The last 3 kits are left .......counting. Get it now or cry later.
I'm having trouble getting the cg correct when using a 2600mah 3s battery. With the battery backed against the bump, the cg is still 3.5 cm rather than 6.5 cm. Even if the bump didn't exist, I would still have the problem of not being able to move the electronics farther back. The plastic tubes for the screws block off a lot of area. I probably will have to add weight to the tail even though I hate having dead weight.
~Removed the screw tubes (I use retainer pin & clip to hold the wings together) ~Rudder/elev servos mounted half way out the tail boom. My first Bix2 I mounted them at the tail, this time I'll try with them a lttle closer in so hopefully I wont need flight lipo as far fwd to counter balance ~2 small hatches gives plenty of access to the ESC/rcRx and vTx lipo/OSD wiring Vents: ~each side where the original servo arns poked through the fuse sides ~1 on top in front of the cockpit, original underside scoop will be taped closed (last B2 the vent under the front gave no end of frustration with dirt etc being scooped in- ridiculous place for a vent on a belly lander IMHO ~1 at rear/top of tail boom where rcRx antenna runs out The 3 fwd vents will have fwd facing scoops so airspeed will force air in The rear vent will have rear facing scoop which will suck out air by venturi effect from air speed and prop wash ~The motor nacelle vent/scoop will also have air going down into the fuselage, this air will pass over the esc for cooling, I have removed a small amount of the heatshrink off the esc to aid cooling. This isnt a fast flying setup so it should run cool enough anyway all sounds good in theory, proof will be in the tasting of the flying pudding ![]() Hope this throws more ideas into the think tank
(ouch). Interesting, especially knowing that full size aircraft can encounter the same issue. That makes me think that those wanting lots of power are better off with a V-70, or something similar, which was designed from the ground up for that kind of power.I hope you get her back together and flying again soon. |
. what ESC were you using?MIk |
M. |
| Thread Tools | |
| Discussion Hobby King Buddy codes for Bixler FPV Build | xxdixonxx | Hot Online Deals | 0 | Jun 19, 2012 12:51 AM |
| Discussion Hobby King Bixler motor? | wehrwolfzug | Electric Motor Design and Construction | 2 | May 17, 2012 05:10 PM |
| Discussion Hobby King USA Warehouse wait time for bixler and 9x? | elcid79 | HobbyKing | 11 | Apr 21, 2012 12:04 AM |
| Discussion Hobby king Bixler Buddy Code | aaluu | Foamies (Kits) | 1 | Feb 23, 2012 12:06 PM |
