Old Oct 07, 2012, 10:47 PM
Short Circuit Creator
Geelong, Victoria, Australia
Joined Nov 2004
Originally Posted by xmod View Post
hi all,
bix2 spare wings were just sitting there lonely when the bix1 kit arrived...
So may i present bix1.5.
I have only flown it once briefly as the winds around here at the moment are very gusty and i had no hope of trimming it out .
P.s the lights make it a lot easier to fly at dusk.
cool mcgool
Crashem Dave is offline Find More Posts by Crashem Dave
Old Oct 07, 2012, 11:50 PM
Thunder Team
scott page's Avatar
United States, WA, Richland
Joined May 2009
Originally Posted by adza View Post
Well, my plane is back in the air, but i have a problem. With the damage to the cf rod I've tried replacing it with wood dowl, but the wings are flexing way to much.
Just wondering if anyone has any suggestions? Would ally tubing be too heavy?
Carbon Fiber Arrow Shafts -- with wooden dowel fit inside.
scott page is offline Find More Posts by scott page
Old Oct 08, 2012, 12:26 AM
Thunder Team
scott page's Avatar
Joined May 2009
Has anybody mixed the flaps with ailerons when flaps were not otherwise engaged -- so the flaps were ailerons unless being deployed?
I set mine up up this way, but has flown yet.
Old Oct 08, 2012, 12:37 AM
Canada
Joined Jul 2009
Why do you need so much aileron? It rolls quite well for a sailplane with just the standard ailerons.
xviper is offline Find More Posts by xviper
Old Oct 08, 2012, 01:15 AM
Thunder Team
scott page's Avatar
Joined May 2009
I'm an adrenalin junky. I like to kick the envelope a bit. .
Old Oct 08, 2012, 02:01 AM
Joined Sep 2012
Good thought Scott! Thanks!
Just came back from a very short maiden flight.. this plane is very slow compared to the axn so it was sort of easy to handle
I have no idea what the axn is, but your experience with the bixler is not normal. My first read is that you have the prop on backwards. (Numbers should be towards the front of the aircraft).
My bixler moves, and climbs quite well (even in 20k+ winds!). I can't comment re flaps as I haven't had them deployed, but honestly - I'd be suggesting you feel what push pressure you're getting with it at the moment (holding it), then reverse the prop and try again - and you might notice some significant difference.
adza is offline Find More Posts by adza
Old Oct 08, 2012, 02:34 AM
Australia, QLD, Mountain Creek
Joined May 2012
Scott, all I can find around here is 8mm shafts that wont fit. Have you found 6mm arrows, do you have a brand name I can track down?
Xmod is offline Find More Posts by Xmod
Old Oct 08, 2012, 03:39 AM
Si Vis Pacem Para Bellum!
Doubletap's Avatar
PRC (People's Republic of Commiefornia)
Joined Jul 2005
I setup all of my high performance sailplanes this way with mixed flaps with ailerons which essentially give full span strip ailerons and excellent roll rate/response.
Doubletap is offline Find More Posts by Doubletap
Old Oct 08, 2012, 04:12 AM
Joined Nov 2004
Try asking for "Dave Brown" C/F Arrow Shafts at your L.H.S.
I use them for pushrods in "Slimmer" models.
Tower Hobbies have them:
http://www3.towerhobbies.com/cgi-bin...?&I=LXB901&P=0
You may have to enlarge the hole a tad. They are about 7.4 mm o.d.
Old Oct 08, 2012, 04:14 AM
Joined Nov 2004
He is referring to the AXN "Clouds Fly" or "Floater Jet" (It's sold under both names)-- very similar model to the Bixler 1, but doesn't do aileron rolls as well.
See: http://www.rcgroups.com/forums/showthread.php?t=972336
Old Oct 08, 2012, 09:37 AM
dontarro's Avatar
Chile, Región de Los Lagos, Puerto Montt
Joined Jun 2010
This is my second flight with Bixler 2 and this is my first plane.
fly very well, seems to have a autopilot, is very stable.
The factory engine looks good to me, perhaps for someone more experienced, need more power, but to my right.
Excellent product I'm very happy with it.
bixler2 second fly (1 min 48 sec)
dontarro is offline Find More Posts by dontarro
Old Oct 08, 2012, 09:41 AM
Mikbaci's Avatar
United Kingdom, England, Forest Row
Joined Apr 2012
I did it with mine and the plane became way too twichy and sensitive ( flaperons are good if you soar and hunt for thermals) I programmed that off and put normal flaps on one switch and the Camber /Reflex on the aerlions and it works wonders. try it
Mikbaci is offline Find More Posts by Mikbaci
Old Oct 08, 2012, 02:22 PM
.--troll-o-copter--.
phoxache's Avatar
United Kingdom, Warks
Joined Jun 2012
Originally Posted by mikhail tupulov View Post
phoxache that is cool! Next time give it a shot without the gyro-you will have so much more fun.
Cheers mate! I don't have a gyro in any of my planes. What was it that made you think I did?
phoxache is offline Find More Posts by phoxache
Old Oct 08, 2012, 04:39 PM
Joined Nov 2004
http://www.youtube.com/watch?v=QDTKt1wprJk
dontarro, the Bixler's (1 & 2) make excellent trainers for novice flyers. Just go on enjoying it and leave it stock for the time being. Progress onto something more "conventional", like a high winged model (Cessna etc) and then a low winger (both with landing gear of course) and then if you want to mod the Bixler, do it then. Welcome to the sensational world of R/C flight.
Old Oct 08, 2012, 05:55 PM
Thunder Team
scott page's Avatar
Joined May 2009
I put adhesive sand paper on a down that was ...small (don't remember) Used that to add the needed 8mm byt spinning the dowel in drill. I've also done this once with an 8mm brass tube that was sharpened -- and chucked on a drill. That was after I had the foam all glued together --
O ya -- the 6mm stock spar fits perfectly in the 8mm arrow shafts.
Discussion Hobby King Buddy codes for Bixler FPV Build xxdixonxx Hot Online Deals 0 Jun 19, 2012 12:51 AM
Discussion Hobby King Bixler motor? wehrwolfzug Electric Motor Design and Construction 2 May 17, 2012 05:10 PM
Discussion Hobby King USA Warehouse wait time for bixler and 9x? elcid79 HobbyKing 11 Apr 21, 2012 12:04 AM
Discussion Hobby king Bixler Buddy Code aaluu Foamies (Kits) 1 Feb 23, 2012 12:06 PM
