Old Nov 23, 2012, 06:04 AM
flypaper 2 is offline
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Good for you. I ended up with a little more gain on the ails and a little less on the rudder and elev., but it does depend on the individual plane. I have very much throw on the elev and rudder, which may be the reason for not needing much gain on the gyro.
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Nov 24, 2012, 08:05 AM
Kokopeli is offline
Find More Posts by Kokopeli
Curiouser and curiouser
Kokopeli's Avatar
Rochester, NY, USA
Joined Oct 2005
Originally Posted by SkyCadet View Post
Walt,
I hooked up my SuperDecathlon BL as a 2-channel system with the ORX, and used roll and pitch as my axes. Mine is a rudder/elevator system on the plane, with the rudder run by the aileron channel.
Therefore, for my 2-channel control, I used the aileron/elevator channels for my system - works very well!
Skycadet/Darren
Thanks Darren.
By looking up the SD BL, I see that it has a fair amount of dihedral, so I think it will match my situation.
Walt
Kokopeli is offline Find More Posts by Kokopeli
Old Nov 25, 2012, 10:51 PM
SkyCadet is offline
Find More Posts by SkyCadet
Segelfliegen bedeutet Freiheit
SkyCadet's Avatar
Canada, MB, Winnipeg
Joined May 2010
Hi Walt!
My pleasure. FYI, I felw my SD BL yesterday in nearly 30 km/hj winds (variable over 45 degree direction) and the ORX flew suoerbly with ALMOST no input from me except when touching down.
Overall, I am very happy with this system... it seems to handle the wind reasonably well, and allows for really nice control on approach. I flew yesterday in nearly 25-30km/h variable winds, and was able to fly really well, including TD - no way without the ORX 3AS - I'd have been fulltime on the stix!
SC
SkyCadet is offline Find More Posts by SkyCadet
Latest blog entry: New plane - Evader!!!
Old Nov 27, 2012, 01:43 PM
SuperFPVflyer is offline
Find More Posts by SuperFPVflyer
One with the machine
SuperFPVflyer's Avatar
United States, GA, Atlanta
Joined Oct 2010
Mine keeps browning out somehow then I get dead stick. Total POC I don't trust it one bit
SuperFPVflyer is offline Find More Posts by SuperFPVflyer
Old Nov 27, 2012, 02:03 PM
SkyCadet is offline
SkyCadet's Avatar
Joined May 2010
I recently flew this weekend in gusty 18-20mph winds. Directions varied over about 15 degrees or more, and wind was up and down a lot that day. The SD BL with ORX 3AS handled it very well! No issues whatsoever, and only minimal inputting on the stix was needed most of the time.
SFPV, the only thing I can come up with on your end is that either the unit is somehow faulty, or your BEC on board the plane is nearing its limits. While not a magical unit, it should do well in many applications, and most folks here find it works well. brownout is a scary thing! Maybe recheck your current draws on the system...
Good luck
SkyCadet
Old Nov 27, 2012, 02:42 PM
Rich in ILM is offline
Find More Posts by Rich in ILM
Retired in NC
Rich in ILM's Avatar
USA, NC, Wilmington
Joined Sep 2010
Your ESC has to have a fully rated switching bec or use a seperate bec. It makes all the difference. The continous operation can be a stress.
Rich in ILM is offline Find More Posts by Rich in ILM
Old Nov 28, 2012, 04:31 AM
Terry Rigden is offline
Find More Posts by Terry Rigden
Terry Rigden's Avatar
UK, Bedworth
Joined Apr 2004
Sorry to hear you are having problems, if you let us know what airborne system you are using we may be able to help or at least avoid getting into similar trouble
Terry
Terry Rigden is offline Find More Posts by Terry Rigden
Old Nov 28, 2012, 05:21 AM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I would suspect the BEC with not a high enough amp rating. If I push mine to hard with aerobatics, I had the ESC shut off from overheating. Soon as it cools off, after about 6 seconds, it turns back on again. I don't push it so hard and it's fine. I've had it happen before and replaced the speed controller with a higher amp BEC with no problems after that. One would suspect a rcvr brown out but the testing showed otherwise.
