Old Feb 19, 2013, 10:42 PM
datura is offline
Find More Posts by datura
datura's Avatar
United States, TX, Austin
Joined Dec 2012
Originally Posted by BarefootNick View Post
Got the chance to take the Bixler 2 for a ride in the Black Hills of South Dakota. It went very well and I'm still learning!
http://www.youtube.com/embed/vuy2bZ-MDCg
Really nice glides! I think you just taught me a new way to fly
Now if only I had some mountains...
I'll bet your neck was sore after that one. How much altitude do you think you had at the high points?
Cheers!
Justin
datura is offline Find More Posts by datura
Old Feb 20, 2013, 01:13 AM
agedflier is offline
Find More Posts by agedflier
Australia, VIC, Bendigo
Joined Jan 2012
Angry Bird
DJ...We are about the same "vintage" so any exchange of ideas is always helpful.
If the forum would let me indulge...Just for you...The strange item in the background is a biscuit barrel in the form of the "ANGRY BIRD" from the PC game..Not sure if copyright would prohibit you from making a like image..
agedflier is offline Find More Posts by agedflier
Old Feb 20, 2013, 01:20 AM
Joined Jan 2012
Barefoot..that is some very impressive scenery..Very much like in my old country..Scotland..How much "power" did you use and was there much "updraft"..I will try find a copy of the old Doris Day song and DJ and I could sing you a duet...haha
Old Feb 20, 2013, 04:26 AM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
Welp, almost there. Everything seems to be in order... Now I just wait for a sunny Saturday.
http://imgur.com/a/9kDxK
And on a random note.. I hate the stickers on this thing. If you so much as touch them, they just peel right off. It takes little to no effort to remove them. Bit of a shame since they actually look pretty good.
So I'm using the NOVA only for the GPS and current sensor, the IR sensor has been unplugged since it does not work in the Swedish winter weather. I've got a Crius AIO Pro with Arudplane in the middle. Receiver is an RmileC 433mhz unit, with antennas in a V shape. GPS works, RSSI works, the controls react like they should, the surfaces move like they should when the FC is set to "stabilize". Wing spar has been reinforced, foam inserts have been glued in and then taped. Underside and nose have been reinforced with glass-fibre lined tape. I will reinforce the elevator and rudder later, it's not a must but it won't hurt.
WiseDuck is offline Find More Posts by WiseDuck
Old Feb 20, 2013, 10:32 AM
elimsprint is online now
Find More Posts by elimsprint
Oh No, not again!!!
Canada, BC, Kelowna
Joined Sep 2003
Originally Posted by Stefan_Go View Post
Yeah, my understanding is that the same watts mean less amps at higher volts. So from there I concluded that a 4S 1000KV motor draws less amps than a 3S 1300KV motor at same rpm with same prop. Unfortunately, the prop size on the B2 is almost maxed out with 7 inches. Otherwise I would look at a 750KV motor with, say, a 9 inch prop.
I know ecalc, but unfortunately the 3 motors (Bixler2 stock and 2826/2836-1000) are not in ecalc and HK doesn't provide all data.
Get one of these http://smallpartscnc.com/index.php?r...product_id=135 and mount your 9" prop
Kim
elimsprint is online now Find More Posts by elimsprint
Old Feb 20, 2013, 10:38 AM
PeterGriffin is offline
Find More Posts by PeterGriffin
Joined Jan 2007
Anyone order a Bixler 2 recently (Monday when they were back in stock in the US) and have an issue with their payment clearing? I always use paypal with HK and usually the order status changes to "Paid" ASAP. I ordered right away when I got the stock arrival notification. However, I checked the order status yesterday morning and it still said "Unpaid" despite having received an email receipt from Paypal indicating a sent payment to Hextronic etc. SO, this morning I finally contact them through their online chat (which is subpar at best), they clear the payment, but of course the Bixler 2 is now on backorder. First time this has happened to me with HK. A bit frustrating to say the least consider these kits only get stocked once ever 6wks or so.
PeterGriffin is offline Find More Posts by PeterGriffin
Old Feb 20, 2013, 11:59 AM
dangerdan is offline
Find More Posts by dangerdan
dangerdan's Avatar
Canada, ON, Hamilton
Joined Nov 2012
Originally Posted by craigblk View Post
Agedflier
Didn't have the luxury of the kit version so just cut some of the packaging and used it as the battery tray, works a treat; did cut away some of the ribs inside the nose though, delicate operation given the space available through the hatch.
Do I see a rear elevator servo in that picture ? See POST 2133
Where is the rudder servo ?
dangerdan is offline Find More Posts by dangerdan
Old Feb 20, 2013, 12:08 PM
BarefootNick is offline
Find More Posts by BarefootNick
Joined Aug 2012
Cheers!
Justin
I can tell you I'm hating going back to eastern SD where I live. I could get really accustomed to flying in mountains!
I'm not sure on altitude.... It's such a challenging metric to eyeball from the ground. 3-500 meter? How far away is a Bixler2 when you can't make out hardly anything but a white dot anymore? Most of the unsteadiness in the video is from me trying to figure out if I'm going up/down/upside down.
