Old Aug 01, 2012, 09:54 AM
wjb111 is offline
Find More Posts by wjb111
wjb111's Avatar
Swartz Creek, MI.
Joined Dec 2010
Question
Transmitter replacement battery
What is a suggested replacement battery for a Futaba T7C? The stock Sanyo battery isn't holding a charge worth a cr@p anymore. Just a couple flights and it's down to 9.6v.
Thanks.
Bill B.
wjb111 is offline Find More Posts by wjb111
Old Aug 01, 2012, 10:04 AM
everydayflyer is online now
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
First off I believe that Sanyo Eneloops are the best NiMH battery to use in a RC Transmitter designed for Ni cells ,period!
Secondly when a Ni cell reachs 1.2V per cell (9.6V for an 8 cell battery ) it does not indicate that it is in fact nearly empty. There is a reason that Ni cells are listed as 1.2V nonimal voltage. They can drop to this level under load and remain there for a long period of time in fact much longer than it took them to drop from say 11V to 6.6V.
Different transmitters consume mAh at different rates however 250 mA us to be a good standard to us thus why I used it in this extended test.
http://www.rcgroups.com/forums/showp...&postcount=142
First step should be to ensure that you are indeed charging them correctly and fully.
Just happened to post here a few minutes ago.
http://www.rcgroups.com/forums/showp...10&postcount=5
Site at that link , Hangtime builds excellent quality SAnyo Eneloops Trans. packs.
Charles
everydayflyer is online now Find More Posts by everydayflyer
Old Aug 02, 2012, 01:57 PM
wjb111 is offline
wjb111's Avatar
Swartz Creek, MI.
Joined Dec 2010
Charles
edf,
Thanks for the information. I ordered a 1100 mah eneloop from Hangtime.
I'm getting tired of the couple flights & the transmitter battery being low.
Bill B.
Old Aug 02, 2012, 02:22 PM
typeRA is offline
Find More Posts by typeRA
Zero Expo
typeRA's Avatar
San Diego, CA
Joined Mar 2009
Originally Posted by wjb111 View Post
edf,
Bill B.
I don't think there are 1100mAh eneloop batteries. The AA size cells are 2000mAh.
typeRA is offline Find More Posts by typeRA
Old Aug 02, 2012, 02:28 PM
Southern Pride
Correct the 1100s are Sanyo Nicads and I would have spent the extra dollars and got the Eneloops.
I only use Eneloops in my Transmitters however I am a DIY type and 8 cells cost me less than $25.
Old Aug 02, 2012, 02:30 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
My latest batch of AA Eneloops were 1900mah.
hoppy is offline Find More Posts by hoppy
Old Aug 02, 2012, 05:32 PM
Southern Pride
There are now a mininum of three different flavors of Eneloops. Thge original nonimal 1000 cycles and nonimal 2000 mAh , then came the improved 1,500 cycles ones and 1,900 mAh and then the ones rated for higher discharge rates but also lower cycles.
Old Aug 03, 2012, 03:58 AM
solentlife is offline
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
There are loads of 3rd party battry pack guys out there who will make a pack up for our use. They use good cells and often will ask what capacity you want. I used a UK company to create a pack for my JR Propo .. that pack is 2300mAh and over a year later of abuse - performs as good as the day they sent it to me. $25 equivalent incl. post.
Eneloops .. yes good idea - but in fact as a Mallory Battery Tech told me - most AA NiMh are now Low Self Discharge including many of the budget AA's. I use Grundig NiMH AA's in all my gear from cameras to my Tx's ...
I get an average of 9hrs use out of my Tx's ... they hold charge for months ... I can charge them either via my Prolux auto peak charger or the old Futaba M chargers I still have. Cost ? $8 for the 8 ...
Nigel
solentlife is offline Find More Posts by solentlife
Old Aug 03, 2012, 10:08 AM
Southern Pride
I agree there are some very good alternates to Enellops but considering how important a Transmitter is and that Sqanyo Eneloops will last for many years they are still the least expensive part of flying RC.
The Eneloops in my DX7 installed 2-11-09 so they will be 3-1/2 years old in 8 more days. I fly an awful lot by most flyers standards and the DX 7 has been my primnary transmitter for around 5 years now. The first batteries I put in it were Ray O Vac Hybrids and they did well and in fact were still doing well when I replaced them after justover one year of service.
I have tested some other LSD AAs and AAAs and the ones I tested here have been doing well.
http://www.rcgroups.com/forums/showthread.php?t=1347070
I still prefer Eneloops as they have a proven history of dependability going back for many years.
Here is my original Transmitter battery test thread her on RC Groups where many brands and capacities have bben tested. The worse ones were the Energizer 2500 and the SAnyo 2500s. Very high capacity AAs are only good for charge and use right then high drain applications. Both of these 2500s brands had very high self discharge rates and also had a high cell failure rate especially the Energizers.
http://www.rcgroups.com/forums/showthread.php?t=327288
Charles
Old Aug 03, 2012, 02:44 PM
wjb111 is offline
wjb111's Avatar
Swartz Creek, MI.
Joined Dec 2010
Well it looks like I ordered the wrong item then...
Sold NEW Furaba Transmitter, 6.0V 1700mAh NiMH Battery for the 6J & 8J transmitters crosby Aircraft - General - Radio Equipment (FS/W) 0 Jul 15, 2012 02:37 PM
Discussion Recommended replacement battery for Hitec Optic 6 transmitter? ltx Batteries and Chargers 15 Jan 19, 2012 11:35 AM
Discussion LiPo replacement for NiMH transmitter batteries llamero Radios 2 Feb 18, 2011 06:17 AM
Discussion Futaba Transmitter 9chp Super Replacement Battery? djdaveq Micro Helis 7 Mar 07, 2006 04:47 AM
