Old Oct 29, 2012, 11:36 PM
scott page is offline
Find More Posts by scott page
Left RCG because of Trolls
Joined May 2009
Originally Posted by mdem View Post
Thanks for the quick reply.
I've thought of using hot glue but it sets far to quick, I wouldn't be able to place both halves in the correct position within the short time frame and same goes for most CA I've found so far.
Double sided tape sounds like it inst that strong lol, I might be wrong though.
Although Welder Adhesive sounds promising.
Is it a Brand name? I'll look into it now.
Thanks again
-mdem
*edit*
Is this the glue you mentioned?
- http://www.amazon.com/Welder-Contact-Adhesive/dp/B003E6ZPWA/ref=pd_sxp_f_pt -
*edit 2*
Been looking around and the Welder adhesive looks similar to foam safe CA, in regards to curing times. I'd need something that takes anywhere between 10-15min + to get all the alinements in places and perfect.
That's the stuff. I got turned onto it by the guys building EPP Superfly flying wings. They even use it to make hinges -- I was incredibly dubious until I tried -- it's magic. I also use it on Tech-one thin skin EPP models and apply very thin fabric (like a veil) in areas taht need reiniforcing --- again -- like magic.
scott page is offline Find More Posts by scott page
Latest blog entry: Making my own tray
Old Oct 29, 2012, 11:41 PM
Joined May 2009
Originally Posted by xviper View Post
Unless you have an onboard altimeter, it's like the stories that fishermen tell after the fact. It was THIS big!
I've measured altitude with an altimeter on various planes. 2000 feet for a small plane like a Trojan makes it barely visible. It takes nearly 3500 feet for an X8 wing (7 foot wingspan) before it almost disappears. 2000 feet for my 11 foot wingspan AWS-17 looks like you could almost reach out and grab it. I've not measured the Bix 2 yet, but I'd say 2500 feet and it's probably invisible. Depends on the appearance of the sky.
You're right -- basically invisible - just a dot. I have FrSKY altimeter telemetry on board one day when I got in a boomer thermal. My spotter had to read the telemetry to me because if I took my eye off the plane for second I'd never have found it. I was at 2200 feet when I got into a cloud -- and it the spoilers.. lost sight of the plane for quite awhile..Everybody looking and my friend found it circling to the North when it was at 1200 feet -- and it's still not too big at that altitude. I was glad to have it back because I had more $$ in equipment onboard than the plane itself.
Never EVER going to do that again.
Old Oct 30, 2012, 01:52 AM
Crashem Dave is offline
Find More Posts by Crashem Dave
Short Circuit Creator
Crashem Dave's Avatar
Geelong, Victoria, Australia
Joined Nov 2004
Originally Posted by ajbaker View Post
Before you do all that, get a Watt Meter. Otherwise, you are risking a fire (or worse).
AJ
Frackin' Hell! What happened there?
Crashem Dave is offline Find More Posts by Crashem Dave
Old Oct 30, 2012, 09:06 AM
Drone 5 is offline
Find More Posts by Drone 5
Drone 5's Avatar
United Kingdom, England, Hull
Joined Sep 2012
Originally Posted by CorporalB View Post
Great news Drone 5, I plan on eventually getting the ArduFlyer (APM2.5 clone) for my Birthday next month but I might put a KK2.0 board in the Bixler 2 in the mean time for stability and level flight.
Before you bash me for putting stabilisation on a very easy to fly and naturally stable airframe... remember that I'm building a dedicated FPV ship, not a run 'o the mill park flyer
Present status of your Bixler FPV looks well on the way.
M.
Drone 5 is offline Find More Posts by Drone 5
Old Oct 30, 2012, 09:14 AM
Blue Flyer is offline
Find More Posts by Blue Flyer
happy when flying
Blue Flyer's Avatar
United Kingdom, England, North Yorkshire
Joined Dec 2010
This is where a RTH system would come in handy, but they're not cheap... I used to have FY31AP (before someone stole it) and the RTH saved me a few times
M.
Thanks, will be installing the RmileC into my 9x and the B2 this evening, aiming for the maiden before the weekend
Blue Flyer is offline Find More Posts by Blue Flyer
Old Oct 30, 2012, 09:18 AM
mdem is offline
Find More Posts by mdem
mdem's Avatar
Australia, VIC, Carrum Downs
Joined Oct 2012
Originally Posted by AussieHoppy View Post
is that an aussie national shop(eg bunnings), or just your local hardware ?
I think Bunnings have it as well, but i found a tool/metal shop that was closer, just used the 'Find distributer' on the Gorilla glue website to find a local store.
