This thread is privately moderated by Kauz, who may elect to delete unwanted replies.
Old Aug 01, 2012, 07:37 AM
Kauz is offline
Find More Posts by Kauz
Fly low...fly slow
Kauz's Avatar
Somewhere in the Black Forest
Joined Oct 2009
Mini-HowTo
Parkzone Albatros DVa - The rigging
In mid June the Parkzone Albatros was available here in Germany. It was certain for me that if I had her at home, I would do some additional detailing and a repaint. This bird is really worth it! I want to start my overview on the things I did with the rigging. What you need is: aluminum tube from your local LHS, outer diameter 2mm, inner diameter 1mm, cotter pins 2mm in diameter and 40mm in length, you have to cut them shorter so they do not need to be that long, but my DIY- store did have only this type. And last, for the rigging itself, elastic cord used for making jewelry. It is available in different colours and on the full size Albatros these wires had a silver colour so it would be the easiest way to choose silver too. I went a different way by using black cord which I painted silver after completion. This may sound strange as it is more work to do, but when you paint your cord there will always be the black basic colour shimmering through the streaks of your paint brush, thus giving the rigging a used look as the wires aged over time, gathering dirt and grease which collected between the single thinner wires of which they were made. I divided my rigging diagram into three parts, as my rigging is made up of three parts too. The attached photos and the text within the photos should help a lot.
And now: Good luck
Frank
Kauz is offline Find More Posts by Kauz
Old Aug 01, 2012, 10:07 AM
TripleW is online now
Find More Posts by TripleW
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
I love what you've done with the Albatross!
Absolutely Stunning!
TripleW is online now Find More Posts by TripleW
Old Aug 01, 2012, 10:16 AM
ddog343 is offline
Find More Posts by ddog343
ddog343's Avatar
United States, WI, Oconomowoc
Joined Feb 2011
And now: Good luck
Frank
TopDog and "One of a Kind" work on the Alby, really Outstanding!
And nice and detailed blog post!
Thanks for posting!
and FLYFLYFLY
ddog343 is offline Find More Posts by ddog343
Old Aug 02, 2012, 02:25 AM
Kauz is offline
Fly low...fly slow
Kauz's Avatar
Joined Oct 2009
Thanks to you both
And ddog: I WILL I WILL I WILL
Old Aug 05, 2012, 05:27 AM
-=RAGE=- is offline
Find More Posts by -=RAGE=-
Heli & Warbird Fan
-=RAGE=-'s Avatar
Bavaria, Germany
Joined Jun 2009
Well done, Frank!
-=RAGE=- is offline Find More Posts by -=RAGE=-
Old Aug 05, 2012, 02:27 PM
Kauz is offline
Fly low...fly slow
Kauz's Avatar
Joined Oct 2009
Thanks Rage
Old Aug 05, 2012, 02:33 PM
Kauz is offline
Fly low...fly slow
Kauz's Avatar
Joined Oct 2009
By reading over my post I noticed there was something missing- the rigging of the landing gear! I had completely forgotten to post it So to finish my "how -to", here it is...
Frank
Old Apr 16, 2013, 09:40 AM
Avenger Pilot is offline
Find More Posts by Avenger Pilot
Avenger Pilot's Avatar
United States, IL, Springfield
Joined Apr 2013
Very nice work indeed.
May I ask you if you thought this bird was nose heavy? I have searched and searched and can not find any info on this, if anyone thinks this airplane is nose heavy.
Your thoughts on this would be great.
Thanks for posting this thread great work.
Avenger Pilot is offline Find More Posts by Avenger Pilot
Old Apr 21, 2013, 06:02 AM
Kauz is offline
Fly low...fly slow
Kauz's Avatar
Joined Oct 2009
Thank you I didn't find this bird to be nose heavy, even with my 2200's. In my opinion it balances perfectly.
Frank
Old Apr 22, 2013, 05:11 PM
Joined Apr 2013
I found you are missing one wire. It goes on the front. Mount another cotter pin about 1 inch under the other cotter pin up by the spinner. Then run a wire from this to the back brace on the top or top rear brace.
Old Apr 22, 2013, 05:12 PM
Joined Apr 2013
http://en.wikipedia.org/wiki/File:Al...rshow_2012.jpg
You see this wire in this photo
Old Apr 23, 2013, 06:52 AM
Kauz is offline
Fly low...fly slow
Kauz's Avatar
Joined Oct 2009
I didn't install this wire by purpose. On many historical photos it is simply missing, so I opted for this layout.
Old May 09, 2013, 05:38 PM
MartinT is offline
Find More Posts by MartinT
MartinT's Avatar
Joined Mar 2006
This is seriously nice work!
Thanks for all your rigging work, I've got my Alby on the way, and I'm looking forward to making it look better!
MartinT is offline Find More Posts by MartinT
Old May 13, 2013, 08:11 AM
Kauz is offline
Fly low...fly slow
Kauz's Avatar
Joined Oct 2009
You're welcome and good luck
Frank
Old Jun 23, 2013, 10:43 AM
pmacko is offline
Find More Posts by pmacko
Go 4th Air Force
pmacko's Avatar
United States, PA, Washington
Joined Sep 2011
I followed Franks directions with my PZ SE5a and couldn't be happier with the results. Now on to my Albatros (and everyting else that needs rigging)
Paul
pmacko is offline Find More Posts by pmacko
Build Log Aerodrome RC 36" Albatros DVa phillip57 Scale Kit/Scratch Built 159 Feb 07, 2016 04:53 PM
Build Log 1:24 scale DVa Albatros - non ar6400 nemoskull Scratchbuilt Indoor and Micro Models 3 Apr 10, 2012 02:10 PM
Discussion Albatros DVa photos and free plans AerodromeRC Scale Kit/Scratch Built 22 Nov 06, 2001 04:08 PM
Albatros DVa Spinner question AerodromeRC Scale Kit/Scratch Built 6 Sep 24, 2001 02:23 PM
