Old Aug 01, 2012, 09:51 AM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
Hobby King Bixler 2
HobbyKing Super Daily - HK Bixler 2 (6 min 35 sec)
Hobby King Bixler 2 available!
Larger, many improvements including optimized cockpit for FPV, installed/hinged flaps.
http://www.hobbyking.com/hobbyking/s...laps_ARF_.html
Doubletap is offline Find More Posts by Doubletap
Old Aug 01, 2012, 09:53 AM
Doubletap's Avatar
Joined Jul 2005
Hobby King Bixler 2 Features/Specifications
Features:
Easy and Fun to Fly
Easy, Fast and Simple Assembly
New Larger Canopy area to accomodate FPV equipment and/or larger Flight Lipo
Pre-Installed Servo's & Brushless Motor
Larger Wing Span for greater glide & Payload Carrying Capability
Plastic Landing Skid
New, lower kv Brushless Motor/larger Prop Combo for Greater Efficiency
Pre-Installed Optional Flaps Mounted on Plastic Hinges (require Servo's for operation - not included)
Plug In Wings for Easy Transportation
Pre-Installed Round Pin Hinges on Rudder & Elevator
Includes:
Instructions
Screwdriver
Glue
2 x Y-Lead
Hook & Loop
Spare Clevise x 2
Horns & control Rods for Optional Flaps
Specs:
Material: EPO Foam
Wingspan: 1500mm
Length: 963mm
ESC: 20A (required)
Flying Weight: 760g
Motor: 2620-1300kv Brushless Outrunner (Included)
Prop: 7x5
Servo: 4 x 9g (Included)
Required:
1 x 20A ESC
4~5 Channel Transmitter and Reciever
1800mAh~2200mAh 3s Lipoly Battery
2 x 9g Servo For Flaps (Optional)
1 x Servo Reverser if using optional flaps with non-computer radio
Old Aug 01, 2012, 11:04 PM
Doubletap's Avatar
Joined Jul 2005
will wait a little bit to see when this model will arrive at the WA USA warehouse, or if I can't resist, will order from the Int'l warehouse.
Old Aug 02, 2012, 12:29 AM
heinduplessis is offline
Find More Posts by heinduplessis
Foam Snow
South Africa, WC, Cape Town
Joined Aug 2011
Ordered! Can't wait..
heinduplessis is offline Find More Posts by heinduplessis
Old Aug 02, 2012, 12:33 AM
Doubletap's Avatar
Joined Jul 2005
HaHa! I'm going to try to hold out a little longer than you. Be sure to post your impressions of the kit in a couple of weeks when you receive it.
Old Aug 02, 2012, 10:27 AM
mike_o is online now
Find More Posts by mike_o
mike_o's Avatar
Denmark, NŠrum
Joined Jan 2012
I'd say the increased wingspan (1400mm -> 1500mm) is the strongest temptation for me. But with the default shipping its $112 ($96 with the cheapest) making it more expensive than the Multiplex EasyStar2 and prone to customs interception, so that's a "no thanks" for me.
Perhaps when it hits the German warehouse, if the price doesn't balloon too much.
The semi transparent cockpit doesn't look really convincing for FPV for me...
mike_o is online now Find More Posts by mike_o
Old Aug 02, 2012, 11:40 AM
Jυđgє Gคbrคηŧђ is offline
Find More Posts by Jυđgє Gคbrคηŧђ
Imperial Archadian Ministry
Jυđgє Gคbrคηŧђ's Avatar
United States, TX, Mission Bend
Joined Jul 2010
Jυđgє Gคbrคηŧђ is offline Find More Posts by Jυđgє Gคbrคηŧђ
Old Aug 02, 2012, 04:07 PM
Rocketman1092 is offline
Find More Posts by Rocketman1092
Purdue Engineering
Rocketman1092's Avatar
United States, CA, San Diego
Joined Jan 2005
I hope they offer this as a kit. In my opinion, it's much easier to build an FPV model "from the ground up" rather than adding video gear to a PNP airplane. Especially since the fuselage halves appear to already be joined.
Rocketman1092 is offline Find More Posts by Rocketman1092
Old Aug 02, 2012, 09:28 PM
Westwood is offline
Find More Posts by Westwood
Canada, BC, Burnaby
Joined Oct 2010
ordering one now will post video here after
here is my old Bixler flight at peak of mountain
Stawamus chief Squamish BC HK Bixler Gopro hero2 (4 min 4 sec)
I'll try bixler2 at later day
Westwood is offline Find More Posts by Westwood
Old Aug 03, 2012, 11:31 PM
Doubletap's Avatar
Joined Jul 2005
Awesome! Anxiously waiting for your video in a couple of weeks or so.
Old Aug 04, 2012, 03:51 AM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
I am not impressed. After my experience with the MK 1, I would like to see a kit form without the hardware.
A larger wing span? What ? 100mm, 4 inches = 2 inches on each wing. Big deal..
FPV suitable? Where would you put the FPV gear such as the OSD? Not in the belly as there are the screws that hold on the wings in the way.
The hinges on the control surfaces are an improvement, but that is from a lesson learnt the hard way, as I have had the original foam hinge break, as I feel sure others have.
No I will not be getting one, as I already have a MK 1 with the mods. Also I have 4 other similar models. 3 EZ*s, one that is my FPV, and a Rookie.
Flypoppa is offline Find More Posts by Flypoppa
Old Aug 05, 2012, 08:26 AM
Doubletap's Avatar
Joined Jul 2005
Didn't take long (3 days), the first load of Bixler 2 is already sold out.
Old Aug 05, 2012, 10:31 AM
Crashpc is offline
Find More Posts by Crashpc
Joined Jul 2012
Yep. Wanted to buy my first plane, and was happy about Bixler 2. Went to odrer this one about "now", but what a pitty. Now i feel bad for it, because I want to buy it next week. I will have to buy something waaay different like Phoenix.
Crashpc is offline Find More Posts by Crashpc
Old Aug 05, 2012, 02:28 PM
Joined Jul 2010
This is a larger wing span! A Sky Surfer on steriods...
http://www.bananahobby.com/2391.html
Old Aug 05, 2012, 04:51 PM
road_rascal is offline
Find More Posts by road_rascal
Joined Dec 2008
Holy 'effing frak.... That's a big Sky Surfer. Thanks for linking that!
road_rascal is offline Find More Posts by road_rascal
Discussion Hobby King USA Warehouse wait time for bixler and 9x? elcid79 HobbyKing 13 Jun 09, 2014 08:13 AM
Discussion Hobby King Bixler motor? wehrwolfzug Power Systems 6 Mar 01, 2014 11:33 AM
Discussion Hobby King Buddy codes for Bixler FPV Build xxdixonxx Hot Online Deals 0 Jun 19, 2012 12:51 AM
Discussion Hobby king Bixler Buddy Code aaluu Foamies (Kits) 1 Feb 23, 2012 12:06 PM
