Old Oct 08, 2012, 10:22 PM
Realms is offline
Find More Posts by Realms
Family, Work, FPV!
Realms's Avatar
Australia
Joined Aug 2012
Anyone using this on a PZ T-28 Trojan? what gain settings should I start with? is 12:00 neutral enough to start on?
Realms is offline Find More Posts by Realms
Old Oct 09, 2012, 12:06 AM
chewytm is offline
Find More Posts by chewytm
Ipoh, Perak Malaysia
Joined Jul 2006
12:00 will probably give you almost no response. Try it by twisting the plane with your hands, though.
chewy
chewytm is offline Find More Posts by chewytm
Old Oct 09, 2012, 05:37 AM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Read the manual from post #1
Melnic is offline Find More Posts by Melnic
Old Oct 09, 2012, 07:48 AM
Brush Hog is offline
Find More Posts by Brush Hog
United States, NC, Smithfield
Joined Jul 2012
Around 10 - 11 was the happy spot for mine....going higher would either mess with rolls or cause oscillations. You dont need it to move the control surfaces massive amounts and there is no fade out on it so it will try to fight your stick inputs.
Brush Hog is offline Find More Posts by Brush Hog
Old Oct 09, 2012, 03:27 PM
tengarang is offline
Find More Posts by tengarang
Fly Straight Fly High
tengarang's Avatar
United States, CA, San Jose
Joined Aug 2010
Originally Posted by pugsam View Post
Windy this morning, at the field.
While the other guys kept their stuff on the ground, the Parkzone F4F Wildcat -- with ORX -- was awesome.
Smooth and strong through gusts, with scale-like mild aerobatics (loops, rolls, inverted - the real thing was a sturdy, pudgy, slugger.....not an aerobatic diva!) .
Do you mind showing me where you put this in the wildcat? I imagine you put it where the slot grove is below the battery, but maybe you have a better setup
tengarang is offline Find More Posts by tengarang
Old Oct 09, 2012, 04:24 PM
pugsam is offline
Find More Posts by pugsam
LiPo-Sucker & Airframe EMT
pugsam's Avatar
Charlottesville, Virginia, USA
Joined Aug 2010
Here ya go!
pugsam is offline Find More Posts by pugsam
Old Oct 09, 2012, 05:47 PM
tengarang's Avatar
Joined Aug 2010
Here ya go!
THANKS!!!
Old Oct 10, 2012, 02:03 AM
svtdoug is offline
Find More Posts by svtdoug
United States, WA, Gig Harbor
Joined Oct 2009
I finally received my two Orange RX gyro units a couple of weeks ago. I mounted one in my Pz T-28 and flew it on a very windy, bumpy day. It really helped. I was greasing on landings when others were having trouble getting their planes to the runway. But, watch the gains, the real sensitive area is around 3 o'clock and I found that just below this (2:45 o'clock or so) seem to be a good setting.
Now where I really found this unit to be of great value was with my Art-Tech AT-6 - a tail dragger which is a handful on the runway during takeoff and landing. I've had many ground loops! With the yaw gain set about 3 o'clock, the AT-6 stays very straight on takeoff. It really is cheating, but it works great. I've dialed back the roll and pitch gains to get rid of oscillations. Had one flight with those set too high and about lost the plane due to wild oscillations, so be careful.
Doug
svtdoug is offline Find More Posts by svtdoug
Old Oct 10, 2012, 07:23 PM
Woody_99 is online now
Find More Posts by Woody_99
Too much is just not enough...
Woody_99's Avatar
Joined Jan 2009
Flight report, 3D foamy
Just installed on a 200g, EPP bipe.
Removed from the case, and hot-glued to vertical fuse section. Saved several grams of weight removing from the case.
Set up the gyro as per the 1st page directions, and tips from others on here.
Adjust gains until no chatter, and a little movement of control surface when moving plane around by hand.
Also, had to swap Elev and Rudder on RX and Gyro, due to mounting orientation.
Took it out for the first flight on a very windy day, one that normally wouldn't be any fun with this light a plane.
I have to say, I was very impressed with the stability that the gyro imparted on the plane in this much wind.
It felt like there was no wind, other than the times the wind literally was blowing my plane away. Handled great, all I could have expected!
Tweaked the gains up and down a little, but the initial settings were just about perfect.
