Old Jul 31, 2012, 08:07 AM
Early is offline
Find More Posts by Early
United States, SC, Charleston
Joined Jan 2007
3 axis stabilizer by HK
Ever since the Carbon Cub came out I was looking for a way to stabilize my small planes in the wind. I think this is the answer at a reasonable cost.
Anybody out there have experience with the HK version of the 3 axis stabilizer? Any issues setting them up?
Early is offline Find More Posts by Early
Old Jul 31, 2012, 08:53 AM
onewire is offline
Find More Posts by onewire
onewire's Avatar
United States, CA, San Diego
Joined Jul 2009
Just saw this myself in the Flight Deck email this morning. There's one review on their site, but since it's so new makes me wonder where he got his.
onewire is offline Find More Posts by onewire
Old Jul 31, 2012, 08:58 AM
Early is offline
Joined Jan 2007
Agreed,
I placed an order for two but they are on BO.
I know the technology works and I have had good luck with the Orange brand so I would expect this to be a fairly good product as well.
Old Jul 31, 2012, 09:15 AM
nickelbn1 is offline
Find More Posts by nickelbn1
fly and then fly some more!
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
I am curious how this hooks up. Is this actually a rx too? What brand radio does it work with?
nickelbn1 is offline Find More Posts by nickelbn1
Old Jul 31, 2012, 09:16 AM
onewire is offline
onewire's Avatar
Joined Jul 2009
BO already? I need to put together another HK order myself. I always split the BO from available items or nothing ships. Might order one of these. I'm assembling a World Models Spitfire that is turning into a pig. I wonder if this would help. Gonna call her the Pigspit. Gotta get some nose art.
I just read that as of tomorrow EMS shipping is going to start using package size and weight as opposed to just weight. Whichever is greater.
Old Jul 31, 2012, 09:48 AM
KaiWE is offline
Find More Posts by KaiWE
Low'n Slow is safest, right?
KaiWE's Avatar
Norge, Østfold, Fredrikstad
Joined Jun 2011
It is put between your receiver and the servos, so it is plug'n play with all radio systems using the normal type servos. Just remember to get male to male servo leads to go from receiver to stabilizer...
KaiWE is offline Find More Posts by KaiWE
Old Jul 31, 2012, 01:43 PM
Early is offline
Joined Jan 2007
Thanks for that information KaiWE
Old Nov 14, 2012, 04:21 PM
Roo man is offline
Find More Posts by Roo man
Roo man
United States, FL, Lakeland
Joined Feb 2008
Use of rudder only on the HK 3 Axis flight stabilizer
I just receuved my HK stabilizer and need to know if I can use it for rudder only, bypassing any other electrical connections?
Just need to help control Cub on take off.
Gary
Roo man is offline Find More Posts by Roo man
Old Nov 14, 2012, 06:40 PM
Mr. foambuilder is online now
Find More Posts by Mr. foambuilder
I fly 3-C Crash,Crunch,Crumble
Mr. foambuilder's Avatar
USA, NM, Clovis
Joined Feb 2010
I just purchased a used one, and have it right here in front of me, and it works just fine with the rudder servo plugged into the gyro, and the others plugged into the RX. This is a bench test only, but it works for me.
Roy
Mr. foambuilder is online now Find More Posts by Mr. foambuilder
Old Nov 14, 2012, 08:34 PM
Roo man is offline
Roo man
Joined Feb 2008
Roy
Thanks Mr. foambuilder.
Gary
Old Nov 14, 2012, 08:48 PM
matiac is offline
Find More Posts by matiac
AMA 994002
matiac's Avatar
United States, RI, Westerly
Joined May 2012
I have one in my FMS 750MM P47, and it was revealed to me that because the stabilizer is going to be "double-timing" the servos, it would behoove most to install some sort of BEC between the battery and the receiver, and plug it into the battery inlet on the receiver as a failsafe. But that aside the Orange I have is doing great with bench testing, however I'm not putting it up until the SBEC (in my case) is installed. All settings are 50% from the factory, and I've heard some people having little adjustment before 50%, and way too much past it. Mine has adjustment through the entire travel of each pot, so I guess maybe I got a good one, but for 15 bucks you can't go wrong. Only thing sucked was waiting for it to arrive from Hong Kong...
matiac is offline Find More Posts by matiac
Old Nov 14, 2012, 09:09 PM
USA, NM, Clovis
Joined Feb 2010
Gary
You are welcome Gary. I have an old 3D foamy that I am going to try mine on, just for grins. should be over there doing it now
Old Nov 14, 2012, 09:19 PM
Krash n Burn is offline
Find More Posts by Krash n Burn
United States, AZ, Gilbert
Joined Mar 2012
I have one, been happy with it. As mentioned above my pots only adjust above 50%, so its very touchy when adjusting since your only working with the top 50% of the pot. Other then that it does what it says it does.
Krash n Burn is offline Find More Posts by Krash n Burn
Old Nov 14, 2012, 09:22 PM
Bigbond is offline
Find More Posts by Bigbond
United States, MN, Avoca
Joined Nov 2012
does it support AVCS and gyro off?
Bigbond is offline Find More Posts by Bigbond
Old Nov 14, 2012, 10:27 PM
tlrascal is offline
Find More Posts by tlrascal
United States, AR, Lavaca
Joined Aug 2002
Stabilizer
This is not for heli use so AVCS is not supported. You cannot remotely adjust the gain or turn off. I had to go from a 2Amp BEC to a 3 Amp to make up the additional current draw. I suspected that and tested on the bench and I would. Get error LEDs on my Spektrum receiver with 2and they did not occurr with 3 Amps.
Initial flight tests were good but I have not done any fine tuning of the gain yet. If you only want to control rudder I think it would work but I would use a regular piezo gyro for that.
tlrascal is offline Find More Posts by tlrascal
Discussion ******* 3 axis gyro stabilized video gimbal powerblimp UAV - Unmanned Aerial Vehicles 16 Feb 18, 2013 12:50 PM
Sold Skookum SK360 Flybarless Stabilizer 3 axis gyro AtTheCross Aircraft - General - Radio Equipment (FS/W) 0 Apr 05, 2010 11:02 PM
Discussion ******* 3 axis gyro stabilized video gimbal powerblimp Aerial Photography 10 Feb 23, 2006 07:00 AM
Discussion ******* 3 axis gyro stabilized video gimbal powerblimp Fuel Heli Talk 1 Feb 22, 2006 06:50 PM
