Joined Jun 2012
http://i17.photobucket.com/albums/b9...ONES/th_14.jpg http://i17.photobucket.com/albums/b9...ONES/th_14.jpg I think that I am going to go with a Bixler-1 for now. If I destroy or loose it, my loses are less. If it survives , I might upgrade to a Bixler-2 in 6 months. Shimmy |
I use my flaps for all hand launching and it really shortens the takeoff on taking off from grass
I too intend to take off from grass when this sucker is fully FPV'd up, I want to be sitting in my camping chair and not have to do the usual hand launch wearing the goggles then blindly walk backwards to my chair lol. gave up on finding the chair a few times and just sat on the ground with my legs crossed... only a few feet from the chair. looked stupid to say the least.
small child @ field: "mister mister, why you sit on floor, when good chair just next to you" me: "go away I'm flying a plane" small child @ field: "what plane" for this reason I will definitely be installing the flaps immediately, to help with my take-offs |
![]() ![]() Can't u just launch it standing up in front of the chair and then sit down? or use an elastic so you chair is attached to your body? ![]() Jokes a part... I think If you fly fpv I strongly suggest the flaps as the plane does kind of stabilize and fly slower with them and glides well. |
![]() I have a Gopro coming so tried a heavy Olympus Tough camera to the Bixler to see how it would take off on the smooth grass with flaps. The Olympus is the same weight as the GoPro with the clear case fitted. With the stock motor it did take off, but wouldn't try it without flaps. I have an upgrade motor in the mail, so this will get it up even quicker.
Well I got the flaps hooked up, had to take one servo apart and reversed the wiring and all is good.
Put a servo speed reducer on the flaps turned to sloooow and it's slow. turned up to 50% and it takes 6 seconds to deploy, that's so cool! But now I'm stuck. I want mix in some elev on mix one and I'm not understanding how to do that. Can y'all please point me in the right direction? Thank you all, DJ |
What radio are you using! Mike. |
Good friend of mine did this with a foamy he was checking out with the prop on. |
Canada
Joined Jul 2009
To do mixing ..................
Go to your "mix 1" menu (the DX6i only has 2 mixes possible) and UN-INH it. Then you'll see the choices appear. You want FLAP --> ELE. Rotate the wheel and click as needed till you get this to show up. Then you can dial in % down ELE (as flaps will make the plane balloon UP). Start with 15% and go less or more from there as your plane needs it. It becomes a trial and error thing. Remember how much down you need will depend on how much throttle you're using at the time. So decide that when you activate flaps, you will always be at a certain throttle to start with. Generally, I would be power off when activating flaps initially. Test it on the ground before sending it up so you know that the ELE goes down when the flaps are activated. You don't want to find out the hard way when it's 30 feet off the deck and find you plane trying to do a low altitude loop. ![]() AR6200 is a 6 channel RX. |
Viper, why the hell I have my own thoughts about this has me asking you this; I've installed a servo speed reducer on the flaps. On slow I have to watch to see if there moving. I've set this on 50% and it takes 6 sec. for the flaps to deploy. Now because of that wide range I should be able to teach myself how much down elevator to use since I can have a lot of time to do it. It seems the 'flap + elevator mix' is speed and wind dependent. If we set it up on Tuesday W/ 6 -8 MPH wind and we come back on Thursday and it's a 10 -15 mph wind the set up won't work because the mix is specific to speed (air speed). I'm slowing down the flaps so I can 'fly' the elevator under any conditions. You can tell I'm on my second glass of wine. Viper, I hope this doesn't sound unappreciative, but what do you think ? DJ |
Joined Apr 2011
| Thread Tools | |
| Discussion Hobby King Buddy codes for Bixler FPV Build | xxdixonxx | Hot Online Deals | 0 | Jun 19, 2012 12:51 AM |
| Discussion Hobby King Bixler motor? | wehrwolfzug | Electric Motor Design and Construction | 2 | May 17, 2012 05:10 PM |
| Discussion Hobby King USA Warehouse wait time for bixler and 9x? | elcid79 | HobbyKing | 11 | Apr 21, 2012 12:04 AM |
| Discussion Hobby king Bixler Buddy Code | aaluu | Foamies (Kits) | 1 | Feb 23, 2012 12:06 PM |