I'm too new to really know much about what I'm doing. I meant to ask in this thread if someone can point me to a good resource on gliders. A book or similar that'll take me from clueless to slightly less clueless. Another thing I'm finding is that it's really challenging to gauge updraft etc. when your point of view is from the ground. I really need FPV capabilities! (Next winter project).
I don't specifically know about updraft, but even if there was some, I think I sabotage the effort willingly as I glide with flaps at half lowered. It results in a steady slow decent and was ideal for the area as there were lots of opportunity to lose the plane in trees, on mountainsides and in rivers.
Until clearing the trees I'm at 100% throttle. Then I back it down to about 85% until I get to altitude. I don't feel I get much from the last 15% other than reduced battery life. I found very fast that making sure the prop is balanced makes a world of difference. The prop doesn't fit worth $#%! on the motor shaft, but with some tape and wizardry it spins as true as I think it can. No vibration, significantly reduced noise and seemingly increased power. I'm only on page 40 of this thread, so I'm sure the prop has been discussed a million times already.
BarefootNick is offline Find More Posts by BarefootNick
Old Feb 20, 2013, 12:35 PM
dangerdan's Avatar
Joined Nov 2012
Here are a few links that I have used ..
http://www.rcgroups.com/forums/showt...t=aileron+flap
http://www.wattflyer.com/forums/showthread.php?t=31368
http://www.rcgroups.com/forums/showthread.php?t=1366200
http://www.flyesl.org/forums/topic.asp?TOPIC_ID=255
http://www.orlandobuzzards.org/?page_id=892
http://www.rc-airplane-world.com/rc-...ng-setups.html
http://www.rcdiscuss.com/showthread....ensive-Article
http://www.rcgroups.com/forums/showt...6#post24125648 Post 1283
I hope they help ??
Old Feb 21, 2013, 11:54 AM
keninvic is online now
Find More Posts by keninvic
Joined Jan 2012
I ordered one right away, paid with paypal, it hasnt shipped yet but says it is at the "being packed" phase. I have had that happen too - you have to stay on top of the order in the early stages - sometimes there are glitches between HobbyKing and paypal.
keninvic is online now Find More Posts by keninvic
Old Feb 21, 2013, 01:40 PM
CorporalB is offline
Find More Posts by CorporalB
computer geek
CorporalB's Avatar
United Kingdom, England, Chippenham
Joined Dec 2010
well I've been away from the bixler 2 thread for ages, and there's a lot to catch up on lol
I havent flown mine for a while, I've been preoccupied with my funjet and my quad but fingers crossed I'll get it back in the air soon.
CorporalB is offline Find More Posts by CorporalB
Old Feb 23, 2013, 12:34 AM
TechJunkieRC is offline
Find More Posts by TechJunkieRC
Gone Flying
TechJunkieRC's Avatar
United States, IN, Covington
Joined Dec 2012
CorporalB:
I have seen pictures of your Bixler and read your blog on the build while I was trying to learn about the Bixler and RC flying in general. You Sir have a fine machine that is being neglected. I for one feel that your Bixler neglect is simply unacceptable and requires you to surrender it to me immediately!
TechJunkieRC is offline Find More Posts by TechJunkieRC
Old Feb 23, 2013, 07:07 AM
AscotRC is offline
Find More Posts by AscotRC
Dave
Australia, QLD, Brisbane
Joined Apr 2012
Originally Posted by TechJunkieRC View Post
CorporalB:
I concur - I'm getting out early tomorrow morning before the rain hits, I'm sure @ aussiehoppy knows what I'm talking bout!
AscotRC is offline Find More Posts by AscotRC
Old Feb 23, 2013, 07:40 PM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
I love flying my Bixler 2 but having dicovered that there are some similar models of 2 meters and 2.4meters span I am thinking of upgrading to the bigger size.
I am planing a month long holliday in Thailand and Laos in two months time so I will wait until I have returned from this trip bfore purchasing the larger model. Maybe by then Hobby King will have a larger version of the Bixler.
http://www.rc4y.com/rc4y-new-fpv-epo...ane-p-501.html
http://www.bananahobby.com/super-sky-surfer.html
Ken
kensp is offline Find More Posts by kensp
Old Feb 24, 2013, 01:09 AM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Ken
Make sure and check the prices w/shipping to your address. I am in the USA and it is only $4 more (to my doorstep) for the 2400mm ws from BH including servos, ESC, and motor . Austraila will be different I suspect.
Oh, the one from rc4y.com is a 2000mm ws with no electronic parts whatsoever.
AJ
ajbaker is offline Find More Posts by ajbaker
Discussion Hobby King USA Warehouse wait time for bixler and 9x? elcid79 HobbyKing 13 Jun 09, 2014 09:13 AM
Discussion Hobby King Bixler motor? wehrwolfzug Power Systems 6 Mar 01, 2014 12:33 PM
Discussion Hobby King Buddy codes for Bixler FPV Build xxdixonxx Hot Online Deals 0 Jun 19, 2012 01:51 AM
Discussion Hobby king Bixler Buddy Code aaluu Foamies (Kits) 1 Feb 23, 2012 01:06 PM
