Old Nov 08, 2012, 05:36 PM
flypaper 2 is offline
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Got mine a couple of days ago and mounted one in my old Zoombi bipe. Made a violent 3D aerobatic plane into a pattern plane.!! It felt a little mushy as I had a lot of expo in it. Found with the stability of the gyro, you don't need any expo. Does everything better, Locked in hover where you can take you fingers off the sticks altogether. Does excellent knifedge loops where before it would roll out coming around the bottom. Now it locks in all the way around. Makes a sh## flier like me look good........well, fair. Still need to do more tinkering.and well worth the bucks. I wonder if they'll ban the competition pattern fliers from using these. Geez!! maybe I should enter my Super Zoom.
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Nov 08, 2012, 10:56 PM
t.edwards is offline
Find More Posts by t.edwards
Joined Aug 2005
This has always been the trade-off, unresponsive but stable, or responsive with lessened stability. It takes more sophisticated electronics (think EagleTree Guardian 2D/3D) than HKs' Orange stabilizer to have responsiveness and stability.
t.edwards is offline Find More Posts by t.edwards
Old Nov 09, 2012, 05:17 AM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Yeah, I need to back off on the sensitivity a bit to see if I can find a happy medium.
Old Nov 09, 2012, 06:15 AM
Rich in ILM is offline
Find More Posts by Rich in ILM
Retired in NC
Rich in ILM's Avatar
USA, NC, Wilmington
Joined Sep 2010
I found anything after the 2 o'clock was too intrusive and the pots aren't linear.
Rich in ILM is offline Find More Posts by Rich in ILM
Old Nov 09, 2012, 07:01 AM
Joined Aug 2005
I never found acceptable settings. Even with the gains backed down I was getting reduced/inconsistent/unpredictable control responses.
A ways back there was a post about being able to reduce expo with the stabilzer, sure you can because with much gain at all you get reduced responses to the sticks. Stability by limiting response. This isn't a heading hold gyro in spite of posts making it sound like one. It's a poorly executed rate gyro.
Old Nov 09, 2012, 08:00 AM
Woody_99 is offline
Find More Posts by Woody_99
Too much is just not enough...
Woody_99's Avatar
Joined Jan 2009
I've had the best luck with these by setting all transmitter trims and sub trim to zero. In some cases, the control surface may not be neutral any more, and will need to be set up mechanically.
My experience on other stabilizer systems, and in their directions, recommended that all TX trims be removed as the stabilizer will see them as TX input and try to adjust to that input.
It's worked on the 3 oranges I've set up so far.
Reducing/removing expo seems to have the same effect. I think the stabilizer likes to see a linear input, or at least it feels that way.
Little to no expo works for me with the Orange Stabilizer.
When I get them set up with no TX trims and the gain in the right spot, the planes fly in calm wind just like they did before. In wind, they fly like there is little or no wind which is what I'm looking for.
Woody_99 is offline Find More Posts by Woody_99
Old Nov 09, 2012, 08:33 AM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I set it up the same as you Woody which is the way the instructions say and it works to my satisfaction. I don't like headhold either for the same reasonsas you. I'll be going out later today and do away with the expo altogether and see what happens. Funny, doing knifedge flying away from you, you can actually see the elevator going back and forth compensating for the wind. This plane has a full flying stab, so it's very noticeable.
Gord.
Old Nov 09, 2012, 09:51 AM
SkyCadet is offline
Find More Posts by SkyCadet
Segelfliegen bedeutet Freiheit
SkyCadet's Avatar
Canada, MB, Winnipeg
Joined May 2010
I find the same thing as you folks.
Flying with expos, you have to go negative expo to get close to original operating. I tried running -15% and it seems pretty good. However, I may re-try linear and see how that goes.
The plane where I have set up the ORX on, my super Decathlon, does indeed show good stability in wind though, running close to 2-o'clock. Since the settings at and after this point are SO touchy, it is difficult to find that "just so" spot.
