Was thinking of this set up for the B2 also. |
Stock motor doing takeoffs from the grass.
Ok the stock motor will do take offs from grass , but flaps need to be used.
I just ordered the 2826 and some different pitch 7 inch props.
The performance of a 'snap to flaps W / elevator' is only good at one speed right? DJ |
Canada
Joined Jul 2009
I'm not sure I know what you mean by your last question. I think you are asking if the flap deployment on a TX that has no speed adjustment for flap activation, will the mixed in elevator activate at the same rate? I believe it does. If you use a servo speed reducer on the flaps, the mixed in elevator will still activate quickly, which could cause a sudden momentary dive. Best to not use mix if you have that kind of TX. |
Just to clarify for those who may not know better -- by "high enough" Xviper is referring to the degree to which the flaps are deployed -- not the direction.
Flaps deploy down from neutral, and spoilers deploy up. Flaps give you more lift and reduce the speed at which you'll stall -- where spoilers deployed as spoilerons rather than from mid chord kill lift but make the airplane prone to tip stalling. |
![]() with my 1.2kg fpv Bix2, i flick the switch to full down flaps and she balloons nose high but just as quickly settles to level flight... yet my step son's Bix2, lightship and rock stock using a 2200mah, deploy flaps and she really balloons and needs elev mixed in. It was blowing when I played with the flaps, too difficult to get the mix accurately, but didnt seem to need slow movement mixed in, just some down elev when the flaps are deployed I must say the difference in flight characteristics between my laden fpv B2 and step son's 750kg-ish B2, is quite substantial... LOS I wanted to keep flying his B2, a bunch of fun
Joined Jul 2012
So had my kit for a few weeks and managed to get everything I needed for my first flight (both the planes's and mine)
Went out to the local club to introduce myself and found some really nice helpers who got me setup. It was the first B2 they had seen and after a nice launch they were commenting about how stable it was without being slow. Got it up high for me in a circuit then handed me the control's, I hadn't got the downrate set quite right so after a few circuit's I got slightly confused and nose dived under power. Did a bit of damage but no where near as bad I was expecting since it was a ~75ft drop into hard ground - Enough to throw the battery (2200mah) clear of the wreck a good 20ft. Going to be in the shop for a bit to repair tho |
| Thread Tools | |
| Discussion Hobby King Buddy codes for Bixler FPV Build | xxdixonxx | Hot Online Deals | 0 | Jun 19, 2012 12:51 AM |
| Discussion Hobby King Bixler motor? | wehrwolfzug | Electric Motor Design and Construction | 2 | May 17, 2012 05:10 PM |
| Discussion Hobby King USA Warehouse wait time for bixler and 9x? | elcid79 | HobbyKing | 11 | Apr 21, 2012 12:04 AM |
| Discussion Hobby king Bixler Buddy Code | aaluu | Foamies (Kits) | 1 | Feb 23, 2012 12:06 PM |