I bought Gorilla glue, and will be buying Welders glue, and also two-three others. Will test them all out on EPO foam (as that's what most planes I'll be buying right now will be), and see what works best for myself.
mdem is offline Find More Posts by mdem
Old Oct 30, 2012, 11:01 AM
craigblk is online now
Find More Posts by craigblk
RC Geeky
craigblk's Avatar
United Kingdom, Watford
Joined Mar 2011
have ordered 2cell 2200mah lipos to go with my Bixler2 2826-6 2200kv motor and 7x4 prop, anyone else have experience of this type of setup using 2 cell rather than 3...will probably run two batteries in parallel for extended flight time...any info would be appreciated............
craigblk is online now Find More Posts by craigblk
Old Oct 30, 2012, 11:15 AM
xviper is offline
Find More Posts by xviper
Canada
Joined Jul 2009
You should UN-order those and get 3s batteries. That motor will likely try to suck out more than what the 2s can deliver. Probably puff them up fairly easily. Instead of running 2 batteries hooked together, why not just get the right battery in the size you want (ie, 3s, 4400mah)? It's not like you've just got them laying around anyway.
xviper is offline Find More Posts by xviper
Old Oct 30, 2012, 02:28 PM
RC Geeky
craigblk's Avatar
Joined Mar 2011
Thank you for the advice have managed to cancel the order from hobbyking via live chat...somewhat confused now as I thought the motor prop combo mentioned would draw too much current on a 3 cell, should I downsize the prop to a 6x4 as I believe the turnigy motor has a maximum draw of 34 amps.....
Old Oct 30, 2012, 02:44 PM
xviper is offline
Canada
Joined Jul 2009
Stock prop is 7X6, so I don't think you need to go quite that small. Look at 7X4 or 6X5. I'm running 7X6X3 on an 1100kv motor. I'm going to try a 2200kv motor but I'll stick with the 7X6X3, only make sure I don't go full throttle for long stretches.
Just ensure your ESC can handle it. And do check the ESC, motor and wiring for excessive heat part way into the first flight. I burned my stock motor and wiring out on stock prop.
Old Oct 30, 2012, 02:47 PM
happy when flying
Blue Flyer's Avatar
Joined Dec 2010
Motor, prop, ESC and RmileC Rx installed. Decided to go with the 1450kv motor, 8x6e prop and 40a ESC.
The adjustable motor mount is in the middle position and there's about 8mm clearance between prop tip and fuse.
Will take pictures and update blog when I get back home
Old Oct 30, 2012, 02:48 PM
Joined May 2009
Start with a 3 cell and if you don't have a watt meter -- get one. Before you fly any plane you should check the amps and watts it's pulling. Purists will tell you this is not exactly what it will pull when the props are unloaded and flying -- they are right -- but it will give you a worst case scenario. Additionally -- the temp and humidity of the air can make a surprising difference in the amp draw -- same as altitude does. Check the worst case scenario with a watts-up or similar meter on the ground with the prop "loaded" (not moving through the air).
As far as two cells vs. three cells goes. All you are changing there is the voltage. To get the same power (Watts) you'll have to pull more amps Amps x volts = watts. So dropping the voltage by 1/3 will require corresponding increase in amps to get same power level. I'd worry more about the ESC than the motor as in my experience -- over amping kills ESC's and drawing too much wattage kills motors ... but that's a gross generalization -- as between the battery, ESC and motor ... one of them will be the fuse -- the first to fail in high load situations. Question to ask yourself -- is which would you rather lose?
Old Oct 30, 2012, 03:18 PM
RC Geeky
craigblk's Avatar
Joined Mar 2011
Thanks guys will order the three cell and use the watt meter as suggested and take it from there...pretty sure I have ordered a 7x4 and a 6.5x4 prop with my last order from Hobbyking at the weekend so will try those when they arrive.....will post results as soon as my orders arrive and have tested at the flying field....
Old Oct 30, 2012, 04:24 PM
mlp666 is offline
Find More Posts by mlp666
Mark
mlp666's Avatar
United Kingdom, England, Moreton-in-Marsh
Joined Oct 2012
On my bench test the 2826-6 drew way over it's max power of 342w on a 2200 3 cell running the bixler stock 7x4 prop. A flat out 6x4 was reading 353w so you would need a 30A ESC, but should be ok if you didn't leave it on full throttle all the time. but I'd go for a 6x3 to be on the safe side.
This site is cool for paying about with the numbers http://adamone.rchomepage.com/calc_motor.htm I'm not sure about the acuracy but it seems a good indicator.
M
mlp666 is offline Find More Posts by mlp666
Old Oct 30, 2012, 05:51 PM
xviper is offline
Canada
Joined Jul 2009
Stock prop turns out to be 7X5. I thought it was 7X6, so we're both wrong.
Discussion Hobby King USA Warehouse wait time for bixler and 9x? elcid79 HobbyKing 13 Jun 09, 2014 08:13 AM
Discussion Hobby King Bixler motor? wehrwolfzug Power Systems 6 Mar 01, 2014 11:33 AM
Discussion Hobby King Buddy codes for Bixler FPV Build xxdixonxx Hot Online Deals 0 Jun 19, 2012 12:51 AM
Discussion Hobby king Bixler Buddy Code aaluu Foamies (Kits) 1 Feb 23, 2012 12:06 PM
