Old Oct 03, 2012, 12:37 AM
Chophop is offline
Find More Posts by Chophop
Glad I'm not a Boll Weevil
Chophop's Avatar
Pleasant Valley Modelport
Joined Sep 2006
It is working great for me. I use Plasti-Kote #228 Grey Primer, 500*F resistant. It is not as hard as the epoxy so it's important to go easy on the first layer of windings on a full coated stator. And this is a new can. I found out this stuff uses titanium dioxide, didn't see aluminum oxide listed. My last can used it. I would suppose about any metal oxide will conduct heat better than epoxy or plastic.
Chophop is offline Find More Posts by Chophop
Old Oct 03, 2012, 07:24 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
Yeah, but that titanium is a lot heavier than the aluminum! I can't believe you're getting away with increasing the wing loading like that...
So much good stuff being shared here. It almost time for me to salvage a couple of stators that got pushed to the back dead motor pile.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Oct 03, 2012, 08:41 AM
Chophop is offline
Chophop's Avatar
Joined Sep 2006
Epoxy might cause hot spots under it or prevent winding heat from sinking into the stator. Bad in my book. Thermal conductivity is extremely low, mainly absorptive. The titanium is not as good as al but still much better than plain enamel. I'm going to be sure my next can has aluminum oxide.
You would think any respectable engine enamel and primer would not hold heat in the engine, but transfer it out. Oh well, at least I figured out what I have.
Just for fun, and for those who don't know math can look at the relative properties:
http://en.wikipedia.org/wiki/List_of...conductivities
Old Oct 03, 2012, 09:10 AM
zeroback is offline
Find More Posts by zeroback
United States, FL, Pompano Beach
Joined Oct 2011
On my way to the auto parts store...with my reading spectacles
zeroback is offline Find More Posts by zeroback
Reply With Quote  (Disabled)
Old Oct 03, 2012, 09:21 AM
Chophop is offline
Chophop's Avatar
Joined Sep 2006
Look up the product and it's MSDS sheet on the web first and save the trouble.
Old Feb 02, 2013, 09:03 AM
zeroback is offline
Joined Oct 2011
Nice!
Old Apr 11, 2013, 07:52 AM
zeroback is offline
Joined Oct 2011
After reviewing this thread I see it needs updating. As soon as I'm back online at home I'll do a start to finish post on this process with pictures. In the learning process I tried allot of unnecessary steps, but here it is in a nutshell. KISS comes in handy here.
1) Clean the stator of loose coating and oil.
2) Lay out some foil to catch excess powder and pile on some coating. I use my finger tips and a little shovel I made. The pile can be shoved and flattened with a small screw driver or something, if needed. If you don't like it dump it off and start over.
3) Cook in a convection oven at recommended temp for about 20 Min. I have not tried a regular oven but wouldn't be surprised that it would work fine.
4) Clean up, if needed, is easy with an Exact knife, needle file, sand paper. rotary tool with diamond dust burr, you get the idea, just avoid removing metal.
5) Repeat on other side. The coating does not soften when once cooked.
6) If you don't like the results remove the blemish and re-coat and recook.
This has proven to work very well and holds up to over heat as well.
Old Apr 11, 2013, 11:40 AM
Jack
USA, ME, Ellsworth
Joined May 2008
That is a wonderful summary of how to do it, zero. This is your thread so you can edit post #1, I suggest you put a link in post#1 to the above post as being the one post that best summarizes the best method to do this.
This is a thread that will get frequent mention here, almost every time a winding newbie drops in I think.
Jack
Old Apr 21, 2013, 12:27 PM
zeroback is offline
Joined Oct 2011
See post 1
Old Apr 30, 2013, 10:22 PM
zeroback is offline
Joined Oct 2011
Something to look at, at the end.
Or is it?
Old Jan 31, 2016, 05:14 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Thread added to openining post of
Sticky: (Re)winding and building motors, tips & tricks, checks & tests
Vriendelijke groeten Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Feb 13, 2016, 02:46 PM
Hummina is offline
Find More Posts by Hummina
Joined Jul 2014
How do u erase a whole post ?
Hummina is offline Find More Posts by Hummina
Old Feb 21, 2016, 02:54 AM
Hummina is offline
Joined Jul 2014
With what thermal conductivity do you think coating the windings would be good?
It seems to be very common to pot stators in commercial resins that aren't even that conductive. No one with a model plane does it. Once the heat can get to the motor's aluminum mounting plate it would easily travel to a heatsink/'motor mount, further benefiting from the airflow, maybe even an aluminum external structure of the plane.
I got the very thin fiberglass linked a couple pages back...thought it might be simpler and possibly allow more room for copper. Very disapointing. too hard to do for me. Very hard. I give up. Don't recommend it.
Epoxy remover won't damage the lamination isolation I guess. I'll try that and the powder coat. How did the harbor freight paint go jack?
Old Feb 21, 2016, 07:17 AM
Jack
USA, ME, Ellsworth
Joined May 2008
".. How did the harbor freight paint go jack? ..."
I was not working on a stator that was completely bare of the insulation coating as much as I was working on on stators that had spots of damage where the green coating had flaked off.
I have not used the HF powder paint yet but others here have. So far I have used Tyvek, Nomex, and Kapton I bought in sheet form. Of those three the Nomex seemed to work the best. I also used a Loctite 410 that is a painted on rubberized coating that sets up. That was hard to find and sort of on the expensive side and it went bad and set up in the bottle so I did not pursue it very far.
To remove a stator coating I soaked a stator in Acetone for a day or so and the stator fell apart into a collection of loose plates. That is not a good thing to do as, if I understand it right, you want to have the plates insulated from each other and glued together in a stack with a thin glue.
zeroback gave a good description for using the HF powder here:
Stator coating - www.rcgroups.com/forums/showthread.php?t=1702834
Jack
Old Feb 21, 2016, 08:00 PM
Hummina is offline
Joined Jul 2014
I'd read acetone is bad, I guess it will destroy the thin insulation between plates. I'm still wondering if the epoxy remover will destroy it as well.
Don't want to do that
Discussion 1k or 2k clear coat?or gel-coat? krikkens Composites Fabrication 39 Jul 14, 2012 08:06 AM
Question Stator Coating material lixo Electric Motor Design and Construction 31 May 08, 2011 08:58 AM
Discussion Tired of shorts? New stator coating from CustomCDR. ryanl2006 Electric Motor Design and Construction 39 Jun 16, 2007 06:28 PM
AXI Stator Coating - What IS that stuff? Tom Frank Power Systems 2 Sep 24, 2004 01:17 AM
Best stator coating for bare metal stator? mgdon Power Systems 11 Aug 15, 2004 12:01 PM
