuselage ***ANY CONDITION*** yyz Aircraft - Sailplanes (FS/W) 7 Oct 04, 2010 02:49 PM
Alert Rosenthal 1/3 ASH-26 Kit Available in SoCal pilotfrank Scale Sailplanes 0 Dec 11, 2007 11:53 PM
