Joined Jul 2012
Motors:
http://www.hobbyking.com/hobbyking/s...dProduct=15193 Specs: RPM/v: 1100kv Dimensions: 36 x 24mm Shaft: 4.0mm Voltage: 11.1v Weight: 76g No-load current: 1.8a @ 11.1v Max Current: 32A Max Watts: 280W Mounting Holes: 44mm ESCs: http://www.hobbyking.com/hobbyking/s...dProduct=14630 Specification: Cont. Current: 18A Burst Current: 25A Car Size: 1/18th Battery: 2-3 Cell Lipo / 4-9 Cell Ni-XX L-BEC: 5V / 1A Output Motor Type: Sensorless Brushless Size: 30 x 26.1 x 13.8mm Weight: 26g (Including wires) Motor Plugs: 3.5mm Bullet type Battery Plug: Required On/Off Switch: Yes Reverse: Yes Sometimes I have initiated the startup and ran all 3 escs + 3 motors on full throttle for close to 10 minutes while also powering some additional components. If it does shut the PSU off it happens after I engage throttle and then let off. Thanks for the help. |
Joined Dec 2004
I don't know if this is any help, but the multiple 12v rail supplies I've seen don't say the 12v is split in two on the sticker, and are really 7A on one rail and 7A on the other.
I knew this cheap method of advertising more amps would lead to this. Imagine all the poor saps that ended up with their video card and cpu on the same rail, and had to buy a new supply, even though they were only using 51% of what they had. |
| Thread Tools | |
| Discussion What Caused My (electric) Motor To Lose Power? | Buzz_Man | Crash Discussion | 2 | Jul 02, 2012 01:07 PM |
| Sold Blade MCPX mSR Celectra 1S 3.7 DC Li-Po Charger + Power Supply EFLC1006 EFLC1005 | eranrc | Aircraft - Electric - Batteries & Chargers (FS/W) | 0 | May 30, 2012 11:40 PM |
| Discussion Opto ESC causing motor issue | FlyHighSelllow | Power Systems | 8 | Apr 01, 2012 04:45 PM |
| Wanted Power 32 Brushless Outrunner Motor, 770Kv or Power 25 BL Outrunner Motor, 870Kv | Joe Pierson | Aircraft - Electric - Power Systems (FS/W) | 1 | Sep 01, 2010 08:05 PM |
| Discussion Using an AC/DC Power supply to test an ESC+BL motor | Caedes | DIY Electronics | 4 | Jan 27, 2007 12:43 PM |
