Old Nov 12, 2013, 11:18 AM
dav3uk is offline
Find More Posts by dav3uk
Has Sloped Off
dav3uk's Avatar
Uk South Wales
Joined Aug 2009
The Guardian offers features and control modes that can be used to fine tune your gyro experience waaaaaay better than the basic 3AX units.....but you pay for that simple.
If used as is the 3AX is a basic 3 axis rate gyro that will smooth out flight in gusty winds etc.
It also can help with 3d with the gains up high....but it can be hard to set up at that level of gain.
Other uses are stabilising basic camera platforms to smooth the video, we are not talking about horizon following super stable just smoothing out footage.
For the price it make an excellent start point to have an experiment, some find that what they give is all they want or need and stay with them
Others find it ignites a spark of curiosity and move up to more complex ones.
Give one a go, for the price there is nothing to loose......but set it up correct....remember check/check/check........
Dave
dav3uk is offline Find More Posts by dav3uk
Old Nov 12, 2013, 12:30 PM
itsme2 is offline
Find More Posts by itsme2
United States, TN, Maryville
Joined Mar 2011
Dave
Thanks for the great info Dave, just what I wanted to hear.
I've ordered HK 6 Channel RX3AX and V2 units to play with.
My planes tend to be mostly high value or highly valued that I try hard not to crash. Can anyone here recommend an inexpensive RTF/ARF/BNF sturdy foamie that would make a good gyro test platform? I also have a Apprentice 15e trainer, would this be a good gyro test platform?
Thanks again!
itsme2 is offline Find More Posts by itsme2
Old Nov 12, 2013, 01:58 PM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Dave
Only a model if you get it wrong. Ask me how I know.
Flypoppa is offline Find More Posts by Flypoppa
Old Nov 12, 2013, 02:19 PM
dav3uk is offline
Has Sloped Off
dav3uk's Avatar
Uk South Wales
Joined Aug 2009
Indeed get the setup wrong on this, or any other 3 axis gyro and the results can range from the unexpected to the spectacular(not in a good way). Sometimes when setting up you look and look and look and still get something the wrong way.......been there.......also it is sooo tempting to go for big deflections of the gyro......but less is more here and it take quite small movements to get a nice result (unless 3d ing) The more expensive units from Guardian and the like let you adjust the gain whilst in flight or have 3 pre set rates etc and that makes it much easier to set up.
Also when setting up I always put the on/off channel to switch that is in easy reach with both thumbs still on the sticks so it can be knocked off real easy at least till its dialled in.
Most of my planes with gyros, once dialled in have the units on all the time and rarely need the off and on........but whilst setting up its a must, I nearly destroyed my first plane with V1 in it as the elevator was so sensitive it was like a bucking bronco trying to self destruct......lol
Go easy on the gains start low and work up in small steps and check everything over and over and once more at the field.....
Dave
Old Nov 12, 2013, 03:38 PM
itsme2 is offline
Joined Mar 2011
HK has the ET Guardian for $63.74 http://www.hobbyking.com/hobbyking/s...+tree+guardian is this the same unit sold elsewhere for $75.00?
Thank you!
Old Nov 12, 2013, 05:26 PM
JohnRB is offline
Find More Posts by JohnRB
United States, NC, Raleigh
Joined Oct 2011
Thank you!
From the photo it appears to be the same device I purchased from Tower Hobbies. It has a Gyro and an Accelerometer with a more powerful processor and firmware with more features. The RX3S only has a Gyro.
I have not tried my yet, too many toys - not enough time.
I am still happy the the RX3S and Open FlightStab Firmware.
John
JohnRB is offline Find More Posts by JohnRB
Old Nov 12, 2013, 05:28 PM
JohnRB is offline
Joined Oct 2011
I'm very interested in trying gyro setups in some of my planes and am considering the ET Guardian and 3AX units. The Guardian seems to be very complex to set up, is it really worth the trouble for the extra features versus using the simpler 3AX unit?
Thank you!
What is a 3AX? Is that just a different name for an HK RX3S V2 or V3 (with Rx)?
John
Old Nov 24, 2013, 10:15 AM
Gary Hoorn is offline
Find More Posts by Gary Hoorn
Chesapeake Bay RC Club
Gary Hoorn's Avatar
USA, MD, Annapolis
Joined Feb 2005
Orange 3 AXIS Stabilizer
Interesting flight Friday with my Decathlon. Turning from upwind the plane begin to buck and roll almost uncontrollably. Switching off the gyro steadied things down. I at first thought the gyro had failed but upon landing I noticed the gyro hanging loose on the wires. My old double sided tape had failed. Sure am glad I had the switch setup to turn off the gyro. Note to self, toss out the old tape
Gary
Gary Hoorn is offline Find More Posts by Gary Hoorn
Old Nov 24, 2013, 11:03 AM
JRuggiero is offline
Find More Posts by JRuggiero
Blacksburg, VA 24060 USA
Joined Feb 2000
Gary Hoorn,
Thanks for your suggestion. Though my gyros are in plain sight, so I can easily check the mount, your warning serves well when setting up a gyro that's out of sight inside a fuselage.
