9x 3 position Flaps Success!
YES! Thanks for the tips about installing the flaps in the same direction, I considered this but then I found an article on FliteTest which detailed how to use the 3 position switch for flaps: http://flitetest.com/articles/3_stag...ysky/Eurgle_9x And it worked! Position 1 (top) = neutral flap Position 2 (middle) = take-off flap Position 3 (bottom) = full flap Just a warning that there are 2 'AUX' settings in the mix menu, you need to read the instructions carefully or you'll use the wrong one and the flaps won't move equally- If you give it a go you'll see what I mean Thanks for all the help! -Al |
3 pos switch? I find it better to use the simple "flip" the servo over so they're both the same way... plug into a single channel with a Y connector.... then put that channel onto a pot on the tx (variable knob). that way you get much better control over exactly how much flaps you're applying. always good to mix in a bit of elevator too
Joined Sep 2012
Basically there is none available locally. I live four hours from the nearest hobby store that has stock to buy some, and its going to cost me more than $17 just to get one by the time i add shipping. :-(
(Plus I'd have to wait as well). So I'm trying to find something i can use that's available locally. |
Brazil, GO, Goiânia
Joined Sep 2012
My first flight was today!! A friend take-off the plane for me, and in the air I toked the control. I liked a lot, very easy to fly. For a first flight of a person, I liked a lot. I never flown even an simulator before.
Goood plane, will buy some replacements just to keep the place good looking after I learn to fly well. |
Kit fuselage is in 2 pieces.
The skid plate is pretty tough. But you could add a little packing tape at the wing tips in case of dragging a wing on landing. |
Latest blog entry: Selling out
Australia, QLD, Mountain Creek
Joined May 2012
Hi all,
Bix2 spare wings were just sitting there lonely when the Bix1 kit arrived... So may I present Bix1.5. I have only flown it once briefly as the winds around here at the moment are very gusty and I had no hope of trimming it out . P.S the lights make it a lot easier to fly at dusk. |
Here is my first attempt at video. Just mounted my sony cybershot to the front! This plane is just so easy to fly its unreal!
I've been flying my Zephyr and crazy scratch build recently.
I took the Bix2 out yesterday and I absolutely love it. It's so nice to fly! The other planes are faster and more aerobatic but the Bix is still my fave. I get lots of height and glide around for ages.
Joined Jul 2012
Just came back from a very short maiden flight.. this plane is very slow compared to the axn so it was sort of easy to handle. I noticed right away that even though throttle was around 70% (quite a lot compared to the AXN) i had to put flaps to go up.. else it won't gain altitude... once up, i could turn and see that the wings looked like flapping, yes very flexible and sort of coming out so i decided to get back to land.. activated flaps again and achieved a very soft first landing.
I had put those 2 screws inside, what a badly designed system!... they are inside all the way but never end screwing (of course, makes no sense to screw foam!). I guess that a hard side landing will rip them appart on the inside thanks to this 2 screws that actually don't go out either.... pffff! Please let me know if i'm too much off the mark with them. Also, I think our Bixler2 is so underpowered cause of the bent shaft that Hobby King stated will help us replace. |
I've think I read here that a been shaft will make it fly like youv'e got the prop on backwards. DJ |
Canada
Joined Jul 2009
My first flight (before I burned out the stock motor) was not as you described. Mine as able to climb and accelerate with full flaps deployed. Still not real impressive but not as weak as yours. Now that I've got another motor in there, my Bix 2 moves quite well. I now have a 3-bladed prop installed (same pitch and diameter) but haven't tested yet due to windy conditions at the moment. I concur about the stupid wing attachment screws. Mine don't screw all the way in either and I need to carry tweezers to extract them after. A truly dumb system. Magnets or velcro will be in the works. |
Joined Jul 2012
Hi, well, it was a bit windy.. not more than 20km but still it could be that conditions were not helping to lift the plane.. also, since the wings somehow came loose, lots of air flow push was getting lost. PLUS shaft is bent as per "factory default"!
Obviously all that will sum up, and leave me also perplexed. I will see if i can get a motor tomorrow now that HK said they will reimburse me for it. Hope to get the stock one out in a simple way. Any tip on that front I should pay attention to? Tx! |
| Thread Tools | |
| Discussion Hobby King Buddy codes for Bixler FPV Build | xxdixonxx | Hot Online Deals | 0 | Jun 19, 2012 12:51 AM |
| Discussion Hobby King Bixler motor? | wehrwolfzug | Electric Motor Design and Construction | 2 | May 17, 2012 05:10 PM |
| Discussion Hobby King USA Warehouse wait time for bixler and 9x? | elcid79 | HobbyKing | 11 | Apr 21, 2012 12:04 AM |
| Discussion Hobby king Bixler Buddy Code | aaluu | Foamies (Kits) | 1 | Feb 23, 2012 12:06 PM |
