Old Dec 13, 2012, 03:56 PM
dav3uk is offline
Find More Posts by dav3uk
Has Sloped Off
dav3uk's Avatar
Uk South Wales
Joined Aug 2009
I agree, these should be used just other accepted gizmos, like computer radios, dual rates etc. there is a guy around here who crys wolf every time you say gyro but has just spent 1000s on a Futaba top of the range radio....
What i would say is that you still need to learn to fly without...... Just in case it fails.
Over the years i have seen some incredible saved planes due to knowing what makes them fly and how, the best was a rudder elevator biplane that lost rudder and elevator in flight but the guy spent 20 mins getting it back from way downwind using just throttle, it climbed and turned on higher settings, landed it at his feet. Some of the best stress flying I ever saw, sadly the guy has passed away some time ago so I will name him his name was Ken Phillips an ex army gunner he was a natural still think of him when out flying he would have loved all these electric models.
Dave.
dav3uk is offline Find More Posts by dav3uk
Old Dec 13, 2012, 04:31 PM
flypaper 2 is offline
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
On my 3D Zoombi and flash, I had to back off the expo all the way as the gyro more or less takes over that task. They were just too mushy with it working. If you've flown with too much expo, you know what I mean. I was also able to move the CG back much further than normal. for even more violent aerobatics. Yet when you let the sticks go, it locks in like on rails.in whatever direction you desire. I'd be sceptical about taking it out with a switch at these settings while flying. Two more of the later v2 versions just came in the mail and will be picked up tomorrow for further experimenting. One will go into a scratchbuilt VTO Pogo that needs the elevon setting.
Don't know why age keeps creeping in as an excuse, as I'm a 76 yr. old codger. Still lots to learn.
flypaper 2 is offline Find More Posts by flypaper 2
Old Dec 13, 2012, 10:30 PM
quitcherbitchen is offline
Find More Posts by quitcherbitchen
Bombs away!!!
quitcherbitchen's Avatar
United States, CA, La Caņada Flintridge
Joined Jul 2011
Your avatar doesn't look a day over 21
quitcherbitchen is offline Find More Posts by quitcherbitchen
Old Dec 14, 2012, 12:08 AM
SkyCadet is offline
Find More Posts by SkyCadet
Segelfliegen bedeutet Freiheit
SkyCadet's Avatar
Canada, MB, Winnipeg
Joined May 2010
You're only as old as ya feel!
SC
SkyCadet is offline Find More Posts by SkyCadet
Latest blog entry: New plane - Evader!!!
Old Dec 14, 2012, 12:20 AM
Fugitive_Bill is offline
Find More Posts by Fugitive_Bill
CURIOSITY Has Landed!
Fugitive_Bill's Avatar
Sydney, Australia
Joined Jul 2005
His 21'st birthday is coming up... for the 4th time, or that 5th time?
But it sounds like he's still a spring chicken (Rooster) to me.
If I live another 30 years to reach your age 'flypaper 2', I'll be a very, very happy boy!
Did someone say off topic!
-B!LL!
Fugitive_Bill is offline Find More Posts by Fugitive_Bill
Old Dec 14, 2012, 06:04 AM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Hanging out with the younger guys and teaching them how to fly keeps me young. Don't want to hang out with the old pharts.
As you say getting off topic.
This Pogo I'm working on, about the fourth one, is 3 ft. across, and fairly big to go in my van, so I made it so it folds up flat.
Gord.
Old Dec 14, 2012, 07:09 AM
Terry Rigden is offline
Find More Posts by Terry Rigden
Terry Rigden's Avatar
UK, Bedworth
Joined Apr 2004
On my 3D Zoombi and flash, I had to back off the expo all the way as the gyro more or less takes over that task. They were just too mushy with it working. If you've flown with too much expo, you know what I mean..
