Old Dec 17, 2012, 07:47 AM
flypaper 2 is online now
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I used both ail. outputs by flipping one ail servo over so both outputs are facing left. No jittering unless I crank up the sensitivity too far.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Dec 18, 2012, 06:23 AM
david.merc is offline
Find More Posts by david.merc
United States, VA, Blacksburg
Joined Jun 2010
Part 2 or HK 3-Axis Stabilizer Reveiw
Hooking up and testing,
HobbyKing RX3S OrangeRX 3-Axis Flight Stabilizer V2 (V-tail/Delta/AUX) Part 2 (20 min 43 sec)
david.merc is offline Find More Posts by david.merc
Old Dec 18, 2012, 11:11 AM
beto9 is offline
Find More Posts by beto9
Montreal, Canada
Joined Dec 2002
Thank you David for the two videos. Saved me a lot of time!
beto9 is offline Find More Posts by beto9
Old Dec 18, 2012, 02:29 PM
Joined Jun 2010
Glad I can help!
Old Dec 18, 2012, 05:01 PM
signflyer is offline
Find More Posts by signflyer
2^p - 1
signflyer's Avatar
United States, MO, Springfield
Joined Feb 2003
Anyone have a couple they want to sell? I've decided that I really like them V1 or V2 doesn't matter to me. I would also need 2 more of the 10cm male to male adapters.
signflyer is offline Find More Posts by signflyer
Old Dec 18, 2012, 06:00 PM
Minimog is offline
Find More Posts by Minimog
Canada, BC, Coquitlam
Joined Dec 2009
Good video David.merc :-)
I have some inputs though.
Gyros don't like vibrations, so if you want a good result mount them with gyro tape and not Velcro. There's a thing called zeal tape, it's a green gel type tape that's a out a 1/4 to 3/8 thick.
Also reminding everybody to trim their airplanes mechanically before installing this system.
When doing your testing start with a low gain and move up until you get oscillation, then back off a little until it's gone. Run as high a gain as you can for best results.
Gyros like fast servos, so even though it will work with analog servos I believe the best result will be achieved with faster digital ones. To achieve higher gain levels you will have to have both, as little vibes as possible (and gyro tape that will dampen the rest) and fast servos.
Minimog is offline Find More Posts by Minimog
Old Dec 18, 2012, 08:00 PM
Weed89 is offline
Find More Posts by Weed89
Weed89's Avatar
United States, CA, Thousand Oaks
Joined Aug 2012
Thanks Dave...still waiting for mine to arrive...so now I will know how to use it
Weed89 is offline Find More Posts by Weed89
Old Dec 19, 2012, 03:36 AM
Terry Rigden is online now
Find More Posts by Terry Rigden
Terry Rigden's Avatar
UK, Bedworth
Joined Apr 2004
could somebody please explain about trimming the model before adding the gyro
If my understanding of the way these things work is correct then they respond to rotation so having the servos off their centre should not affect the gyro operation. Have I missed something ?
I know how to trim an aeroplane and often adjust it to suit conditions ie more down trim on a windy day or adding down trim when landing through a turbulent zone. Adding a few clicks on the rudder to hold a thermal are all things I do routinely
Is it OK to use subtrims when doing the set up?
or having some trim in permanently
Do we have to set each gyro controlled channel at 1.56 ms ? (servo centre)
if so why ?
The servos on my model are not at the centre of their travel at neutral stick input as I have both sub trim and conventional trim dialed in. Is this why the gyro has slowed them down and caused a drop in servo resolution ?.
Thanks terry
Terry Rigden is online now Find More Posts by Terry Rigden
Old Dec 19, 2012, 05:46 AM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I use a few clicks of trim and subtrim with no noticeable affect.
Gord.
Old Dec 19, 2012, 06:51 AM
JRuggiero is offline
Find More Posts by JRuggiero
Blacksburg, VA 24060 USA
Joined Feb 2000
Minimog,
Good point re not mounting the gyro with velcro. What about thick double-sided sticky tape, like the kind used for mounting pictures and servos? Maybe several thicknesses? Where do you get gyro tape or green zeal tape?
Jim R.
JRuggiero is offline Find More Posts by JRuggiero
Old Dec 19, 2012, 07:22 AM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
On helis I use double sided foam tape, about 2mm thick.
I've seen a few installs using foam tape, aluminium plate, foam tape, gyro.
Avoid using too much - it may allow the gyro to twist around indepedantly of the aircraft! (small amounts of course, but it will affect the controls)
Odysis is offline Find More Posts by Odysis
Old Dec 19, 2012, 07:56 AM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I velcroed the gyro to the bottom of the fuse, with another velcro strap completely around the gyro. It doesn't move in any direction.
Gord.
Old Dec 19, 2012, 08:07 AM
quitcherbitchen is online now
Find More Posts by quitcherbitchen
Bombs away!!!
quitcherbitchen's Avatar
United States, CA, La Caņada Flintridge
Joined Jul 2011
I built a box out of aircraft ply the same size as the gyro which is mounted to the airframe and velcro the gyro inside. No problems so far. one end is open so I can pull it out.
quitcherbitchen is online now Find More Posts by quitcherbitchen
Old Dec 19, 2012, 09:07 AM
A Rdnek is offline
Find More Posts by A Rdnek
Bruno, GOOD DOG
A Rdnek's Avatar
United States, IA, Grinnell
Joined Aug 2007
I use these pads. I cut them in pieces and use whatever I need.
http://www3.towerhobbies.com/cgi-bin...?&I=LXMYH2&P=7
They have worked great for me.
Rn
A Rdnek is offline Find More Posts by A Rdnek
Old Dec 19, 2012, 09:19 AM
Bill0 is offline
Find More Posts by Bill0
Bill0's Avatar
United States, CA, Oceanside
Joined Aug 2010
I use scotch indoor, outdoor mounting tape. It can be bought at Lowe's or Home Depot. It is very sticky and has a small amount of cushion to it too. I have the gyro mounted to a slow stick with just the mounting tape to the 10mm stick. No velcro or anything else, plus it's mounted upside down on the bottom of the stick.
It takes some effort to get it back off.
If your wondering why a slow stick, it's my test plane for everything.
Bill0 is offline Find More Posts by Bill0
Discussion 3 axis stabilizer by HK Early Electric Plane Talk 17 Nov 18, 2012 02:11 PM
New Product OrangeRX 3-Axis Flight Stabilizer 14g (advertised) nemoskull Scratchbuilt Indoor and Micro Models 7 Sep 21, 2012 09:50 PM
Discussion Eagle A3 Aeroplane Fixed-wing Micro Flight Controller Board W/ MEMS 3-axis gyro eyeinsky1 Aerial Photography 3 Jun 06, 2012 03:38 PM
Sold CPD-4 Co-Pilot 2 axis flight stabilization system ecampos FPV Equipment (FS/W) 6 Oct 26, 2011 01:34 PM
Discussion ******* 3 axis gyro stabilized video gimbal powerblimp Aerial Photography 10 Feb 23, 2006 06:00 AM