Gord.
Old Nov 28, 2012, 05:32 AM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
Any idea what the idle current for the Rx is?
The micro inside it shouldn't brown out until about 4v, so it seems a pretty large draw to pull it down that far?
Odysis is offline Find More Posts by Odysis
Old Nov 28, 2012, 09:38 AM
omnivorr is offline
Find More Posts by omnivorr
Australia, QLD, Deagon
Joined Oct 2011
One might suspect from your avatar that you run FVP servos, plus control-surface servos... and then the added load of stabiliser, and constantly activated control-surface servos 'stabilising'your FVP rig.....
...did you allow for this load in your choice of bec, Rx-power supply ?
omnivorr is offline Find More Posts by omnivorr
Old Nov 28, 2012, 01:22 PM
A Rdnek is offline
Find More Posts by A Rdnek
Bruno, GOOD DOG
A Rdnek's Avatar
United States, IA, Grinnell
Joined Aug 2007
Why does anyone run an airplane, the size we are dealing with, with numerous servos, without a UBEC? GEE WIZ, you can you can buy a good running UBEC these days for $10.
Rn
http://www.headsuprc.com/servlet/the...Battery/Detail
A Rdnek is offline Find More Posts by A Rdnek
Old Nov 28, 2012, 02:28 PM
Truglodite is offline
Find More Posts by Truglodite
Registered Aircraft Offender
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Shoot, you can pick up a properly designed 5A switching BEC for less than $10:
http://www.hobbyking.com/hobbyking/s...V_5A_UBEC.html
A gyro constantly works the servos hard, even when your hands are off the sticks. That's why it's possible to take a plane that works fine with manual control and a built in BEC, then add an Orange stabilizer to it and the BEC smokes. The more powerful and fast your servos, the bigger the difference in current will be with/without stabilization. BEC's are so cheap these days, pretty much anything with gyros should have one... except maybe the small indoor stuff where just 1A can smoke all 4 servos anyways.
Kev
[edit: One more thing on this subject... you guys doing FPV should be concerned with high current ground loops. I NEVER EVER use a built in BEC on an FPV rig, especially if it has a current sensor.]
Truglodite is offline Find More Posts by Truglodite
Old Nov 28, 2012, 02:37 PM
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
My ArdupilotMega2.5 only draws 200-300mA, and that thing has a bigger Amtel chip, barometer, 6x gyros, ACC, compass, etc. Not sure on the exact draw, but the ORx stabilizer uses common parts; looking at similar controllers using the same parts (kk boards), it probably draws around 100-200mA.
99.9% of the time it is excess servo load that causes brownout problems with FC's.
Kev
Old Nov 28, 2012, 08:31 PM
Odysis is offline
Joined May 2007
That makes sense. I was wondering how a wee tiny little Mega8L (I'm guessing) could pull so much current.
Old Nov 29, 2012, 08:05 AM
creapyd is offline
Find More Posts by creapyd
Prefectionist
Joined Mar 2007
Hobby King just posted a Version 2 that adds remote ON / OFF and V-Tail / Delta mixing.
creapyd is offline Find More Posts by creapyd
Discussion 3 axis stabilizer by HK Early Electric Plane Talk 17 Nov 18, 2012 02:11 PM
New Product OrangeRX 3-Axis Flight Stabilizer 14g (advertised) nemoskull Scratchbuilt Indoor and Micro Models 7 Sep 21, 2012 09:50 PM
Discussion Eagle A3 Aeroplane Fixed-wing Micro Flight Controller Board W/ MEMS 3-axis gyro eyeinsky1 Aerial Photography 3 Jun 06, 2012 03:38 PM
Sold CPD-4 Co-Pilot 2 axis flight stabilization system ecampos FPV Equipment (FS/W) 6 Oct 26, 2011 01:34 PM
Discussion ******* 3 axis gyro stabilized video gimbal powerblimp Aerial Photography 10 Feb 23, 2006 06:00 AM