That's interesting I'm on the verge of chucking my V1 in the bin as it makes my Easy star mushy but doesnt do much to stabilise the model. If its calm then I dont need the stabiliser and if windy the model still gets chucked about. All I'm trying to do is get a more stable platform for aerial photography. I'll take out the small amount of expo I've dialed in and give it one last try. But so far I'm unimpressed
Regarding the used of "gizmos" to aid flying I don't care what the other flyers choose to put in their aeroplanes provided it doesnt compromise flight safety or make too much noise.
Terry
Terry Rigden is offline Find More Posts by Terry Rigden
Old Dec 14, 2012, 09:32 AM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Hi Terry: You say you don't get much stabilizing affect. I wonder if it doesn't have enough sensitivity. When I set mine up, I kept moving it up a bit at a time till the surface started to oscilate from being over sensitive, then backed it off enough to quit. I did this for each surface individually. I found I needed more on the ails than I thought, and less on the the rudder and elev. Takes quite a while to get dialed in, but worth it in the end.
Gord.
Old Dec 14, 2012, 09:39 AM
dav3uk is offline
Has Sloped Off
dav3uk's Avatar
Uk South Wales
Joined Aug 2009
Yes I found it took a little time to get it just right as well. And then when I swapped plane it needed doing all over again.
Dave
Old Dec 14, 2012, 09:50 AM
noobee is offline
Find More Posts by noobee
Joined Dec 2006
Originally Posted by lvale View Post
I was refering to this
http://www.hobbyking.com/hobbyking/s...occessors.html
on this one can remove the jumper J1 and use the stabiliser self powered thus eliminating all possible power issues
http://www.hobbyking.com/hobbyking/s...2X365809X5.pdf
interesting. i think i have one of those too.
do you know if atmega168pa running at 3.3v would be 5v tolerant? (since this usbasp would be using 5v levels for the mosi/miso/reset signals).
noobee is offline Find More Posts by noobee
Old Dec 14, 2012, 10:19 AM
UK, Bedworth
Joined Apr 2004
I've been slowly upping the gain and now have the pots at about 3 o clock and the control surfaces move to about half of full deflection when I rotate the model sharply by hand.
Terry
Old Dec 14, 2012, 10:41 AM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
You have it right in the ballpark now Terry. You just need to fly it to fine tune it. Takes very, very little turning of the dial once you are that close.
Gord.
Old Dec 14, 2012, 11:30 AM
dav3uk is offline
Has Sloped Off
dav3uk's Avatar
Uk South Wales
Joined Aug 2009
Yeah microscopic amounts.....lol. its one of the things I am hoping is better on the V2 but mine seem to be attached to a pidgeon........weeks and weeks.
Dave
Old Dec 14, 2012, 12:00 PM
MaOb is offline
Find More Posts by MaOb
Joined Oct 2008
V2 Manual
Hi,
where can i get the V2 manual?
could only find the V1 manual....
BR, Martin
MaOb is offline Find More Posts by MaOb
Old Dec 14, 2012, 06:45 PM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
Should be fine. The data sheet gives up to 5.5V.
Odysis is offline Find More Posts by Odysis
Discussion 3 axis stabilizer by HK Early Electric Plane Talk 17 Nov 18, 2012 02:11 PM
New Product OrangeRX 3-Axis Flight Stabilizer 14g (advertised) nemoskull Scratchbuilt Indoor and Micro Models 7 Sep 21, 2012 09:50 PM
Discussion Eagle A3 Aeroplane Fixed-wing Micro Flight Controller Board W/ MEMS 3-axis gyro eyeinsky1 Aerial Photography 3 Jun 06, 2012 03:38 PM
Sold CPD-4 Co-Pilot 2 axis flight stabilization system ecampos FPV Equipment (FS/W) 6 Oct 26, 2011 01:34 PM
Discussion ******* 3 axis gyro stabilized video gimbal powerblimp Aerial Photography 10 Feb 23, 2006 06:00 AM