I think that i'll dial these back a tad and re-try linear on the TX. Under certain conditions in light winds, I notice a pretty good waggle in the rudder operation (not chatter, but compensating in headwinds) esp. in a moderate dive.
However, I am flying skis right now (we got nailed with over 300mm of snow, highly unusual for us at this time of year!) and I have found that the pitch settings and roll in wind (15mph gusting to 20) seem to really hold the plane well on landing approaches. My issue now is that in wind, the plane on a shallow approach angle climbs up and down vertically without much pitching, due to wing lift, and since no axis is really being affected per se, no comp. is seen.
It is noticably better on landings with the ORX on there and skis, as the pitching is noticable without it on approaches in lighter wind. (as the skis lose lift and create more frontal drag the plane starts to drop the nose a bit.).
SC
SkyCadet is offline Find More Posts by SkyCadet
Latest blog entry: New plane - Evader!!!
Old Nov 09, 2012, 12:29 PM
tengarang is offline
Find More Posts by tengarang
Fly Straight Fly High
tengarang's Avatar
United States, CA, San Jose
Joined Aug 2010
Put one of these bad boys in the already stable Parkzone - jug
http://www.hobbyking.com/hobbyking/s...tabilizer.html
not its hands off and fly with a beer
tengarang is offline Find More Posts by tengarang
Old Nov 09, 2012, 06:58 PM
BladeRex is offline
Find More Posts by BladeRex
Bladerex700
Joined Jul 2007
Has anyone installed with the egle tree system?
BladeRex is offline Find More Posts by BladeRex
Old Nov 10, 2012, 08:41 AM
Flybynight2 is offline
Find More Posts by Flybynight2
Will it ever Fly?
Flybynight2's Avatar
United States, AZ, Beaver Dam
Joined Nov 2011
I tried a FY-30,
But it didn't work well. And after sending to the factory found out if you do install one, it needs a min of 4S ESC to work properly.
The ET might need the same extra cushion.
I am using the Orange on my foamy now.
Flybynight2 is offline Find More Posts by Flybynight2
Old Nov 10, 2012, 07:18 PM
BladeRex is offline
Bladerex700
Joined Jul 2007
Originally Posted by Flybynight2 View Post
I tried a FY-30,
How did you wired to the osd
Old Nov 10, 2012, 11:49 PM
Silverexpress is offline
Find More Posts by Silverexpress
Your customer
Silverexpress's Avatar
United States, MI, Berkley
Joined Dec 2009
http://m.rcgroups.com/forums/showthread.php?t=1596644
Silverexpress is offline Find More Posts by Silverexpress
Old Nov 11, 2012, 12:44 PM
Will it ever Fly?
Joined Nov 2011
AH, didn't wire to a Osd.
I just use it to fly my small foamy for stabilization in the constant 10-20 MPH winds here.
Old Nov 12, 2012, 10:54 AM
Blue Flyer is offline
Find More Posts by Blue Flyer
happy when flying
Blue Flyer's Avatar
United Kingdom, England, North Yorkshire
Joined Dec 2010
Mine arrived today and I'll be putting it into my Bixler 2 for FPV stability. here's my Bixler2 blog http://bixler2fpv.blogspot.co.uk/
Blue Flyer is offline Find More Posts by Blue Flyer
Discussion 3 axis stabilizer by HK Early Electric Plane Talk 17 Nov 18, 2012 02:11 PM
New Product OrangeRX 3-Axis Flight Stabilizer 14g (advertised) nemoskull Scratchbuilt Indoor and Micro Models 7 Sep 21, 2012 09:50 PM
Discussion Eagle A3 Aeroplane Fixed-wing Micro Flight Controller Board W/ MEMS 3-axis gyro eyeinsky1 Aerial Photography 3 Jun 06, 2012 03:38 PM
Sold CPD-4 Co-Pilot 2 axis flight stabilization system ecampos FPV Equipment (FS/W) 6 Oct 26, 2011 01:34 PM
Discussion ******* 3 axis gyro stabilized video gimbal powerblimp Aerial Photography 10 Feb 23, 2006 06:00 AM
