Already had a go in all my planes at least once.....lol
The Mozzy is heavier than most the foamies I fly so I dont find it gets pushed around by the wind much anyway as I only fly the lightweight foamies in up to about 10mph, any more and I fly heavier stuff and lead sled slope soarers. Was out earlier this week in constan 30mph with gusts of 45.....but in the compression on the ridge was up in the 60's.......awesome day. Its not too windy until you cant stand up...... Dave |
I have it in my indoor 3d bipe at the moment as it lets my fly it outside in a bit of wind......
I found that on normal models that with the gain up far enough to make a real difference I didnt like the 'disconnected' feeling it gave when flying. When I backed the gains down to a point it felt ok there was not much difference to normal.......just my own preference. Dave |
Canada, BC, Vancouver
Joined Oct 2011
ORX 3 Axis Stabilizer on RUD / ELEV / No Ail airplanes?
Win the ORX 3AS / can the ORX 3AS be made to work on an airplane that has these two servos only: RUD / ELEV? (the plane has a fixed wing with no ailerons).
If this has already been addressed in this thread, would you please refer me to the page / post link? (I've tried as many variations on "2 servos / no aileron / etc. as I can think of, and have so far found only references to the "Y" harness issue). ...my guess is that it won't work, or might work partially. Perhaps two axis stabilization may be better than nothing, with full manual responsibility for aileron roll still in the hands of the pilot. Advice / experiences? Thanks! |
Yes it will, you can use as many functions as you like, when used on my yacht I only used rudder.
You do however have a choice on a rudder elevator model. Option 1, mount the unit in the normal way and connect the rudder using the Rudder input/output to control the yaw axis, this would help prevent unwanted fishtailing for instance. Option 2, Mount the unit in the normal way and connect the rudder using the Aileron input/output to control the roll axis, this may help the wings rocking when flying in gusty winds for example. Because a rudder elevator plane turns by yawing first then the plane reacts and banks itself both will work but you may find one is more effective than the other. Rudder elevator only models are designed to be quite stable in the first place so you would need to try it and see. However......if you are only learning and this plane is your first/second one you may want to get someone with a little more experience to look over what you have done and help with the set up. There are 2 ways this could end badly. First you may connect it up and have the ORX reacting the wrong way.....so you turn right and the unit corrects to the right and it spirals to the ground.......or you could get the gains to high (they can be fiddly to adjust for some) and the plane could get itself into a never ending oscillation like a bucking bronco say on elevator and either shake itself to bits or just crash. Neither of these are faults with the unit, set any make of gyro up wrong and it can be just as spectacular.......lol Dave |
cool thanks for that
Joined Oct 2011
![]() Yes, I am on my first two airplane builds (doing them both at once) -- and they're both two servo models with fixed wings. While I am brand new to airplanes, I'm not brand new to flight control or configuring 3 axis gyros, as I bring some heli experience to airplanes. What great news to learn that the ORX 3AS should work usefully on a 2 servo plane! I'll definitely be trying both of the methods you've described. Thanks! |
I've got it all installed and working to my satisfaction on the bench, I had some issues with the channel assignments but figured it out , It seems to have good control of the stabilisers rolling the ship on its axis at a realistic speed all though the gain is near the maximum The rudder I fear will not be effective, the ship already should have excellent "tracking" due to its long lean shape. As this is of a secondary nature for the reason to add the unit I'm not concerned. Sea trials will happen within a couple of weeks. Cheers Nick |
Syzygy:
Glad you asked the big Q! ![]() I recently got one of these, and am planning to try it out on my SuperDecathlon BL 3-channel plane as an experimental setup. I plan to mount mine and hook up with Aileron channel control, since this plane has a LOT of rudder authority. Elevator as normal. Will start at the 50% (or whatever bench pre-testing suggests) to start, then tweak accordingly. I should get a chance this weekend to try it (off tomorrow, so hook up and play time!) Will post results here and on my blog. Darren/SkyCadet |
Latest blog entry: Some notes on the ORX 3AS V2 and DX6i...
Hi all - I just installed this device and it is working great, except for when I am doing rolls. It acts very robotic or clunky when doing one so the roll rate is much slower. I played w/ the gain and I think I am below 50% now(the pot slot is at about the 10:00 o'clock position). That did help some, but, I fear if I turn it down too much I will lose the capability to fly in windy conditions. Any thoughts? Thanks!
| Thread Tools | |
| Discussion 3 axis stabilizer by HK | Early | Electric Plane Talk | 17 | Nov 18, 2012 02:11 PM |
| New Product OrangeRX 3-Axis Flight Stabilizer 14g (advertised) | nemoskull | Indoor and Micro Models | 7 | Sep 21, 2012 09:50 PM |
| Discussion Eagle A3 Aeroplane Fixed-wing Micro Flight Controller Board W/ MEMS 3-axis gyro | eyeinsky1 | Aerial Photography | 3 | Jun 06, 2012 03:38 PM |
| Sold CPD-4 Co-Pilot 2 axis flight stabilization system | ecampos | FPV/RPV - Equipment and Vehicles (FS/W) | 6 | Oct 26, 2011 01:34 PM |
| Discussion ******* 3 axis gyro stabilized video gimbal | powerblimp | Aerial Photography | 10 | Feb 23, 2006 06:00 AM |
