Cheers, JR |
For powder coating I think the sharp edge is needed to keep the stuff acting like a drop of water. I spent many hours trying to polish the sharp edges off stators and haven't found it to be productive. Hit and miss no guarantee all the work will payoff. Although they were 22ish mm or so stators which makes it much harder for the even the Dremal size bits to get into the critical spots. There maybe better results with larger parts.
Latest blog entry: Edge Walker
My stator is a 35mm version so it looks like it would be a little easier to polish. I think the key to polishing it is to form a good radius which will take a lot of time. But it sounds like powder is the way to go. Maybe hi-temp paint can be used inside the poles after powder coating the ends for some added insulation. So now we are back to powder coat. I saw a demo of a plastic pipe device with a coffee filter in the top that held the powder and then air was injected under the filter. Then you just heat the stator to 400 deg and lightly dip the stator in the powder while it is bouncing in the pipe. Is that the best way or can you just touch the hot stator in a can of powder? |
USA, ME, Ellsworth
Joined May 2008
Jack |
Joined Mar 2012
Electroplating shops use a sticky backed thin lead tape for masking parts to be chrome plated. I'm thinking maybe this tape could be use to protect the sharp ends of the stator. Overlap the sharp corners by 10thou or so and fold it over. It trims easily with an x-acto or sheetrock knife blade. The lead would be easier to work with than the more common sticky aluminum tapes.
Dipping the hot stator is one of the tests I plan as soon as I have another stator ready. I don't think anything is going to clean the first tests from this stator but I have it soaking in Epoxy remover right now.
As far as lead tape that might work better than Kapton for masking, although as an insulator to prevent shorts I get the idea, but it's metal. The other factor is anything used to prevent shorts is space more copper can be. That's why I only want to create a radius on the end, and nothing in the slot. I have wound some real thorn bush stators using the "one time use" plastic caps over the ends, short free every-time. But (again) they are thick and add useless wire hanging off the ends which can also create clearance problems with the bell. I have used Kapton tape as the insulator but it is very time consuming to get it where it is needed. I think that the PC is going to work I just need to refine the process, if I don't figure out the easiest way I'm sure some one will. |
Powder Coat
Well I picked up my red powder from HF today and tried what I have seen done on RCG. I used a pickle jar lid with a notch cut out. Put two strands of re-bar wire around the core for a grip. Put the lid on the edge of a table. The notch is so I can dip the core in a vertical orientation.
Used a sanding block with 150 grit machine grade paper until all traces of the old coating was removed. Cleaned both ends with Acetone Toasted it at about 400 deg F for about 12 minutes. Dipped both ends of the stator a couple of times and it came out like the picture below. I think I only needed one dip but with a little detail work with either the dremel or a sanding block it should clean up good. Cheers, JR Thanks for all the great ideas. |
Looks great!
Just make sure with that thickness that you have enough clearance to the ends of the motor when wound. I'm guessing one dip might be just right. Thank you for clearing that up! I also think that the thickness could probably be controlled by the depth of the powder on the surface of the dip pan, or sheet. Seems like a piece of sheet metal would work to lay the powder on. I don't have a HF nearby, so I don't have the powder and don't know how fine it is. But what I use in casting for applying parting dust evenly to a drag might work for laying down an even layer on a pan for dip powder coating -- if the powder is fine enough. I put it in an old sock and tie a knot in the end. Then you can just tap the sock and it dispenses the dust evenly. |
I used an xacto blade to cleanup the center mounting hole and I am now ready to clean the outside of the laminations. With this motor there was a lot of space on the ends but I will probably take a little off each end. This will flatten them somewhat and thin them down but still leave that nice rounded edge at the stator edges where the wire will run. After the cleanup, I think I will put a little 1200 deg F paint on the inside slots of the poles. Then I should not need any Kapton or other insulators to make winding difficult.. About the thickness, I think you are correct. What might work is an ultrasonic cleaner or even a home made shaker table. That way you could put in less powder and get even coverage, with less cleanup to do after it is coated. Man, this is fun... Cheers, JR |
| Thread Tools | |
| Discussion 1k or 2k clear coat?or gel-coat? | krikkens | Composites Fabrication | 39 | Jul 14, 2012 08:06 AM |
| Question Stator Coating material | lixo | Electric Motor Design and Construction | 31 | May 08, 2011 08:58 AM |
| Discussion Tired of shorts? New stator coating from CustomCDR. | ryanl2006 | Electric Motor Design and Construction | 39 | Jun 16, 2007 06:28 PM |
| AXI Stator Coating - What IS that stuff? | Tom Frank | Power Systems | 2 | Sep 24, 2004 01:17 AM |
| Best stator coating for bare metal stator? | mgdon | Power Systems | 11 | Aug 15, 2004 12:01 PM |
