Old Dec 25, 2012, 11:57 PM
rcguy59 is offline
Find More Posts by rcguy59
Joined Nov 2012
Just made up a set of male-male leads so I could check my V2 that arrived yesterday. The ailerons are STILL not as they should be, identical in fact to the V1. The aux. channel feature works, and this, along with elevon support was what I was most interested in. Looks like we'll have to keep those y-cords handy. The V2 is also a fair amount smaller than the V1.
rcguy59 is offline Find More Posts by rcguy59
Old Dec 26, 2012, 12:22 AM
hendrnk is offline
Find More Posts by hendrnk
An Aussie in Chicago
Joined Apr 2012
Originally Posted by signflyer View Post
Can someone with a v2 unit attest to the aileron issue? With the v1 units, you must use a splitter to use dual aileron servos. Is this still the case?
Yes you do. There is 2 ports for Ailerons L & R, but they move the same way so you need to use a splitter cable.
hendrnk is offline Find More Posts by hendrnk
Old Dec 26, 2012, 07:37 AM
signflyer is offline
Find More Posts by signflyer
2^p - 1
signflyer's Avatar
United States, MO, Springfield
Joined Feb 2003
Thanks Hendrnk. I really wish they had fixed this, it would be nice to use flaperons.
signflyer is offline Find More Posts by signflyer
Old Dec 26, 2012, 09:48 AM
SkyCadet is offline
Find More Posts by SkyCadet
Segelfliegen bedeutet Freiheit
SkyCadet's Avatar
Canada, MB, Winnipeg
Joined May 2010
Why DO these two not run differentially? Is not that the intent?
It does not affect my immediate application, but seems illogical.
SkyCadet is offline Find More Posts by SkyCadet
Latest blog entry: New plane - Evader!!!
Old Dec 26, 2012, 10:52 AM
2^p - 1
signflyer's Avatar
Joined Feb 2003
Nobody know the answer to that. Seems like an easy fix, maybe something noobee can fix with firmware??
Old Dec 26, 2012, 11:36 AM
chewytm is offline
Find More Posts by chewytm
Ipoh, Perak Malaysia
Joined Jul 2006
Unless you have two input for the ailerons, then having 2 output for the ailerons is useless. It still will NOT give you flapperons/spoilerons
chewy
chewytm is offline Find More Posts by chewytm
Old Dec 26, 2012, 02:12 PM
Minimog is offline
Find More Posts by Minimog
Canada, BC, Coquitlam
Joined Dec 2009
I'd like to see 2 aileron inputs on V3 and it would be awesome to get remote gain control even though it would require 3 separate channels to do so.
Minimog is offline Find More Posts by Minimog
Old Dec 26, 2012, 02:24 PM
ckleanth is offline
Find More Posts by ckleanth
If it has wings it will fly...
ckleanth's Avatar
United Kingdom, England, Birmingham
Joined Mar 2011
chewy
Have a read
http://www.rcgroups.com/forums/showp...&postcount=955
ckleanth is offline Find More Posts by ckleanth
Old Dec 26, 2012, 06:13 PM
2^p - 1
signflyer's Avatar
Joined Feb 2003
Yes, but this is not what we are discussing. The problem is that the stabilizer 'corrects' both ailerons in the same direction. Many of us have tried all sorts of reversing in the TX and on the unit, but there is no way to utilize both aileron outputs (even with two input).
chewy
Old Dec 26, 2012, 06:32 PM
ckleanth is offline
ckleanth's Avatar
Joined Mar 2011
this is probably due to the original (can I say lame) programming. if we utilise the dip switches to define what mode we are in, then for the flaperons mode we treat L AIL and R AIL signal independendly and then what comes out is the L AIL -gain pulse change and R AIL respectevly + gain pulse change. you need to do your mixing on the tx for flaperons, but it can be done
Minimog is offline
Joined Dec 2009
If you had 2 inputs it would be no issue to simply reverse in your transmitter, no reversing will work right now with the single aileron input. Only way of doing it would be using a servo reverser or with a programmable servo (reversing the rotation direction like on hyperion servos)
Old Dec 26, 2012, 07:05 PM
2^p - 1
signflyer's Avatar
Joined Feb 2003
I see what you are saying now. Chewytm was also correct.
Old Dec 26, 2012, 10:47 PM
omnivorr is offline
Find More Posts by omnivorr
Australia, QLD, Deagon
Joined Oct 2011
I'm not following this aileron prob.. if the two outputs are identical, then no prob, same as y-cable...... so are you telling me that L and R aileron outputs are one the reverse of the other ??
omnivorr is offline Find More Posts by omnivorr
Old Dec 27, 2012, 01:14 AM
hendrnk is offline
Joined Apr 2012
Yes they are.
I will try the Delta dip switch in the morning and see if that makes a difference.
Old Dec 27, 2012, 02:56 AM
chewytm is offline
Joined Jul 2006
Originally Posted by ckleanth View Post
Yes, adding more hardware (cabling etc) will work, but that involves a hardware hack. A lot of people are up to it, but it is not possible without an additional aileron input.
chewy
Discussion 3 axis stabilizer by HK Early Electric Plane Talk 17 Nov 18, 2012 02:11 PM
New Product OrangeRX 3-Axis Flight Stabilizer 14g (advertised) nemoskull Scratchbuilt Indoor and Micro Models 7 Sep 21, 2012 09:50 PM
Discussion Eagle A3 Aeroplane Fixed-wing Micro Flight Controller Board W/ MEMS 3-axis gyro eyeinsky1 Aerial Photography 3 Jun 06, 2012 03:38 PM
Sold CPD-4 Co-Pilot 2 axis flight stabilization system ecampos FPV Equipment (FS/W) 6 Oct 26, 2011 01:34 PM
Discussion ******* 3 axis gyro stabilized video gimbal powerblimp Aerial Photography 10 Feb 23, 2006 06:00 AM