Had a chance to take the plane out again, with zero wind.
Again, I'm pleased to say that the gyro did it's thing, but didn't cause any issues in windless conditions either.
I could put the plane in a hover and it would stay put, with just a touch on the control surfaces occasionally. Lowered the throttle, and the plane did a tail slide, but stayed nicely vertical.
Fooled around with the gains again, and ended up putting them back to starting position.
Roll rates, and other flight characteristics are unchanged at these gain settings.
I encountered the disconnected feeling some had mentioned as the gyro buffered the TX input a little. On this plane, I had a LOT of expo for the huge control surfaces. Cut the expo in half, and the natural feel returned.
Short version, I like it a lot, and it did exactly what I was hoping for.
I just wanted to share the experience, and also say thanks to all those that have taken the time to provide detailed feedback on setup.
Woody_99 is online now Find More Posts by Woody_99
Old Oct 11, 2012, 04:21 AM
Berkie is offline
Find More Posts by Berkie
Great Southern Land
Berkie's Avatar
Australia, VIC, Melbourne
Joined Feb 2007
Good on you Woody
An interesting report.
Very similar experience to my own
Kev
Berkie is offline Find More Posts by Berkie
Old Oct 12, 2012, 03:49 PM
Dennis Sumner is online now
Find More Posts by Dennis Sumner
Wanted for breaking Ohm's Law
Dennis Sumner's Avatar
United States, MI, Canton
Joined Sep 2002
I wanted to share my flight report. I have my stabilizer installed in a House of Balsa electric Cub that weighs 23oz. I put in 6 or 7 flights today in perfect conditions, we had a direct crosswind blowing 10-12 mph and the Cub flew great, crosswind loops and Cuban Eights were a blast as were the landings. I have mine adjusted like others have reported, just enough to see some surface movement with a bit more on the Rudder. I used double sided servo tape to mount in the Cub. I also have an E-Flight Mig with AS3X and the Cub flies much the same. It may lack features of other stabilizers and the pots are touchy to adjust but for $15.00 not too shabby.....
Denny
Dennis Sumner is online now Find More Posts by Dennis Sumner
Old Oct 13, 2012, 04:28 PM
Vrated is offline
Find More Posts by Vrated
Vrated's Avatar
United States, UT, Marysvale
Joined Aug 2004
Who has used this gyro stabilizer on a dual/servo, aileron set up? What would happen if the gyro stabilizer was set up on just one aileron? Or run (2) stabilizers, one for each aileron, etc.? Just curious.
~Fred
Vrated is offline Find More Posts by Vrated
Old Oct 13, 2012, 05:21 PM
dav3uk is offline
Find More Posts by dav3uk
Has Sloped Off
dav3uk's Avatar
Uk South Wales
Joined Aug 2009
2 units will give normal operation assuming you use just aileron on the second unit for the second aileron servo
If you use one unit on just 1 aileron servo it will still work but be less effective, it may respond better with a higher gain setting than normal, just take care at the high gain settings.
Dave
dav3uk is offline Find More Posts by dav3uk
Old Oct 13, 2012, 05:55 PM
Vrated is offline
Vrated's Avatar
Joined Aug 2004
dav3uk, Thank you sir. I may try the 2 unit set-up out.
Old Oct 13, 2012, 08:25 PM
noobee is offline
Find More Posts by noobee
Joined Dec 2006
why not use a y servo cable for your second aileron? do you have a flapperon/spoileron setup?
noobee is offline Find More Posts by noobee
Discussion 3 axis stabilizer by HK Early Electric Plane Talk 17 Nov 18, 2012 02:11 PM
New Product OrangeRX 3-Axis Flight Stabilizer 14g (advertised) nemoskull Scratchbuilt Indoor and Micro Models 7 Sep 21, 2012 09:50 PM
Discussion Eagle A3 Aeroplane Fixed-wing Micro Flight Controller Board W/ MEMS 3-axis gyro eyeinsky1 Aerial Photography 3 Jun 06, 2012 03:38 PM
Sold CPD-4 Co-Pilot 2 axis flight stabilization system ecampos FPV Equipment (FS/W) 6 Oct 26, 2011 01:34 PM
Discussion ******* 3 axis gyro stabilized video gimbal powerblimp Aerial Photography 10 Feb 23, 2006 06:00 AM
