Go Back   RC Groups > Aircraft - Electric - Airplanes > Scale Electric Planes
Old Nov 18, 2003, 06:30 PM   #1
Exotic Dancer
Pork Tornado's Avatar
Should I put ailerons on my Curtiss Jenny?
I'm building the Dare curtiss Jenny, and noticed that in most of my reference photos, it has ailerons. Building it scale would mean a pull-pull system for each aileron, which would mean either some very complicated engineering, or seperate aileron servos. I have sketched it out on the plans to where I am pretty sure it will be doable, but figured I would be well served to ask some of you guys if anyone had tried it, and if it was even feasible.
Were any of the original Jennys rudder/elevator only?
This image shows the ailerons. They are on the top wing only.
Pork Tornado is offline Find More Posts by Pork Tornado   Reply With Quote
Old Nov 18, 2003, 06:33 PM   #2
Exotic Dancer
I guess I should add that I will be using a Speed 300 geared 4:1, or if this mod adds too much weight, an astro 010, which should handle it on 3s lipolys.
Old Nov 18, 2003, 10:50 PM   #3
E-Challenged's Avatar
Ailerons for Jenny
Contact Pat Tritle for advice, his e-mail address is on his website:
www.thuntek.net/pcmodels/
E-Challenged is offline Find More Posts by E-Challenged   Reply With Quote
Old Nov 19, 2003, 01:23 AM   #4
Someone has already converted the Dare Jenny to aileron control with scale like control wires.
Look here:
http://www.rcgroups.com/forums/showt...ighlight=jenny
Dennis
Ta152h is offline Find More Posts by Ta152h   Reply With Quote
Old Nov 19, 2003, 09:42 AM   #5
Exotic Dancer
Thanks much. I'm needling him for the details as we type.
-=D=-
Old Nov 20, 2003, 06:25 AM   #6
Replikit Designer
vintage1's Avatar
If it has less than 5 degrees dihedral I'd say definitely some form of lateral cntrol is needed..Is that what you meant?
Rudder only gets pretty nasty - especially in any turbulence - at less than that.
vintage1 is offline Find More Posts by vintage1   Reply With Quote
Old Nov 20, 2003, 09:22 AM   #7
Exotic Dancer
Yeah, if I built it "really scale" it would have a flat wing, which could go way off the suckmeter when reversing direction with rudder only. From reading the other thread, I learned that the ailerons help to maintain bank during a turn and make it a bit easier to fly. I'm thinking about putting about 2-3 deg dihedral and adding the ailerons to see how that goes.
Old Nov 21, 2003, 11:20 AM   #8
Balsa Flies Better!
Actually, I think the full scale version has some dihedral. While normally I'm a fan of rudder only- my Sterling Jenny was something of a bear on rudder only. Don't know what tweaks Pat has done, but I must admit- long skinny wings in parkfliers don't work real well, and might indeed benefit from ailerons.
Sam
Megowcoupe is offline Find More Posts by Megowcoupe   Reply With Quote
to put ailerons on my slowstick or not? jeff262 Parkflyers 14 Feb 02, 2004 12:09 AM
Ailerons on my HH Electric Scout! Matthew Allen Sport Planes 4 Jul 15, 2002 03:13 AM
Should I put a prop on my Kyo T-33? the#1 Foamies (Kits) 8 Dec 24, 2001 05:32 AM
I put a gb on my T-52 but am having problems with the motor. s_sanders Foamies (Kits) 13 Jul 16, 2001 10:45 PM
What do I need to put a gearbox on my sky scooter?? e-flyer Parkflyers 6 May 25, 2001 01:45 AM
Congratulations SimpleM!
