Old Aug 01, 2012, 07:04 AM
jah00 is offline
Find More Posts by jah00
Pete
jah00's Avatar
New Zealand, Wellington, Lower Hutt
Joined Jan 2005
Looking forward to watching this 400 series build as I work on my FW190. Your B17 was impressive.
Pete
jah00 is offline Find More Posts by jah00
Old Aug 01, 2012, 07:34 AM
Bill Smudge is offline
Find More Posts by Bill Smudge
Bill Smudge's Avatar
United States, KY, Bowling Green
Joined Jul 2011
Watching all the way..
Bill
Bill Smudge is offline Find More Posts by Bill Smudge
Old Aug 01, 2012, 08:55 AM
Spitfire1954 is offline
Find More Posts by Spitfire1954
Spitfire1954's Avatar
United Kingdom, England, East Riding of Yorkshire
Joined Jan 2011
Thanks Pete – what is your AUW target – I am going for retracts (using GWS PICO Mechanical Retracts) – Lipo is a 450mAh Hyperion 2S. Will have A/R/E and castoring tail wheel.
Bill – hope you enjoy!
Best
Charles
Spitfire1954 is offline Find More Posts by Spitfire1954
Old Aug 01, 2012, 02:58 PM
glewis is offline
Find More Posts by glewis
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Cool! I'm signing in too.
This is one on my someday list.
It looks like the laser cut parts fit together very well, unlike the old die crushed crap.
I like your power system and retract ideas too.
I would suggest skipping the castoring tailwheel and connect it to the rudder. I tried a castoring tailwheel twice and the models were impossible to control on the ground. Full scale pilots have the use of the brakes for directional control and we have to rely solely on prop wash over the rudder.
Glenn
glewis is offline Find More Posts by glewis
Old Aug 01, 2012, 03:15 PM
Electriflier is offline
Find More Posts by Electriflier
Watts Matter?
Electriflier's Avatar
UK, South Yorkshire
Joined Feb 2011
Subscribed
Electriflier is offline Find More Posts by Electriflier
Old Aug 01, 2012, 04:45 PM
Smokin' Beaver is offline
Find More Posts by Smokin' Beaver
Registerd Beaver
Smokin' Beaver's Avatar
Australia, WA, Warwick
Joined Jul 2003
Originally Posted by Electriflier View Post
Subscribed
ditto
Smokin' Beaver is offline Find More Posts by Smokin' Beaver
Old Aug 01, 2012, 07:02 PM
jah00 is offline
Pete
jah00's Avatar
Joined Jan 2005
Originally Posted by Spitfire1954 View Post
Thanks Pete what is your AUW target I am going for retracts (using GWS PICO Mechanical Retracts) Lipo is a 450mAh Hyperion 2S. Will have A/R/E and castoring tail wheel.
Bill hope you enjoy!
Best
Charles
I'm aiming for between 250g probably closer to 300grams AUW. I havent done my sums or put all the components on the scales yet.
For retracts I'll be building custom hinges (Sort of like Smokin' Beavers P51). Mainly taking this route because I have 6mm head room at the pivot point (about 10-15mm in from the leading edge). There are mechanical retract sets that would fit that but I fear they would be too light for ROG takeoffs.
Pete.
Old Aug 02, 2012, 12:19 AM
Joined Jan 2011
Hi Glenn – take your point on the castoring tail wheel, I'll do as you suggest
Pete your AUW estimates are in the same ball park as mine – I'm going to aim for the lower figure – Smokin' Beavers P51 build was stunning and was the inspiration for this build – if this turns out anything like I'll be happy
Best
Charles
Old Aug 02, 2012, 05:38 AM
glewis is offline
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Do you have room for the GWS 'blue' retracts? Might be a bit lighter than making wire and brass tube ones as Phil did.
Glenn
Old Aug 02, 2012, 06:02 AM
Joined Jan 2011
Hi Glenn – I'm going to use these GWS PICO Mechanical Retracts
Charles
Old Aug 02, 2012, 08:13 AM
glewis is offline
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
The little black ones?
A bit of warning, those are extremely fiddly to get set up.
There is no overtravel in the mechanism and servo endpoints must be exact. They also don't 'lock' in position and when retracted the weight of the landing gear is borne by the servo full time.
The blue ones have a positive lock and some overtravel in the actuator allowing some leeway in the servo position and linkage geometry.
They are a much better unit, if they will fit your application.
Glenn
Old Aug 02, 2012, 08:59 AM
Joined Jul 2011
Glenn
I'm with Glenn on this one, I had a little castoring tailwheel on my Guillows Champ and it just didn't work at all.
Bill
Old Aug 03, 2012, 12:57 AM
Joined Jan 2011
Hi Glenn – I will look into the Blue GWS units, I'm sure that they could be made to fit – One question that I do have concerns the flat bottom profile of the wing – if this is built as per the kit, will it fly?
Charles
Old Aug 03, 2012, 05:53 AM
glewis is offline
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
I'm not a big fan of that airfoil. It does generate decent lift at a the relatively slow speed of a rubber powered model.This is a good trait for rubber power because the motor delivers most of it's power at the start and you want the model to climb as high as possible.
For our application it has a speed/pitch sensitivity meaning the faster the model travels the more down elevator it will take to keep the nose down.
I had misdiagnosed this problem in the past as both cg and thrust line related and ended up with a model that would fly ok at full throttle but as soon as the power is cut it would drop like a stone.
I modify the airfoil to a Clark Y section by raising the leading edge. This usually requires cutting new ribs but it is well worth the effort because the model will fly much better.
Just looked at the plan and you could raise the leading edge off the board about 3/32". You will then have to add a sliver of balsa to the top of the ribs to compensate. Once the wing is removed from the board sand away the lower front portion of the rib to bring it up to the new leading edge position.
Glenn
Question Advice for my Guillows Spitfire 403 electric RC conversion GHoldway Beginner Training Area (Aircraft-Electric) 7 Mar 21, 2016 05:11 AM
Build Log Guillows 403 Spitfire JazzMan2001 Scale Kit/Scratch Built 59 May 07, 2015 05:34 PM
Discussion Guillow's #403 Spitfire...yeah... crazysccrmd Scale Kit/Scratch Built 38 Mar 01, 2010 10:37 PM
Cool My Guillows Spitfire is the Model of the Month on the Guillows Website! TMO Scale Kit/Scratch Built 4 Feb 01, 2007 09:44 AM
Help with Guillow's Spitfire.....TIA ramw5p Scale Kit/Scratch Built 10 Aug 30, 2003 01:11 AM
