Old Dec 20, 2012, 06:49 AM
If it has wings it will fly...
United Kingdom, England, Birmingham
Joined Mar 2011
in theory yes it should work but then you loose your reference to the gain position (and the v1 gains are sensitive) you dont really need to remove it, just unplug the input wires, connect your servos up to the receiver and leave the stabiliser as is
ckleanth is offline Find More Posts by ckleanth
Old Dec 20, 2012, 08:55 AM
matrixFLYER's Avatar
Italy
Joined Nov 2011
I have not achieved a good gain position yet and removing the cable from the stabilizer and putting them straight to the receiver require more work then just put all the gains to zero. So if gains to zero is like removing the unit i think i will just set them to zero.
My only fear is thet even with gains to zero in flight it will fight my inputs.
matrixFLYER is offline Find More Posts by matrixFLYER
Old Dec 20, 2012, 03:36 PM
Terry Rigden's Avatar
UK, Bedworth
Joined Apr 2004
I don't think it work like that but just do a ground test
Terry
Terry Rigden is offline Find More Posts by Terry Rigden
Old Dec 20, 2012, 05:04 PM
"Auntie Samantha"
Sandancer's Avatar
USA, MO, Clever
Joined Dec 2009
To respond to the question of "to velcro or not to velcro", I have used this polyester blue velcro from HK for a couple of years now. I have used it for anything from RXs to batteries. It has high adhesive glue (takes a pair of pliers to pull it loose) and excellent hook & loop.
Gary
Sandancer is online now Find More Posts by Sandancer
Old Dec 20, 2012, 05:23 PM
"Auntie Samantha"
Sandancer's Avatar
USA, MO, Clever
Joined Dec 2009
I have another question...will the gyro work as efficient mounted upside down? If so what adjustments would be necessary?
Gary
Old Dec 20, 2012, 05:52 PM
Bill0's Avatar
United States, CA, Oceanside
Joined Aug 2010
I have one mounted upside down. Just make sure the servos are going in the right direction. If not, reverse them by using the gyro.
Bill0 is offline Find More Posts by Bill0
Old Dec 20, 2012, 05:53 PM
Joined Mar 2011
Gary
it doesent really matter how you mount it as long as the wires are facing either to the front or back of the a/c and the bottom of the module is attached to the a/c. if we define x axis to be along your fueselage, y is along your wings and z axis is along the vertical towards the ground, basically the gyro will sense change of direction on y and z axis and rotation on x (that's aelerons). basically your module needs to oppose the sudden movement without jerking the control surfaces. if your control surface is not opposing the movement direction you need to reverse direction on the stabiliser. if there IS a lot servo jerking about then reduce gain. best way to do this is to setups orientation then start with low or (zero) gain and gradually increase
Old Dec 20, 2012, 06:17 PM
"Auntie Samantha"
Sandancer's Avatar
USA, MO, Clever
Joined Dec 2009
I appreciate the info. I have (2) V2s coming from HK and I plan to install one in my Sky Surfer. The best centralized location I have found is on the bottom of the ele/rud guide tube support. I'll cut an access hatch in the belly so I'll have access to the controls. Should work fine!
Gary
Old Dec 20, 2012, 08:29 PM
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Gary just for info, these simple rate gyro stabilizers work just fine off centre. You don't have to be too precise about placing it in the "middle" since they respond to angular acceleration.
Mine is attached normal way up to a piece of ply which sits across the back of the cockpit opening in my Bixler. And on the cockpit floor behind the battery in the EasyStarII. Means you can lift it out to work in the opening and it is fully accessible to change plugs/ adjust pots etc. Nothing wrong with your arrangement - just another way to do it that gives less hassles if you have to make any changes.
Gary
jj604 is offline Find More Posts by jj604
Old Dec 20, 2012, 10:37 PM
"Auntie Samantha"
Sandancer's Avatar
USA, MO, Clever
Joined Dec 2009
Good to know that John. Thanks!
Gary
Old Dec 21, 2012, 01:07 AM
Italy
Joined Nov 2011
Tried to set all the gyros to zero but servos still move a little!
I removed it!
Old Dec 21, 2012, 03:58 PM
Better to burn out, than fade
SlimTom's Avatar
Slovenia, Ljubljana
Joined Sep 2012
Tried to search this threat to answer my question, but it's too long....
Q: Is there a way to connect a Chanel from RX to enable/disable stabilizer during fligh?
SlimTom is offline Find More Posts by SlimTom
Old Dec 21, 2012, 04:09 PM
Bill0's Avatar
Joined Aug 2010
V2 disable it with a switch. If you disable V1 there will be no power going to the servos....................not good
Old Dec 21, 2012, 04:11 PM
Chop it, cut it, bash it
quitcherbitchen's Avatar
United States, CA, Altadena
Joined Jul 2011
Yes, but only version 2 which is the one currently available.
quitcherbitchen is offline Find More Posts by quitcherbitchen
Old Dec 21, 2012, 04:17 PM
SlimTom's Avatar
Slovenia, Ljubljana
Joined Sep 2012
V1/2=? has this to do with AVR connectors on the unit?
If I would know how to do this, I wouldn't be asking
Discussion 3 axis stabilizer by HK Early Electric Plane Talk 17 Nov 18, 2012 02:11 PM
New Product OrangeRX 3-Axis Flight Stabilizer 14g (advertised) nemoskull Indoor and Micro Models 7 Sep 21, 2012 09:50 PM
Discussion Eagle A3 Aeroplane Fixed-wing Micro Flight Controller Board W/ MEMS 3-axis gyro eyeinsky1 Aerial Photography 3 Jun 06, 2012 03:38 PM
Sold CPD-4 Co-Pilot 2 axis flight stabilization system ecampos FPV/RPV - Equipment and Vehicles (FS/W) 6 Oct 26, 2011 01:34 PM
Discussion ******* 3 axis gyro stabilized video gimbal powerblimp Aerial Photography 10 Feb 23, 2006 06:00 AM
