Gary |
Latest blog entry: FMS 1450mm P-51B Old Crow: My Build!
Just waiting for some good weather...
I just finished my V2 install in my Yak55 last week.
First impressions: NICE - smaller and lighter than the V1, and I was able to get the DX6i to run the gear channel for on/off (using a spare AR500 spektrum RX I had left over). I'm running digital servos all the way around, and checked the current draw during operation: My BEC can handle up to 4A and it's less than 800mA under pretty much full standby (no motor running) but with the ORX and all servos adjusting during operation. Just over 0.5A actually (that's the Turnigy 45A AE45 ESC, my 500W motor on standby, my ORX, the AR500 running, plus the four HD-1810 digital servos (HK))... ![]() My unit is positioned with the in/out jacks facing forward, and thus my Aileron channel needed to be reversed on the ORX to compensate properly. No big deal there. Gear channel works fine! I was able to set it to provide on/off as designed on the V2. No issues. Linearity on my V2 is MUCH better than the V1 I have been using, and I still need to tweak it a bit before maidening the plane. I mounted the RX such that all channels mapped pretty much 1:1 off each unit. Easier, cleaner install. I also used some HK foam degined for gyro mounting. Nice product. Double-sided foam adhesive product which seems to add some dampening to vibrations that might impact gyro operation during flight. So far, everything looks very good, and no issues with operation. It may be several weeks to maiden as we've been locked in full winter mode here in west-central Canada with colder than average temperatures and tons of snow! ![]() SkyCadet |
Latest blog entry: Some notes on the ORX 3AS V2 and DX6i...
Latency?
Hi!
I got my stabilizer as well, and decided to strip it and put end connectors on it. It is lighter and more compact this way. I put it in a small flying wing which was tail-heavy before and did not fly very well. Now, it is ok. I noticed that the rolls were not as quick as before due to the dampening of the stabilizer. But then I concieved a mixer from the roll channel to the AUX channel, so that with more than 50% stick deflection, the stabilizer is switched off. Now the rolls should be as quick as before. Has anyone made tests about how much latency is added by this stabilizer? I don't want to rip mine out once it was so neatly installed, but if anyone has one lying around, perhaps he could do the following test: Mix 2 channels, plug one servo in the RX directly, and on the other channel, put the stabilizer in between. Now check if there is a delay between the movement of the two servos. This would be great! Cheers, Julez |
Joined Apr 2010
Hey guys, i would like to show my orx 3 axis. Since i want to put it in a 3d foamie i had to find a way to strip it. I recon that the soldering points of ailereon elevator and rudder are aligned and that there are holes in it, so it must be stackable with orx 610.
I was able to shove the 610 on the nine pins, it could look better but i decided to solder this way to still be able to choose whether to solder the aileron right wires from the top or from the bottom. total weight of combo is 6.7 g weight without case 3 axis 5.7 g 610 3.7 g without pins 3axis 4.2 g 610 2.1 g with cases 14 and 9.7 g all weights as far as i can remember |
| Thread Tools | |
| Discussion 3 axis stabilizer by HK | Early | Electric Plane Talk | 17 | Nov 18, 2012 02:11 PM |
| New Product OrangeRX 3-Axis Flight Stabilizer 14g (advertised) | nemoskull | Indoor and Micro Models | 7 | Sep 21, 2012 09:50 PM |
| Discussion Eagle A3 Aeroplane Fixed-wing Micro Flight Controller Board W/ MEMS 3-axis gyro | eyeinsky1 | Aerial Photography | 3 | Jun 06, 2012 03:38 PM |
| Sold CPD-4 Co-Pilot 2 axis flight stabilization system | ecampos | FPV/RPV - Equipment and Vehicles (FS/W) | 6 | Oct 26, 2011 01:34 PM |
| Discussion ******* 3 axis gyro stabilized video gimbal | powerblimp | Aerial Photography | 10 | Feb 23, 2006 06:00 AM |
