Old Nov 18, 2003, 03:22 PM
dmarnel is offline
Find More Posts by dmarnel
Coral Springs, FL
Joined Jan 2002
Question
Anyway to revive NiCads that have sat around too long?
I have a 32-cell NiCad pack that I haven't used in about 8 months. When I plug it into my Orbit charger, the charger doesn't even recognize it is there--it says "waiting for Nicads" or something of that sort. Is this pack beyond help or is there some way of restoring a charge?
Thanks!
- Don
dmarnel is offline Find More Posts by dmarnel
Old Nov 18, 2003, 04:06 PM
Xnaron is online now
Find More Posts by Xnaron
Xnaron's Avatar
Joined Feb 2003
Try using a "dumb" charger that doesn't require seeing a voltage to calculate the charge rate/voltage.
Brendin
Xnaron is online now Find More Posts by Xnaron
Old Nov 18, 2003, 07:20 PM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
Waiting for nicads (or any cell) means there is an open circut. There should be some power even after sitting for some time.
Do an "easycharge" at the lowest setting to bring the cells up to a voltage the charger can read.
Then cycle it a few times.
Moving to Batteries and Chargers.
FB
Fred Bronk is offline Find More Posts by Fred Bronk
Old Nov 19, 2003, 05:32 AM
dmarnel is offline
Coral Springs, FL
Joined Jan 2002
Thanks guys, that did the trick!
Old Nov 19, 2003, 09:13 AM
Xnaron's Avatar
Joined Feb 2003
What worked?
Old Nov 19, 2003, 03:15 PM
dmarnel is offline
Coral Springs, FL
Joined Jan 2002
I pumped a little juice into them for about 5 minutes with a dumb charger like you suggested. Then I used "Easy charge" to charge them all the way up. I am also cycling them right now and everything seems to be OK so far.
Old Nov 19, 2003, 03:18 PM
Xnaron's Avatar
Joined Feb 2003
I have had success with this method as well. I have an Orbit charger too and it seems to look for a certain amount of voltage from the cell. If the voltage is very very low the orbit won't see it.
Brendin
Old Nov 19, 2003, 04:15 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
.. the reason I keep my old 335 around!
..a
Old Nov 20, 2003, 03:33 AM
Frank B is offline
Find More Posts by Frank B
Frank B's Avatar
Denmark, kbh
Joined Jun 2001
I know this is a little off topic, but what plane do you fly with a 32-cell pack? That's big.
Frank B is offline Find More Posts by Frank B
Old Nov 20, 2003, 07:18 AM
dmarnel is offline
Coral Springs, FL
Joined Jan 2002
The 32-cell pack is for my Joker, it's a helicopter.
Old Nov 20, 2003, 05:26 PM
rscamp is offline
Find More Posts by rscamp
rscamp's Avatar
Dundas, ON Canada
Joined Feb 2001
Reflex mode is less fussy about the health of the pack. Formatting is even less fussy, but if your pack doesn't have enough voltage the charger won't recognize it is connected to a battery and won't start.
If you are sure you don't have an open circuit, you can force the Orbit to charge by pressing all three buttons simultaneously. You can connect the Orbit to a brick (well, okay maybe a power resistor) and it will try to charge it.
Rob
rscamp is offline Find More Posts by rscamp
Old Nov 21, 2003, 11:36 AM
dmarnel is offline
Coral Springs, FL
Joined Jan 2002
Thanks, Rob, that's good to know!
Planes that have been modeled to death Travis Scale Kit/Scratch Built 31 Jun 21, 2002 12:00 AM
Coloring posts that I have read already ? FlyByMike Site Chat 2 Mar 03, 2002 12:22 PM
8 cell 800Mah battery charging takes too long? try2fly Power Systems 12 Feb 04, 2002 06:40 PM
... Think I have been reading too much EZone! jcatron Foamies (Kits) 0 Jan 30, 2002 04:57 PM