I would also add that weird gyro behavior can be caused by control surface linkages that aren't tight, permitting flutter that the gyro may try, unsuccessfully, to correct.
Jim R.
JRuggiero is offline Find More Posts by JRuggiero
Old Nov 24, 2013, 11:19 AM
dav3uk is offline
Has Sloped Off
dav3uk's Avatar
Uk South Wales
Joined Aug 2009
Originally Posted by JRuggiero View Post
Gary Hoorn,
Jim R.
+1 on this, as with any servo controlled by a feedback loop type system such as this it is very important to remove all slop from the linkages, hinges and servos themselves. Also as the servos will be constantly 'hunting' as they correct faster servos are better as are those with metal gears as cheap plastic gear servos get overworked with a gyro, remember helis have used gyros for years and some of the most expensive servos are tail rotor ones.
Dave
Old Nov 25, 2013, 03:25 AM
BAF23 is offline
Find More Posts by BAF23
The sky is the limit
BAF23's Avatar
Belgium, Vlaams Gewest, Hasselt
Joined Aug 2012
Dave
I think you made a point here. These stabilizers are not bad at all, even the series 1, but most people tend to try these out on an "expandable cheap" and often worn out model. Because of the lesser quality servo's and accumulated play on control surfaces, their test planes show weird behavior and they blame the stabilizers for that, discarding a cheap piece of fine equipment because they don't trust it on their more expensive "serious" planes. Just like you wouldn't consider driving a car with play in the steering system over a German autobahn, don't even think of flying with play on the flight control system. As power steering wouldn't help in the car, gyro's won't help in an aircraft.
BAF23 is offline Find More Posts by BAF23
Old Nov 25, 2013, 03:32 AM
dav3uk is offline
Has Sloped Off
dav3uk's Avatar
Uk South Wales
Joined Aug 2009
Yep, as I am also a heli flyer the importance slop free linkages is something that is natural to me.
Dave
Old Nov 25, 2013, 06:27 AM
flypaper 2 is online now
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Tried my first one on an old beater Twist 3D and as you say, didn't make much difference, and was getting surface flutter without even launching, as the surfaces were over running with the slop, trying to keep up with the gyros. I replaced all the surface horns and it made a different plane out of it.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Nov 25, 2013, 07:40 AM
dahawk47 is offline
Find More Posts by dahawk47
Augermeister
dahawk47's Avatar
United States, TX, Keller
Joined Jul 2011
My first gyro experiment was with the "Ice Man" . Nice setup. Installed it in a PZ-28 which had become my experimental platform. Got her up in the air no problem. Was entirely focused on watching the plane's behavior and lost track of my heading. Smack ! Direct hit into oak tree. A bag full of foam pieces. LOL. Have this Orange version installed in my Durafly Spitty and am testing per Dave's rec's. A little at a time. So far, so good.
-Hawk
dahawk47 is offline Find More Posts by dahawk47
Old Nov 25, 2013, 11:58 PM
Weed89 is offline
Find More Posts by Weed89
Weed89's Avatar
United States, CA, Thousand Oaks
Joined Aug 2012
I was hopeing to use one of my 3 axis orange RX's in my new plane. but cant, as I have spoilerons / flaperons / etc... bummer would have been fun
Weed89 is offline Find More Posts by Weed89
Discussion 3 axis stabilizer by HK Early Electric Plane Talk 17 Nov 18, 2012 02:11 PM
New Product OrangeRX 3-Axis Flight Stabilizer 14g (advertised) nemoskull Scratchbuilt Indoor and Micro Models 7 Sep 21, 2012 09:50 PM
Discussion Eagle A3 Aeroplane Fixed-wing Micro Flight Controller Board W/ MEMS 3-axis gyro eyeinsky1 Aerial Photography 3 Jun 06, 2012 03:38 PM
Sold CPD-4 Co-Pilot 2 axis flight stabilization system ecampos FPV Equipment (FS/W) 6 Oct 26, 2011 01:34 PM
Discussion ******* 3 axis gyro stabilized video gimbal powerblimp Aerial Photography 10 Feb 23, 2006 06:00 AM
