This thread is privately moderated by studioRS, who may elect to delete unwanted replies.
Old Aug 01, 2012, 11:01 AM
studioRS is offline
Find More Posts by studioRS
Klassische Bilder
studioRS's Avatar
Northern Vermont
Joined Jul 2010
Build Log
Robbe - Nine Eagles Sky Surfer 780mm with sailplane graphics
I ordered the new Nine Eagles Sky Surfer with 780mm wing span (also marketed by Robbe in Germany) from the HK warehouse in WA, USA, this little sailplane is tiny! OMG. All my sailplanes have wingspans of at least 2m so this little baby is going to take a bit of getting used to.
From the get go, I wanted to add some of my european style sailplane stickers http://kewlartdesigns.com and give this a semi-scale appearance. This Surfer looks like a cross between a DG-1000, ASW-17 and Radian (If you squint real hard there is a scale look there somewhere). So I decided to make it look more like an ASW-17 with the lower elevator.
More photos, details read on...
studioRS is offline Find More Posts by studioRS
Old Aug 01, 2012, 11:56 AM
studioRS is offline
Klassische Bilder
studioRS's Avatar
Northern Vermont
Joined Jul 2010
Nine Eagles Sky Surfer 780mm sailplane packaging photos.
Old Aug 01, 2012, 12:02 PM
studioRS is offline
Klassische Bilder
studioRS's Avatar
Northern Vermont
Joined Jul 2010
Added my http://kewlartdesigns.com sailplane graphic stickers ( I used some extra 2 meter sailplane stickers I had laying around and printed some out on the ink jet, clear laminate over for now ). I will have a PDF available in Suisse, German and UK registry on the website soon.
Painted wing tips and underside of wing with Krylon Short Cuts pepper red.
Cheers, Thompson
Old Aug 01, 2012, 12:06 PM
studioRS is offline
Klassische Bilder
studioRS's Avatar
Northern Vermont
Joined Jul 2010
First modification before maiden flight was to secure the wing servo wires to the wing. These need to be be recessed into the foam and secured. Certainly a lot of movement with the wire, just fiddling with getting the wing on and off once was an indication it needed securing.
I cut a small channel and put in a few drops of CA at the plug end, then placed a piece of clear tape over.
Cheers, Thompson
Note: red dots on wing indicate CoG.
Old Aug 02, 2012, 08:59 PM
studioRS is offline
Klassische Bilder
studioRS's Avatar
Northern Vermont
Joined Jul 2010
Maiden flight photos, at dusk under setting sun and a full moon on its way up. Great little sailplane, glides really well.
NOTE: Sky Surfer is ABOVE the Radian
Old Aug 08, 2012, 07:11 AM
Pepo is offline
Find More Posts by Pepo
Joined Apr 2012
Hi studioRS,
This is really good little smart glider. I would say very nice for beginner as me. I made a lot flights also with the keychain camera in CG, but now I have problem with the servo of the elevator oscillation and also aileron servo. When I made a test range it works and suddenly no reaction, the red light on RX is poor solid and no reaction when I moved stickers on the TX. Last landing was without control but fortunatelly I was line up on the final approach and landed save and sound. One time I had slight dirty landing the wing was disconnected from fuss and also from servo, but after check it works and it flys without problems. Now it is getting worse and worse. I tried also to bind it again and again, doesn`t help.
Pepo is offline Find More Posts by Pepo
Old Aug 08, 2012, 09:50 AM
studioRS is offline
Klassische Bilder
studioRS's Avatar
Northern Vermont
Joined Jul 2010
Originally Posted by Pepo View Post
Hi studioRS,
If your original Nine Eagles Rx and Tx radio isn't working right I would think about first replacing the Rx brick.
http://www.hobbyking.com/hobbyking/s...dProduct=19272
If you have another Tx (like Spektrum DX6i) upgrading is an option too, you could remove the complete original radio and motor and replace with brushless motor with micro servos and micro Rx.
- Hobby King 1811 - 2000kv 10g micro brushless motor
- Zippy 2S, 350mAh 20C
- HK R415 OrangeRx, DSM2
- HK 5320 1.7g servos x 3
- TowerPro 9g w12A ESC
- Graupner Cam 4,7x2,4 folding prop
http://www.rcgroups.com/forums/showthread.php?t=1592502
Or you could purchase another BNF Surfer from Hobby King, this would be about the same cost.
Old Aug 08, 2012, 03:44 PM
studioRS is offline
Klassische Bilder
studioRS's Avatar
Northern Vermont
Joined Jul 2010
Made a clear, more scale looking canopy with pilot.
Old Aug 09, 2012, 03:43 PM
Pepo is offline
Joined Apr 2012
Hi again,
Thanks for advice. You`re right the DX6i upgrade is the best solution, but I love the practical thing to have a independent Tx in one box, simply to take it on shoulder and go to the place. Fortunatelly I have also Sky500 and today was very calm fo flying her. I like these size RTfs. I have to study the threads about this topic. Have a good landings!
Old Aug 09, 2012, 06:43 PM
studioRS is offline
Klassische Bilder
studioRS's Avatar
Northern Vermont
Joined Jul 2010
Hi again,
You are welcome! Yes, handy to have small Tx and sailplane in back of car for easy flying. I will fly until parts need to be replaced then upgrade to brushless and use my DX6i with micro servos.
I ordered the Turnigy Plush 6A ESC, 1811 brushless motor and small 5.5x3.3 folding propellers, waiting for Orange 415 Rx and 5320 servos to come in stock.
New Product Nine Eagles Sky Surfer. ArneHu Electric Sailplanes 340 Aug 28, 2014 06:02 PM
Discussion Cox Sky Cruiser / Nine Eagles Sky Runner Mod Thread, SpekTrum, B-Less & Ailerons ShokWaveRider Foamies (Kits) 31 Jun 08, 2014 05:21 PM
Discussion Cox Sky Cruiser / Nine Eagles Sky Runner Mod Thread, SpekTrum, B-Less & Ailerons ShokWaveRider Scratchbuilt Indoor and Micro Models 0 Jul 21, 2012 10:33 AM
Found COX Sky Cruider or Nine Eagles Sky Runner - Prefer No Radio Just Airframe ShokWaveRider Aircraft - Electric - Airplanes (FS/W) 2 Jul 15, 2012 04:23 PM
New Product Nine Eagles Sky Surfer. ArneHu Electric Plane Talk 2 Aug 01, 2011 04:45 AM
