I thought so. The piezo crystal vibrates and any inertial changes to the board affect the resonant frequency of the oscillator. A phase sensing circuit or other similar system must do a doppler shift measurement to determine the relative rate of motion.
Cool. Amazing what technology we have nowadays! ![]() I've dealt with piezo oscillators in one of my other hobbies, Amateur Radio. So I have pretty good electronics background. I had heard that these gyros had piezo units in them just did not know for sure what made them tick. However, the other option could be like what we see in micro balances: A piezo crystal generates a voltage due to force on the faces (piezo electric effect). Maybe a small change in voltage is read directly without oscillation? However, the oscillation option makes more sense as it's easier to measure VERY small relative changes in a frequency compared to a nanovoltage, which may be subject to noise (motor/ESC/RX/Servos, etc) SkyCadet/VE6IZ |
Latest blog entry: Some notes on the ORX 3AS V2 and DX6i...
You will find some good info on this site. These are they guys who make the sensors. Browse around and you will find papers on design and how they work.
http://invensense.com/index.html |
In a boat
I posted a short while ago asking if these were any good for a boat stabilizer, I'm reporting back and saying this is awesome for the application
It works even better than I expected, I can see how a system with more sophisticated sensors would have the advantage as there were a couple of times I noticed it actually inducing a slight lean but I'm well happy.Cheers Nick |
Dave |
The secon AIL output is actually reversed so when you connect your servos they will both go the same way, its a bit of an odd setup no one knows why they did it........ There are more complex and costly units out there that will support 2 separate AIL servos to allow mixing for differential, crow braking etc. Dave |
Joined Jul 2007
I think I might end up with a (Y) connector in order for me to avoid any headaches, Thanks Aisamac |
Yes that's what I figured too. He needs to use one output off the RX to run the ailerons differentially.
SC |
| Thread Tools | |
| Discussion 3 axis stabilizer by HK | Early | Electric Plane Talk | 17 | Nov 18, 2012 02:11 PM |
| New Product OrangeRX 3-Axis Flight Stabilizer 14g (advertised) | nemoskull | Indoor and Micro Models | 7 | Sep 21, 2012 09:50 PM |
| Discussion Eagle A3 Aeroplane Fixed-wing Micro Flight Controller Board W/ MEMS 3-axis gyro | eyeinsky1 | Aerial Photography | 3 | Jun 06, 2012 03:38 PM |
| Sold CPD-4 Co-Pilot 2 axis flight stabilization system | ecampos | FPV/RPV - Equipment and Vehicles (FS/W) | 6 | Oct 26, 2011 01:34 PM |
| Discussion ******* 3 axis gyro stabilized video gimbal | powerblimp | Aerial Photography | 10 | Feb 23, 2006 06:00 AM |
