Old Nov 16, 2012, 11:43 AM
MPP is offline
MPP
Find More Posts by MPP
MPP
In Unusual Attitude Recovery
MPP's Avatar
Danbury CT (DXR)
Joined Oct 2005
Charles, you really have mastered insert planking. looks great. Might want to get the Dremel in on those rear formers before you add more logerons. The spit has a short nose and the arm really takes an effect. Keep up the great work! Don't neglect the B-25 even though you seem to be keen on the Spitfire. I imagine you will have them both airworthy before I finish. BTW I see you have a few more Guillow's in the stash. You are officially one of us crazy Guillow's converters
Best,
Mark
MPP is offline Find More Posts by MPP
Old Nov 16, 2012, 11:52 AM
Bare is online now
Find More Posts by Bare
Canada
Joined Nov 2000
An interesting and Scale variant : The Beer delivery Spit.
Bare is online now Find More Posts by Bare
Old Nov 16, 2012, 12:04 PM
Steve85 is online now
Find More Posts by Steve85
The "pro" in procrastination
Steve85's Avatar
Canada, ON, Kingston
Joined Mar 2004
Looks like insert planking is good physiotherapy!
Steve
Steve85 is online now Find More Posts by Steve85
Old Nov 16, 2012, 04:06 PM
glewis is offline
Find More Posts by glewis
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Nice job on the insert planking on this and your B-25.
Not one of my favorite tasks, but kind of relaxing once you get into it.
Glenn
glewis is offline Find More Posts by glewis
Old Nov 16, 2012, 04:27 PM
ccc1970 is offline
Find More Posts by ccc1970
United States, FL, Jacksonville
Joined Nov 2010
what thickness is the balsa you use for the planking?
ccc1970 is offline Find More Posts by ccc1970
Old Nov 19, 2012, 02:10 AM
Spitfire1954 is offline
Find More Posts by Spitfire1954
Spitfire1954's Avatar
United Kingdom, England, East Riding of Yorkshire
Joined Jan 2011
Thanks for all your kind words, certainly keeps one motivated – insert planking is very therapeutic, the end result is very satisfying with these models because they have such good outlines. Point taken on the Spit Mark, will take out what I can. Steve what better way! have you flown the Lanc yet? Glenn, it is very relaxing especially if you have some of what that Spit is carrying! ccc1970 – am using 3/32" soft balsa for the insert planking.
Best
Charles
Spitfire1954 is offline Find More Posts by Spitfire1954
Old Nov 19, 2012, 07:06 AM
glewis is offline
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Humm, I'm going to have to try that! A pint of Bass Ale before insert planking. Maybe after a couple of pints it would be easier to cut and fit the bits!
Glenn
Old May 21, 2013, 02:26 AM
Joined Jan 2011
Build update It's been quite a while since my last entry on this build, but work has commenced once more! I have almost completed the insert planking on the fuselage using 1/8" soft balsa on the forward half of the fuselage and 1/16" on the rear half. Additional stringers were added to the lower rear half of the fuselage to help create the correct shape. After an initial sanding the complete fuselage including servos weighs 2.6 oz. The tail surfaces were built up over the plan and cut to the scale shape, I used 3/32" stringers on these for a extra strength and will cover using tissue.
Old May 21, 2013, 12:54 PM
Steve85's Avatar
Joined Mar 2004
Glad to see you back on this one, Charles. I should pull mine out of its hibernation and repair the damage inflicted by its last flight (or its last landing, to be more precise...)
Steve
Old May 22, 2013, 09:03 AM
gupi is offline
Find More Posts by gupi
Balsa Lover
gupi's Avatar
Vienna, Austria
Joined Jul 2010
Good to see you back on the Spit! I flew mine quite successfully but she still needs roundels and other markings. And better flying weather!!!
gupi is offline Find More Posts by gupi
Old May 24, 2013, 12:35 PM
TIM HART is offline
Find More Posts by TIM HART
Joined Dec 2011
About bloody time bruv!!!!
TIM HART is offline Find More Posts by TIM HART
Old May 30, 2013, 08:03 AM
glewis is offline
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Are those GWS pico retracts? Going to take some interesting linkage to operate those! The Pico units have the actuator travel in an arc and there is no over-travel.
There is also no positive lock and the servo is holding the wheels up all the time. Maybe you can come with some sort of an over center linkage using a belcrank.
The blue ones the actuator moves linear and there is some over travel and a positive lock. Much easier to set up.
Great job squeezing them in the wing in the scale position.
GLenn
Old May 30, 2013, 08:16 AM
Joined Jan 2011
Hi Glenn – yes these are the GWS Pico retracts – I had also thought about using a central belcrank, I think that is going to be the best solution
Best
Charles
Old Jun 18, 2013, 02:42 AM
Joined Jan 2011
Hi Everyone updated images attached things are moving along quite well, battery hatch has been cut out and should give plenty of room ailerons are completed and hopefully will be large enough! only downside to progress has been the undercarriage, at this point the wheels will be in the down position until I figure out the best way of actuating these efficiently.
Best
Charles
Build Log Guillows 403 Spitfire JazzMan2001 Scale Kit/Scratch Built 59 May 07, 2015 06:34 PM
Question Advice for my Guillows Spitfire 403 electric RC conversion GHoldway Beginner Training Area (Aircraft-Electric) 6 Jan 20, 2012 07:28 PM
Discussion Guillow's #403 Spitfire...yeah... crazysccrmd Scale Kit/Scratch Built 38 Mar 01, 2010 11:37 PM
Cool My Guillows Spitfire is the Model of the Month on the Guillows Website! TMO Scale Kit/Scratch Built 4 Feb 01, 2007 10:44 AM
Help with Guillow's Spitfire.....TIA ramw5p Scale Kit/Scratch Built 10 Aug 30, 2003 02:11 AM
