Old Mar 04, 2013, 09:32 AM
dangerdan is offline
Find More Posts by dangerdan
dangerdan's Avatar
Canada, ON, Hamilton
Joined Nov 2012
Originally Posted by aeronca View Post
Thanks, TechJunkieRC! I'll have to order a bundle for my hangar mechanics.
Aeronca
FYI - Here is another option. These have the hooks already installed.
http://www.hobbyking.com/hobbyking/s...5pcs_bag_.html
dangerdan is offline Find More Posts by dangerdan
Old Mar 04, 2013, 10:17 AM
BlinkguY is offline
Find More Posts by BlinkguY
BlinkguY's Avatar
United States, NJ, Newark
Joined Nov 2005
I know its been talked before, but i have to buy a motor within an hour, so i dont have the time since im at work, to look at the whole stuff. I need a good motor for this kit a little more powerful than stock... im not a speed demon so there you go guys.. and it most fit the stock motor mount... please let me know, thanks! got around HK again to give it another try.
BlinkguY is offline Find More Posts by BlinkguY
Old Mar 04, 2013, 11:04 AM
datura is offline
Find More Posts by datura
datura's Avatar
United States, TX, Austin
Joined Dec 2012
A lot of people like this one: http://www.hobbyking.com/hobbyking/s...ner_Motor.html
datura is offline Find More Posts by datura
Old Mar 04, 2013, 11:16 AM
BlinkguY is offline
BlinkguY's Avatar
Joined Nov 2005
Originally Posted by datura View Post
stock prop?
Old Mar 04, 2013, 11:24 AM
TechJunkieRC is offline
Find More Posts by TechJunkieRC
Gone Flying
TechJunkieRC's Avatar
United States, IN, Covington
Joined Dec 2012
looks like a good option!
TechJunkieRC is offline Find More Posts by TechJunkieRC
Old Mar 04, 2013, 12:02 PM
mlp666 is offline
Find More Posts by mlp666
Mark
mlp666's Avatar
United Kingdom, England, Moreton-in-Marsh
Joined Oct 2012
stock prop?
The stock prop is to large for that motor. Just right for this one.
http://www.hobbyking.com/hobbyking/s...er_1450kv.html
Mark
mlp666 is offline Find More Posts by mlp666
Old Mar 04, 2013, 08:04 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Mark
+1. Great call....
AJ
ajbaker is offline Find More Posts by ajbaker
Old Mar 04, 2013, 08:16 PM
Sculptor is offline
Find More Posts by Sculptor
AKA, Cheap Chiseler
Sculptor's Avatar
United States, FL, North Fort Myers
Joined Mar 2012
Originally Posted by ajbaker View Post
+1. Great call....
AJ
How's the puppy coming along AJ? This might be off-topic but I'm sure many of us would like to know.
I'll be launching my plane over the wide and tropical Colusahatchee River from my backyard and my grandkids will man a SAR canoe. Is it true that you can drowned the electronics in "corrosion X" and you're good to go?
DJ
Sculptor is offline Find More Posts by Sculptor
Old Mar 04, 2013, 08:56 PM
eckace1 is offline
Find More Posts by eckace1
OFF TOPIC POSTER
Des Moines IA
Joined Dec 2005
DJ we have dunked our planes in muddy Iowa rivers with no ill efect just make sure it is completly dry before atempting further flights.
eckace1 is offline Find More Posts by eckace1
Old Mar 04, 2013, 09:50 PM
Sculptor is offline
AKA, Cheap Chiseler
Sculptor's Avatar
Joined Mar 2012
And I've been told by my flight instructor, just clean it out and let it dry. But he also told me, if your flying in salt water you're gonna have trouble!
DJ
Old Mar 05, 2013, 01:27 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Bixler video
DJ
Without going into too much detail, Sculptor is doing great. Here is a picture and I have a video that I have to upload. He poops about 5-6 times a day and has the runs. A Bissel carpet cleaner is on order. The vet gave us some medicine which he hates. I flew my Bix2 yesterday without much fanfare. I took a video but it would be boring to post it. Thanks for asking.
AJ
Old Mar 05, 2013, 07:19 AM
Bertsjuhn is offline
Find More Posts by Bertsjuhn
Joined Jan 2012
I solved my issue of the tight fit with the cables by enlarging the hole where the cables have to go through.
This makes it a lot more easy to get everything inside the fuselage.
The problem with the wings not screwing together I also solved, when holding them in place without the fuselage between them I saw that the holes did not lined up with eachother. So I cut away some foam so that they do fit.
Then I tried putting the screw in the wing that goes on top, that made the holes so the screws will fit in.
This solved my wing problem
So no messing with magnets or velcro
Bertsjuhn is offline Find More Posts by Bertsjuhn
Old Mar 05, 2013, 12:12 PM
Patatduif is offline
Find More Posts by Patatduif
Patatduif's Avatar
The Netherlands, NH, Amsterdam
Joined Jun 2012
Bixler screw solution
Here’s my solution for the Bixler screw problem. I used some iron wire to easily place and remove the screws. I also used my Dremel to cut away some of the head of the screw. So far it still works
Patatduif is offline Find More Posts by Patatduif
Old Mar 05, 2013, 12:47 PM
aeronca is offline
Find More Posts by aeronca
The figure "9" Specialist
aeronca's Avatar
A Barrier Island in New Jersey, USA
Joined Oct 2003
Necessity wins again - nice solution!
Aeronca
aeronca is offline Find More Posts by aeronca
Old Mar 05, 2013, 01:22 PM
Sculptor is offline
AKA, Cheap Chiseler
Sculptor's Avatar
Joined Mar 2012
AJ
AJ, is "crow" the same as air brakes? Here in the River the wind is always coming out of the South and I live on the north side of the river. I should have no problem launching into the wind I'm gonna have to bring it back and landed coming down tomorrow have to put it down in about 50 feet of yard. I've never practice landing downwind. You think I can even get this plane on the ground coming downwind?
Angelo sculptor Baker is just gorgeous. Studying your photo of him I projected forward in time to what he will probably look like when he's fully grown. Then I knocked out this 3D sketch. See what you think.
DJName: Sculpt21 copy.jpg
Description:
Discussion Hobby King USA Warehouse wait time for bixler and 9x? elcid79 HobbyKing 13 Jun 09, 2014 08:13 AM
Discussion Hobby King Bixler motor? wehrwolfzug Power Systems 6 Mar 01, 2014 11:33 AM
Discussion Hobby King Buddy codes for Bixler FPV Build xxdixonxx Hot Online Deals 0 Jun 19, 2012 12:51 AM
Discussion Hobby king Bixler Buddy Code aaluu Foamies (Kits) 1 Feb 23, 2012 12:06 PM
